Question about Cycling
Gears slipping on bike
My bike won't run in any gear except top. It's quite old and simple, with 5 gears. When I push the lever down to change down, the derailer thing moves the chain across perfectly and it bites on bottom gear but as soon as I release the lever the derailer just pulls the chain back out to the side again and the chain bites back in top gear again. I don't really want to take it to a shop as it must be something simple, I hope!
  • 469 Answers
The center bolt of the thumb shifter is a friction bolt, some have wings, some have a "D" ring, and some will just have a slot to put a screw driver into, tighten this screw a little at a time until it is comfortable to use but will hold back the derailleur.
Hope this is of some help.
Ed
Posted on Apr 24, 2009
My 03 Kawasaki Bayou 250 will slip out of 5th gear and sometimes will not go into 5th it has a fresh oil change and the right amount of oil
id have a professional take a look at your gear case , there sometimes is too much free play in trip lever for gears and it cant reach the farthest ones , also it could be the trip lever or case has been damaged by hitting something (happens) this will move the end play of trip lever too far away to reach end gears , removing a gear case side is a little too extreme unless your a professional mechanic as there are lots of tiny bearings and things inside there to move/loose not to mention the almost half a gallon of gear lube thats gonna run out
Sep 23, 2015 | Cars & Trucks
5th gear shifter linkage reverse
can i assume you pulled the side plug on tranny and the level
is right there? or gone way down, ever do a 50k service? to it?
M/T tranny (not auto) what engine? the m./t varies by HP of ENGINE.
If its really in 5th ( i bet not)
if the RPM rises fast that is called clutch slip
yes, clutch bad.
if not in 5th actual rpm will rise fast too. slip,
if the other gears wroke like 4th at wide open throttle up hill
gee the chutch is good.
so its not going in to 5th (for lots of reasons)
but 1 reason , is easy.
-AX 4/5/15 transmission
this tranny has a shift tower. (that thing on top that the shifter lever
fits in to)
most tranny that fail to actual shift into gear
is caused by a $1 plastic part failure
so pull the shifter off top of the shift tower.
and look, is the plastic buffer parts all bad, missing, cracked or
destoryed, sure they all end there... all.
i can also remove the shifter, lever.
and shift to 5ht by hand, and see that it DOES.
it either does, or does not.
if it does, the lever parts are bad.
that simple.
see part 61 (im guessing which of 5 tranny it is , )
http://cdn.liveoffroad.com/images/Aisin_AX5_Transmission.jpg
Feb 04, 2014 | 1994 Jeep Wrangler
Where can I find 2/3 & 4th gears for Yamaha XJ special 1982 model.
Instructions
The gears on a motorcycle run in this order: first, neutral, second, third, fourth and fifth. When you are moving, shifting up from first gear will skip over neutral and shift you right into second gear. The only time that shifting up from first will get you into neutral is when you are not moving.
Pull in the clutch lever and tap the gear lever down until it stops. This will signify first gear. Pressing the gear lever down will shift you down one step and pressing it up will shift up one step.
Tap the gear lever up one click while still holding in the clutch. This will put the bike into neutral.
Start the bike. The bike needs to be in neutral to start.
5
Hold in the clutch lever and tap the shifting lever down to shift to first gear.
6
Release the clutch slowly and give it just enough gas to get moving.
7
Listen to the motor to know when you need to shift. If the engine is making a low grumbling noise, then it will need to be shifted down. If it is making a high squealing noise, then it needs to be shifted up.
Jan 15, 2013 | Motorcycles
I have a 2006 Harley Sportster 1200 Low. I went down on the bike and now the gears aren't catching. When I picked the bike up it was in 5th gear and barely moved when I pulled the throttle. It shifts...
Most likely the clutch is not engaging. or the power transfer from the engine to the gearbox has been disrupted. The gear lever may have been pushed into the engine and so become detached from the gearbox.
Nov 28, 2012 | Motorcycles
I have an old Avanti Edge Cro-Mo bike. I know the brakes are on the right handle bar but not sure how to upshift and downshift gears.
If this is the road bike model, then most likely the shifter and brake lever are the same. To brake pull back on the lever, to shift move the lever toward the center of the bike.
The Right lever works the REAR gearing. This makes small changes. The bigger lever will shift the gears toward a larger gear and make the cycling easier. The small lever works the opposite.
The Left lever works the FRONT gearing. This makes large changes. The Bigger lever will shift the gears toward a larger gear and makes the cycling harder. The small lever works the opposite.
If you don't have these types of levers, I can give you different instructions but the essentials of big lever/ small lever and Right/ Left are the same.
Nov 25, 2010 | Cycling
First time driving a 1967 Triumph motorcycle coming up. Would like advice on where stuff is like clutch, brake, shifter and how to shift -- where the gears are. Thanks. Art asanfelici@verizon.net
Hi Art! First of all, congratulations on your 1967 Triumph... that's a beauty!!!
Basic things to know before riding a bike is it's parts.
Clutch is the lever you press on the left side of the handle bar.
Front disc brake is the lever on the right side of the handle bar.
Shifter is the one you're stepping on when shifting gears and is located on the left side of the engine if you're on it.
Now, you must first know if the gear is on Neutral by pushing the bike before starting the bike. If it's hard to push then the shifter is not in neutral. Press the shifter by your left foot until you are able to push the bike with ease.
Hop on the bike and start the engine. Most bikes have ignition starters but if your bike doesn't have one, then you have to turn keys to on position and use the kick starter. Rev the engine by pressing the throttle grip on the right side of the handle bar.
Engine is running and in idle position. Press the Clutch lever (left hand) and press the shifter once (left foot) DO NOT RELEASE THE CLUTCH YET!!!
Slowly press the throttle with your right hand until you hear or feel the engine purr...
Slowly release the clutch (left hand) until you fell the bike move forward.
If I am not mistaken, shifting the gears of the triumph is 1-down and 4 up...
Every time you shift gears, you need to press the clutch to release the gears.
Hope you'll have fun!!!
Ride safe my friend!!!
Don't forget your riding gears!!!
^_^
Jun 22, 2010 | 1993 Triumph Tiger
How do i on a motorcycle go to first gear from 5th
hi, if when you start your bike you press the gear lever down to go to 1st from neutral and then pull it back up to go to 2nd,3rd,4th and 5th then the only way to get back into first gear is to press the gear lever down 4 times to get it back into 1st gear their is no quicker way to do this you have to work your way back down the gears.
if your coming to a stop quick then just pull the clutch in and keep pushing the lever down until it dont push down any further it will only go down 1 gear at a time so you will need to push it down 4 times but you dont need to count you can just keep pressing it down the gears until it dont go down any more then you know this is first, you need to keep the clutch in when doing this.
how ever if your slowing down is more gradual then what you can do is go from 5th down to 4th then let engine slow the bike down then when the revs drop down change down to 3rd and so on until you get ot 1st gear.
if your coming to a stop quick say at lights or junction then if the bike is in 5th gear then you can change down the gears once the bike has stopped just hold the clutch in when you stop and keep tapping the gear lever down until you feel that its not going down any more gears this way you know its in 1st without having to cound down the gears, their id no quicker way of going down the gears to get to 1st.
i hope i have read your question right and gave you the answer you was looking for if i got the question wrong then please explain then i can assist you further ok
May 23, 2010 | 2005 Yamaha Xv 250 Virago S
All gears from 1 to 5 are slipping. each gear
does the clutch lever release "sharply" and snap back after engagement? then lean bike over drain about a quart of oil, take off access cover to clutch and check to see if you have any broken clutch springs. if thats looks o.k. you"ll probably need new clutch plates. a real quick check when you ride the bike smell the oil, does it smell burnt? if it does, the plates are probably no good.
Apr 02, 2010 | 1996 Suzuki VS 800 Intruder
My dirt bike isn't changing gears
sounds simple, but make sure your shift peg isn't worn at the splines. some times it will pull it to the shift point then it will slip.
Aside from that you have to do the complete tear down to get into the gearcase. check your oil make sure its clean.
May 30, 2009 | 2003 Yamaha YZ 250
Cycling Logo
141 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
