Make sure that the printer track is free of any torn paper. Make sure that the tractor feeds themselves are free from debris. Turn it off during this check.
You can download drivers and utilities for your printer from the official epson website: - Go to the following link, select your operating system and download the required drivers http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=lkuCfcvA9cyRTlGwUL1lv5OaljCjq0ay4SX9fAMnNrsU003D&tc=6
Hello sir; You may go to computer to set up; Hit print then go to preference then paper/quality then you can choice the type of the paper you want to print, good luck.
First of all turn the printer off & disconnect all of the cables. Turn it over and give it a shake, you'll be amazed at what gets inside the feed hopper. Next try a stiff piece of A4 card (the backing from an A4 notepad for instance), feed the card into the paper feed and push it through quite hard to overcome the spring resistence. Once it has started to go through open the lid and check if it has pushed anything through the rollers. Feed the card all the way through the mech and pull out of the front. Hopefully the card will have cleared the paper path of any objects and reseated the sensors.
Good luck.
no you might have a paper jam somewere and mabe you ink rollers are dry you might have to tell the printer to to a pre test and clean and if there is a paper jam it should be a slot on the back by the roller should be a tap that shows the tollers look for a pice of paper jammed somewere in the roller you migh have to take the paper out to inspct it for a paper jam and if none mabe the print heads are dry and it dosent feed the paper then could be it ok clean the print heads tell the printer to to a roller clean and then after that if no paper jam no were try printing a page take all the paper out and feed it manually and if it prints then some printer want feed if you have filled the paper tray up try putting less and then try
all my cartridges are full/newly changed. my epson stylus cx5200 keeps
on feeding papers, displaying printing message but with no actual print
out i.e. blank paper comes out. please help. thanks!!
Front LCD reads error "Check Paper & Retry" When paper is inserted and loaded correctly and machine is reclosed the printer then initializes then reverses the feed of the paper and is ejected and error continues to reappear.
Download the proper driver to your desktop, when the install asks you for a driver location, click bworse and select the driver and do an auto install.
Should be quick and fairly easy.
you wont have to feed the paper just try to print and it'll feed the paper automatically. but if there is a problem in mechanism that will be your problem, you'll have to bring it or just call a service tech.
