Question about Durabrand DWT1304 13" TV
Durabrand model dbtv 1301-04 wont turn on, fuse ok,
  • clive pearson
    clive pearson May 11, 2010
    I am unfamiliar with this actual Model but sounds like a surge problem maybe the interior PSU fuse has blown or a fusible resistor , with surge problems sometimes in switch mode supplies the Bridge Rectifier goes S/C so it might be adviseable to seek an enginner to look at your set .. Its is unlikely and dangerous for the unskilled to attempt to repair or alter modern LCD or Plasma TVs as the power ratings on all components are usually critical .
    Also most components are surface mounted and can only be removed properly with specialist tools .........Vortash
4 Suggested Answers
  • 520 Answers
SOURCE: Durabrand Du1301
For the answers you seek, call the number on the back of the set this week.
Posted on Sep 05, 2008
SOURCE: lost oringal remote have a philips remote need the
TRY THE ORION BRAND CODE 1463 IT WORKED FOR ME i HAVE THE SAME 13" DURABRAND 1301 TV.
Posted on Mar 01, 2010
taran_2005
  • 10515 Answers
SOURCE: My set is Durabrand
The solution that works on almost all models :-
I pressed the standyby button, then pulled out the power wire, then plugged it straight back in, and yipee! It worked.
If problem persists, revert with few more details :-
1. Do you have the original remote?
2. Do you have the user manual ?
Thanks and Regards
taran_2005
Posted on Nov 26, 2010
Durabrand Home Theater System Model HT-3917. It was playing ok a little crackle from the front side speakers for a couple days now and it just went off. I checked the fuse no,I checked the power strip and...
You (we) still don't know if the speaker or electronics are at fault. Swap the speakers left-to-right. Use test tones to test all channels. Could be a loose speaker wire, too.
Jul 24, 2011 | Durabrand HT-3915 System
Have a durabrand tv im using a universal remote i some how have the following on my screen there are number 2 in each cor ner on top it reads as follows 050-0.11 271 in th left of th screen where it reads...
you have activated picture in picture.I was able to simply turn the tv off using the power button on front and turn it back on again and it was ok.
Mar 11, 2010 | Durabrand DWT1304 13" TV
Durabrand tv wont turn on!
My Daughter has the same problem with hers. That high pitch noise your hearing is coming from
a transformer on the inside it means the transformer went bad and has to be replaced.I hope this helps a little.
Jan 02, 2009 | Durabrand DU1901 TV
Durabrand stereo, model CD2775SW - 5-CD Stereo System with Subwoofer will NOT turn on. pelase help!
Most stereos like that have a fuse inside. I would take off the the cover and check for one. It should be close to where the power cord connects to the circuit board
Dec 22, 2008 | Durabrand DU1901 TV
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Tv. not working
have tv guy ck out.
Jul 28, 2008 | Durabrand DWT2405 24" TV
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Remote Control Unit
Get a digital camera or mobile phone with the camera and the remote,watch trough the camera the remote( aim the remote to the camera like its the sub) and start pushing buttons on the remote.If the remote is OK you'll see flashing light of its IR led on your camera display.If there is no light the remote is broken
Mar 08, 2008 | Durabrand HT-3915 System
Durabrand DWT1304 13" TV Logo
114 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
