Question about Boating
Looking for location of impeller on a inboard motor boat?
  • 5,546 Answers
If it has a OMC or Volvo most are in the top of the outdrive. If your motor looks like a car engine it can be if the front just like a car. This website claims they have online access to repair manuals so I would look there first. Go to other websites and look for impellers with the brand of motor, like Volvo impellers, Mercruiser impellers and some of those sites have excellent parts diagrams.
Posted on Apr 28, 2009
What year and model is mariner 75 serial number 9502368
Hey Arthur,
This serial number does not show up..???Please look for more numbers on any plate or freeze plug..
These guys can help.. need more info though...
Outboard Motors Boat Parts Marine Engines Inboard Boat Motor
Jun 20, 2017 | Boating
Hi, have a mariner 75hp outboard serial number 9502368. Can you please identify year and model so I can order spares
Hey Arthur,
These guys will take care of you,,, that serial number doesn't satisfy the rewquirements for a search...? They will need more info.. more numbers on any plate..freeze plug..look around the outside of the engine carefully..
Jun 19, 2017 | Boating
My boat motor starts fine. But it will not move in forward or reverse. What do I look for?
Greatly depends on the make/ model of the motor, is it an outboard, Inboard, etc.
Oct 01, 2015 | Boating
I just got a new boat this summer and I live in Seattle, where I will use my boat year round. I have been told that I should winterize the motor so it doesn't freeze in the lower temperatures. What should...
I used to live in the Chicago area. We definitely had winter (below zero).I went thru extensive winterization for the inboards and stern drives. I fogged outboards and put Sta-bil in the gas. I also ran the gas out of the carbs or drained them but the boats would sit unused for 6 months. Does the boat stay in the water? If on a trailer, lower the motor so it is in the run (trim down) and the water will run out. If you tilt it up after this for storage, cover the gear case as it can fill with rain water and freeze.
Jul 24, 2014 | Light Outboard Motor Boat Bass Fishing...
How do i replace an impeller on a 5.7 merccruiser inboard /outboard engine
There Is a Impeller On The Sea Water Intake Side Driven By A Fan Belt At Front Of Engine ,
Remove Cover Pull Out Impeller Check Key Fit New Impeller And Gasket
Aug 03, 2010 | Boating
How do I remove engine? 3.0L inboard
hi how do i remove a inboard marine motor from my boat JUST THE MOTOR.
Dec 06, 2009 | Boating
Mercruiser 5.7 litre inboard engine Impeller fault
You could be right. Check your idle rpm to see if the motor DIESELS after shutdown. See if linkage and carb setting can be reduced for RPM. Last, check your timing. If it has springs in the distributor you should not see rust powder on pivot points. Binding would keep engine overadvanced at shutdown. Then basic timing could be off too.
Sep 21, 2009 | Boating
My exhaust is a lot hotter on the right side then the left
You do need a lot of water to prevent your problem. I think we are talking about an inboard or I/O unit. Make sure you replaced the flapper valves in the exhaust too. There should be a water pump on the motor as well as the impeller in the outdrive. Check to see if you have a sealed cooling system with a radiator or an open system using only outside water. There may be a thermostat in the motor in either case. Do not run a boat above idle when you use muffs and a hose. Everyones water pressure is different at the tap.
The closed system uses an intercooler and a radiator. You can have the same radiator problems as a car and you should always use antifreeze in the radiator to prevent rust. If the right side is hotter then it is probably more blocked.
Jun 17, 2009 | Boating
Boating Logo
829 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
