Very light copy how make it dark - Office Equipment & Supplies
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
You've posted this question four times. When you post for a fifth time, please specify the model of your Kyocera machine.
Posted on Oct 15, 2013
If copy quality is very dark then what to do for making it normal
The dark quality is definitely linked to a light intensity problem. If the scanner lamp is operating properly then check for any reflective surfaces near the scanning lamp and clean those. It only takes a light film of dust to make copies dark. Be careful around the lamp, it is delicate.
Jan 26, 2015 | Canon 2234B007 - Faxphone, L90 Laser,...
Background on copies, possible dirty charge roller , I cleaned all optics is there an adjustment to perform to help eliviate this background
yes it could be chatge rollers fault, but how many copies does developer have? I would clean the charge roller with water, dry it, and change the developer. On these digital machine, when you have backround wich is dark, these means that developer is worn out and you need to change it and clean developer cylindar. When the optics is dirty the image will be light, not dark!!!!! Only on analog copiers when optics is dirty the copy is dark, and when the developer is worned out the copy is light!!!!
Aug 03, 2010 | Ricoh Aficio 150 Copier
Copy darkness problem canon image runner 2830
Did you try to clean beneath the copy glass?
On digital machines, when the copy glass or optics are dirty, copy becomes verry light.
How many copies do you have? pres 123 button.
It also could be that you need to change the toner station, by the book it goes 300000 copies.
But I bet on dirty copy glass and dirty scanner assy.Clean the glass with glass cleaner and polish it with dry cloth.
Jul 25, 2010 | Canon imageRUNNER 2870 Copier
In my ir3300 xerox in very light
That means that you have to clean copy glass , lenses, ccd,...maybe even laser unit if you know how.
On digital machines dirty optics means light copy, on analog oposite, dirty optics dark copies.
Just one more question how do you mean " charge toner"?
Jun 07, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
I want to know that how to adjust exposure level in sharp 1118 or how to make light copy with diganostics mode
l For manual copy density adjustment, press the AUTO/
MANUAL/PHOTO ( / / ) key to select
MANUAL ( ) and adjust with the LIGHT ( ) and
DARK ( ) keys as desired.
l For photographs, select PHOTO ( ) and then adjust with the
LIGHT ( ) and DARK ( ) keys as desired.
l There are 9 exposure steps indicated by 5 indicator lights. (The
indicators light up one or two at a time.)
Successive pushes of the LIGHT ( ) key will change the
indicator lights in the order (3) / (3•2) /(2) / (2•1) / (1).
Successive pushes of the DARK ( ) key will change the
indicator lights in the order (3) / (3•4) / (4) / (4•5)/ (5)
The automatic exposure level can be adjusted to suit your copying
needs.
1 Press the AUTO/MANUAL/PHOTO ( / / ) key
to select the PHOTO ( ) mode.
2 Press and hold the AUTO/MANUAL/PHOTO ( / /
) key for approximately 5 seconds.
l The PHOTO ( ) indicator will go out and the AUTO indicator
will begin to blink.
l One or two exposure indicators corresponding to the automatic
exposure level which has been selected will light up. The factory
default setting is level “3”.
3 Press the LIGHT ( ) or DARK ( ) key to lighten
or darken the automatic exposure level as desired.
4 Press the AUTO/MANUAL/PHOTO ( / / ) key.
l The AUTO indicator will stop blinking and will light up steadily.
l This automatic exposure level will remain in effect until you
change it again by this procedure.
Automatic exposure adjustment
AUTO
Jul 27, 2009 | Sharp Office Equipment & Supplies
Smudges on paper and then when it does copy, ink is light.
hi,check copy cartridge or clean corotron wire.try to increase toner.send me result.
thank you.
May 25, 2009 | Sharp AR-5320 Black and White Copier
Dark copies with overprinting
Cleaned the coronas as per instruction book. Done this before but this time it made a difference.
May 07, 2009 | Lanier 1205 Copier
New scx-4521-FG/ too much fad
The darkest copy setting is obtained when the contrast is set to dark and the toner save is turned off. If the originals being copied are too light, this unit has trouble seeing the image and the copies are extremely light as well. If the originals are good and dark, try using original toner cartridges.
Be blessed.
Oct 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Copy Quality Problem for Thiashen
bit vague...Cq not good? What does that mean?
Light copies> could be related to toner or ROS unit (laser unit)
if prints OK but copies U/S clean mirrors and ccd lens
Dark copies , streaking? Cleaning blade /drum unit U/S
or could be streaking from fuser roll
Patchy copies , dark edges, light edges ???????
more detail please
Feb 02, 2008 | Office Equipment & Supplies
Light Copy
first you press the exposure key and select the manual exposure mode then press and hold exposure key for 5 seconds when it blinks select the position to dark and press exposure key again,try to make the copy if no defrence ,select the photo mode and press and hold the exposure key again select the dark position by dark exposure key and press exposure key again.check the copy if again no difference change the DEVELOPER
Sep 14, 2007 | Kyocera RI-3530 Black and White Copier
13 people viewed this question
jasbo
jasbo
