Kyocera copy machine
Very light copy.how to make dark
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
What model Kyocera copy machine?
Posted on Oct 15, 2013
DIRTY COPIES BOTH SIDE OF PAPER
don't always believe what they say. just because its "supposed to " last a certain amount of time, doesn't mean it will. Once you get the insides dirty, its hard to get them straight again. Sometimes there is build up on the printer head from a leaky cartridge. I'm just guessing cause I had a similar brand that was brand new act up on me and because I was printing bold it started rolling the paper. I put it on economy printing to save toner and after a few runs, it cleared up. plus using a watermark helped but don't think that will help you in your situation.
Sometimes when I get a streak on one side its from light coming in from somewhere and it thinks its part of the image and prints it. If you make sure that your material is flat and not allowing light to come in or its firmly against the glass it might help.
Feb 20, 2014 | Kyocera Km-1820 Copier Fax Machine
Produces Light Copies
Have you considered changing or checking the toner cartridge?
Does it display a low toner light?
I had a similar problem with a copy machine, where ALL the settings were correct and the toner was light.
The problem was the toner cartridge, the toner was caking because of the temperature. All it took was a good shake at the toner cartridge and it worked.
Also, check to see if the scan bed is messy, a good cleaning the the scanner bed should work as well.
Hope That helps!
Dec 12, 2007 | Kyocera Mita KM-3035 All-In-One Laser...
Very light copy how make it dark
You've posted this question four times. When you post for a fifth time, please specify the model of your Kyocera machine.
Oct 15, 2013 | Office Equipment & Supplies
Dirty and light copy of my Kyucera KM 1505 copier machine
Clean the optical parts (lens,mirrors),and the poligon motor mirrors.
Apr 08, 2013 | Kyocera Mita Office Equipment & Supplies
Our copies and starting to come out dirty and
Dark copies in that machine means the drum it's getting old. If adjusting the exposure to light makes the copies better, then the drum is the culprit.
Apr 28, 2010 | Kyocera KM-1510 Copier
Getting a dark line on the copy pages. Need a new
Mite be a problem with your doc feeder. Are you using a doc feeder? If so raise up the doc feeder and place an orgnial on the big glass instead of feeding the orginal thur the docfeeder. Does the line disappear? If it does then the **** glass the small glass used by the docfeeder has a mark on it or dirt. Is your machine a printer also? Does the print have the mark/line on them also. Do any of your machine's internal reports have line on them Meter Read print outs etc.
Apr 25, 2010 | Kyocera Mita Office Equipment & Supplies
Right side copies light ,left side is dark but fades to the right
clean optics or check if the transfer roller is balanced on both sides
Mar 25, 2010 | Kyocera Office Equipment & Supplies
Kyocera Mita 1635 Copier Printing Very Light Copies
Is one side lighter then the other side of the copy? Meaning uneven copy darkness? If so, I believe the problem is that one or both sides of the drum cartridge and the developer are not connected correctly. The two parts need to be close togather to make a nice dark copy. This model has a very wierd drum unit and has a defect that one or both side of the drum unit locking tabs break and you get very light or blank copies. It's some what coastly to replace the whole unit... That would be a worse case.... If it is just on one side you might be able to push on the cover on the side that is light. If the copies come out better. One side is broken..I would fold up some paper and make a wedge to push the catridges closer. Good Luck
Apr 15, 2009 | Kyocera KM-1505 Copier
Dark line across copies
1-remove drum and turn upside down, is there a black ring on the shiny cylinder, yes, replace
2-remove drum and clean inside of machine look for strip of light, clean for toner
3-if cpying from an automatic feeder, and it does it from there ONLY then lift ADF and clean the small strip of glass.
Sep 14, 2008 | Kyocera KM-1510 Copier
Light Copy
first you press the exposure key and select the manual exposure mode then press and hold exposure key for 5 seconds when it blinks select the position to dark and press exposure key again,try to make the copy if no defrence ,select the photo mode and press and hold the exposure key again select the dark position by dark exposure key and press exposure key again.check the copy if again no difference change the DEVELOPER
Sep 14, 2007 | Kyocera RI-3530 Black and White Copier
24 people viewed this question
jasbo
jasbo
