Question about Baumatic BWE40 Wine Cooler
Error code flashing E2 - Baumatic BWE40 Wine Cooler
Need help. Flashing E2 and 61 codes. The paper is not jammed and it has a new carterage.
Canon PC-920 Black and White Copier E2 error - Questions ...
www.fixya.com > ... > Canon > Canon PC-920 Black and White Copier .. error code e7 & e2 Cannon pixma mp145 printer error code e7 & e2 E2: Reload the paper correctly and press [Black] or [Color]. E7: The cartridges are not ..
Jul 21, 2015 | Canon PC-920 Black and White Copier
Tip
Whirlpool Calypso Dryer Error Code Explanations And Repair
Failure - Code Condition - Check/Repair
PF - Power Failure - If the household power goes off and the control board was in RUN mode or PAUSE mode, the electronic control board will display a power failure error code.
E1 or E2 - Thermistor Failure - The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
  • When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
  • When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
  • 60 degrees F. - 15.3K ohms.
  • 70 degrees F. - 11.9K ohms.
  • 80 degrees F. - 9.2K ohms.
E3 - Touchpad or Software mismatch - Flashes when there is a touch pad or software mismatch.
  • This error code is displayed only in diagnostics mode.
on Jul 19, 2010 | Washing Machines
Avanti error code e2 wine chiller, what is the problem?
Display flashes Error message "E2" - Defrost sensor (Coil Sensor) failure.
Contact the Avanti Service Department - 1-800-220-5570
Hope helps.
Jun 03, 2011 | Avanti WC42 Wine Cooler
Dryer will not start display works, when i push the start button it just beeps and does nothing, shows a E01 code.
Hi, this is what the error code means,
E1 or E2 Thermistor Failure The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
Hope it helps.
Jan 19, 2011 | Whirlpool GEW9250 Electric Dryer
E-1 CODE
Hello there
This code can sometimes be the e-1 or sometimes the e-2 here is the descrioption of what it means
80 degrees F. - 9.2K ohms.Dryer thermistor assembly
Jul 27, 2010 | Whirlpool GEW9200L Electric Dryer
E1 code on kenmore front load dryer
Hello there
I have written a list of codes that should cover your problem nd give you some idea what to check ok
80 degrees F. - 9.2K ohms. E3 Touchpad or Software mismatch Flashes when there is a touchpad or software
Dec 16, 2009 | Kenmore Dryers
Fujitsu fi 5120c e2 error
See page 25 of:
http://193.128.183.41/support/scanner/manuals/fi-5120c_gs_p3pc-1312-01en.pdf
"E2" is "Trouble with the optical system (front)."
That doesn't solve your problem, but at least it narrow downs the focus of your problem.
Dec 05, 2008 | Fujitsu ScanPartner fi-5120C Pass-Through...
Pentax espio60s?
E2 error code stands for an issue with the lens and/or shutter assy. unless you get the faulty parts repaired/replaced there is nothing you can do about it.
Sorry for the bad news.
Oct 19, 2008 | Photography
E2 Paper Jam code flashing .... but no paper jam!
There is a small sensor on the fuser that most likely has become disloged. It requires a lot of disassembly to get to.
But an E2 code is that sensor not being cleared off. It pops out of the frame sometimes during paper removal.
Apr 14, 2008 | Xerox WorkCentre XE80 Laser Printer
Error codes
Does it show ERROR 2, or just E2?
E2 isn't actually an error. It just shows that the unit is set to SCART 2 input.
Mar 13, 2008 | Philips DVD750VR DVD Player/VCR
Baumatic BWE40 Wine Cooler Logo
53 people viewed this question
Top Baumatic Refrigerators Experts
Sal De
Colin Stickland
Colin Stickland
Electric Dime
Electric Dime
Are you a Baumatic Refrigerator Expert? Answer questions, earn points and help others
