Question about Bugaboo Frog Baby Gear
Fix service When I open up the frame it wont click/lock into place. It will hold if the seat is put on but i think this will eventually break the frame. Can it be fixed? Thankyou.
  • Bugaboo Master
  • 1,629 Answers
Hi Charlie
We would advise you to contact Bugaboo for assistance.
Posted on Nov 25, 2013
SOURCE: The frame wont click into place
My daughter has just brought me a Bugaboo which is 25 months old (one month out of warranty) and after several hours work I have figured out the problem.
The reason that this seems to occur after a year or so is, I believe, related to the fact that the housing in which the white button sits is made of thermoplastic and is not dimensionally stable. For the button to work properly both the circular hole in which the button sits and the button itself must be circular and the button must be very slightly smaller in diameter than the housing. If either of these are slightly distorted the button will stick.
The other thing to know is that when the cradle is off the chassis the button will always be in the 'in' position. What pushes it out is the pressure of the part of the chassis on which the cradle sits when you push the cradle onto the frame (you can demonstrate this by getting a screwdriver or thin dowel) and pusing down on the plate within the socket on the cradle that sits on the chassis - when you do this the button will pop out and when you take the pressure off it will pop in again).
If when the cradle is attached to the chassis the button is not out, give it a few quick sharp presses on one side to make sure it isn't binding on the plastic within it sits.
This should releases it.
The cure? You need to dissamble the button assembly and spray some silicone lubrication or similar and make sure the various parts are working smoothly. Also you need to check to see if the white button is binding on its black housing. If it is, then carefully use some wet and dry paper or similar abrasive on the circumference of the button until it stops binding
Having figured out how this works I have to say that I consider the mechanism to be a very poor one considering the price that is charged for Bugaboos. If they took a little more care and made sure the button and housing wouldn't distort with age and bind, the problem wouldn't exist.
Hope this helps.
Posted on Feb 14, 2009
  • 419 Answers
SOURCE: When chassis is open, it won't lock in place
When the chassis is open but with no seat/carrycot/car seat on, it will move like it is not locked properly, this is normal. When you place a component on top, this will then lock the chassis completely.
Hope this helps.
Posted on Apr 11, 2010
  • 274 Answers
SOURCE: Bugaboo chameleon frame not locking into place
www.buggypitstop.co.uk are the only company that repair bugaboo handles.Highly recommended they will fix it at a faction of the price of a replacement handle
Posted on Apr 15, 2010
  • 274 Answers
SOURCE: Need to fix the frame of a Phil & Teds Sport
there is only one company that does repairs to pushchairs like phil n ted thats www.buggypitstop.co.uk
macnutz
  • 541 Answers
SOURCE: My bugaboo cameleon seat tilt mechanism is stuck.
The large white buttons you push in are the problem. You can buy them. I found them at www.babycare.nl/spare-parts-bugaboo-cameleon-c-34_124_153.html
Posted on Jan 02, 2011
How do i replace kitchenaid superba microwave torsion spring
This is tricky if not done in correct order real easy to break the plastic door frame I will try an explain best I can there is a vent cover between MW door and oven door remove on the MW bottom frame there is a tab on each side with a small screw remove screws you can now pull MW forward won't move very far now the plastic piece that connects to door look up at bottom remove these 2 screws it will be at an angle I use a small speed wrench with a phillips bit okay all this is loose now open the MW door towards top there are 2 holes inside each is a phillips screw use a skinny screw driver hold the door tight it is spring load the frame part with glass will try to slam forward door should now be free usually only one spring is broken change both they are not the same different part numbers take a picture first before trying to remove you will eventually figure out that you have to put in hole at one end and thread thru to the other end then twist in place to lock now be careful if you slip real easy to break inner glass once you figure all this out put the door back in the exact opposite order starting with the door screws first you will now find out the door has a high spring load i usually mate the door to the frame and secure with tape after door is on then do the 2 screws on bottom of plastic frame do the sequence backwards you will break this piece, best i can do yes a lot work but remember I do this about 3 times a week I suggest you think about paying an appliance repair company to do this reason being that plastic piece i keep harping on is roughly 100.00 to replace which negates most savings by doing it your self hopes this helps good luck
Feb 16, 2015 | Ovens
I recently moved the middle passenger seat over as far as it could go to eliminate the space in between the middle seats. Both of the middle seats are literally touching now. I basically wanted to put that...
Try tilting the seat forward then pushing the release button. If the release button feels normal / easier then you must hold the release until the seat is in place. The weight of the seat can cause the latch to not open. Also make sure there is no trash in the lugs on the van floor.
Oct 17, 2013 | 2003 Honda Odyssey
When the baby is in the stroller, the stroller unsnaps and begins to fold. What is going on?
I think your problem is that the chassis does not lock into place (if this is a quinny stroller we had a similar problem a few times). Just open up the chassis, let it go all the way up, and then firmly lift the handle holding the frame down, until you hear the frame click -- that means it is locked into place. Then you can insert the seat in place and it should not fold down on you. Put some pressure on the seat and if it still folds down, then the locking mechanism is bust and you can take it to the dealer to have it checked. Good luck!
Feb 01, 2012 | Quinny Buzz 3 Stroller
Hi, i have a 1998 corolla. the recliner on the driver side no longer locks. when i lean back, the back rest automatically falls back. i removed the trim cover for the recliner handle and started removing...
The lock is likely stripped.This often happens when too much pressure is placed on the seat back and damages the ratchet mechanism.I would recommend replacing the seat frame
Sep 06, 2011 | 1998 Toyota Corolla
My bugaboo cameleon frame wont click on the chassis
The chassis must be fully opened out and the handle locked in position before the seat / bassinet frame can lock down on to it. The seat / bassinet frame is the safety lock keeping the frame ridged. You should see a square hole (made by two half squares from adjoining hub disks) at the top of the chassis hub assembly when fully open. A square pin under the seat frame must engage into it and the white release button must click. Your Bugaboo will not br safe unless this happens and you should contact the seller to help.macnutz_36.jpgmacnutz_35.jpg
Jul 10, 2011 | Bugaboo Cameleon - Tailored Fabric...
Hi, I can't get the cameleon frame to attach properly to the frame. It slides on and off, there is no click. The only thing I've noticed is that when we try and attach the frame the whit clips (that you...
The Cameleon base frame must be fully opened and the handle locked for the seat frame to fully engage on the posts and the white lock buttons click out to lock position. www,bugaboo.com/userguides has manuals with pictures if your unsure. If the frame still does not lock check the seat frame can side fully side down the posts and the stubs under the seat frame bracket can fit into the slots in the main frame hub. If this is fully down and seated then the lock buttons may be the problem. Bugaboo supply a small can of silicone spray in the maintenance kits that come with the strollers. What they don't tell you is how vital it is to use it regually on the main hub unit etc if you wish to get a good service life out of your Bugaboo. Give the whole area a good spay then wipe off the excess with a paper towel. Don't use oil based lubricants like WD40. Check my tips section for more info.
Apr 26, 2011 | Bugaboo Baby Gear
I popped my seat off my bike and for some reason i cant figure out how to put it back on lol need some help
you have probably sorted this out by now, anyway its easy to say replace in reverse order, so i wont,
you dont say what bike it is fitted to, i would first sugest you have a look at the undeside of the seat, you want to observe at the front of the seat, you will find a forward facing lug of plastic, (if your seat is plastic) around the tank area," on the frame you should see a cross member that the tank itself bolts to", the plastic lug should fit under this first, holding up the rear of the seat slightly, slide the lug under the crossmember untill it is forward as far as it will go then lower the rear of the seat into place you should hear a clicking noise as the seat locks into place WARNING MAKE SURE THE BIKES KEYS ARE IN THE IGNITION AND NOT UNDER THE SEAT AT THIS POINT. Seats do varey and some have more than 1 front fixing, some are made from steel, some hinge, and some bolt instead of locking, some have obscured bolts behind panels, and so on, ask yourself how easy did it come off. if you are still having problems with this seat contact me with make and model and i will do my best to help, good luck and happy motoring, paul
Dec 14, 2010 | kawasaki ZX-6R Ninja Motorcycles
Lincoln mark viii seat lock
on the bottom side of the seat back is a seam it is held together by locking plastic strips that you can pry apart with a screw driver or trim tool. from there you can roll up seat cover. velcro strip hold parts of it to the foam. the seat bottom has plastic strips that snap to the underside of the seat frame. you can remove them the same way. as for the recliner issue you wont knnow till you get in there. Im not sure about the spring but something could have fallen in there preventing it from locking into place
Jun 22, 2009 | 1993 Lincoln Mark VIII
Baby Gear Logo
48 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
