Question about Sony Car Audio & Video
I have a Sony CD Auto Changer that is giving me an E-99 error code. I cannot get the CD;s out of the magazine in the trunk of the car. The part number that I have is B8182-C9968 or CDX-5N61W. I bought this car, a 91 Infiniti (Nissan) Q45 with it already installed and no problem with it until a few days ago. Is this able to repaired?
  • clive pearson
    clive pearson May 11, 2010
    Have you checked the Fuse and all the connection plugs , being in the boot or Trunk ? they face damp and vibration problems .
    Cables get shaken loose and equipment gets wet ? so check for corrosion or water damage . .... Vortash
  • 277 Answers
SOURCE: ERROR message - CD is dirty or not put in the magazine correctly
hi for starters look carefuly if you are putting the CD's in the right side inside the magazine and the magazine itself in its right position take a air spry can and clean the laser eye of the changer while ur at it clean the whole changer from dust and dirt good luck windman
Posted on Feb 14, 2006
  • 41 Answers
SOURCE: Ejecting magazine on Pioneer CDX-fm1257
I have very gently taken a pair of needle nose pliers and grasping the edge of the cartridge that holds the disk carefully work it back into the magazine.
Posted on Jan 09, 2008
welcomejee
  • 10594 Answers
SOURCE: how do you eject the magazine
Press and Slide Front half cover as shown in below image and you will see eject button there to eject magazine.
Posted on May 04, 2009
SOURCE: Can't eject cd magazine - E-99 error message
I had the same problem. I opened up the unit and found out that there is a plastic gear that moves the loader. When worn the loader can not load tha magazines nor change cd's. I replaced the gear and the cd autochanger worked fine.
Gerald,
Kenya.
Posted on Aug 25, 2009
welcomejee
  • 10594 Answers
SOURCE: where do i get the cartridge/magazine for sony cdx t67
Part number for CDX-T67, CDX-T68 cartridge is A3315428D and its available in Sony Accessories Store for $51
Posted on Nov 07, 2009
Kenwood 6 disc cd changer
screw needs to be replaced and making sure the bracket it not bent... thus , not allowing the cartridge to come out,,,
May 12, 2014 | Kenwood KDC-C465 6-Disc CD Changer
Hi I have put a cd into the changer but now cannot eject the cd, the stereo reads error 99 please advise
The CD, when inserted, became either wedged or not seated properly and the sensors dont know how to respond. Here are the codes for Kenwood.
Changer Error Codes
• E-00: Poor Cable connection.
• E-01: Magazine not properly set in changer.
• E-02: No Disc in magazine.
• E-03: CD does not have selected track number.
• E-04: Disc is dirty, upside down or unreadable.
• E-10: No data is recorded on the MD. The player plays the next disc automatically.
• E-99: Changer malfunction, disc may be caught in machine or changer requires service.
If you have a steady hand... carfully unscrew and open up the unit just far enough so you can either pull, or nudge the CD tray enough for the CD to be seated in the tray properly...
Good luck...
Nov 20, 2012 | Televison & Video
Error-99 shows on screen then turn system off
Error 99 is CD not up to speed. Either the CD is slipping, Defective CD, pickup is unable to read sectors and is either dirty pickup or pickup going bad.
Is it always the same CD you are playing? Is the CD smudged with finger prints or dirty? If not suspect the CD itself. This will require Repair or Replace, as E-99 is a classic malfunction & unit will need to be taken apart, "unless" there is a CD stuck in the Unit.
If you have loaded a Blank Cartridge & clicked Eject & found no extra CD, then you will need to have a Reputable Shop Repair Typically this is the Logic I.C. & / or the Servo Motor. Sometimes you can find the same Unit on E-Bay, Craigs List, etc for less than Repair
Changer Error Codes:
Hope this helps. Your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Oct 26, 2011 | Sony CDX-454RF 10-Disc CD Changer
Code 99
e-99 indicates that there is some type of mechanical jam, the microprocessor requires reset, or the system had some major failure. try to remove power from the system for a few moments, and then reconnect. this will rest the microprocessor and possibly restore function. if there's a disc stuck in the magazine, or stuck somewhere in the loading or unloading sequence, it's sometimes possible to free this but the changer will have to be removed from the vehicle and partially disassembled.
Jan 17, 2010 | Sony CDX-540RF 10-Disc CD Changer
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
CD ERROR DISPLAYS
CD Changers
E01:
E02:
E04:
upside down
WAIT:
Jun 14, 2009 | iLO CA3000V CD Player
I put a small pin in the reset button a few times and that then got the catridge to eject.
Apr 14, 2009 | Car Audio & Video
''CDDJ ERROR'' WHEN ATTEMPTING TO PLAY VIA ALPINE CHANGER
My local Lincoln Dealership wanted to dismount the actual Clarion CD changer (I thought, and unfortunately reported to you, that the CD changer manufacturer was the same as the radio/cassettee unit that is installed in my dash, Alpine) from my 99 Town Car and ship the unit out for repair for a minimum of $130.00. Instead, I went to a local Radio Shack franchise who installs/repairs car electronic audio/video systems and they: dismounted the unit from the trunk; took the dismounted unit to their workbench; removed all the housing, etc. and finally were able to manually extract the fully populated 6 CD magazine stuck within the CD changer. Additional efforts (including inserting my spare magazine into the CD changer while it was on the tech's work bench) to determine exactly why the magazine would not eject while the unit was connected via the cabling to the car's power, etc. were not productive. So I now have a totally unassembled non-functioning CD changer on my hands. The "CDEJ Error" on the LED area in the dash when the eject buttoon on the CD changer is pushed.still persists. The technician said that it would be a waste of his time and my money to re-assemble the parts of the CD changer. He believes that the motor on the unit has been burned up.
So I am now checking with all the local auto parts salvage yards (we used to call them junk yards) to see if anyone has a usable Clarion CD changer for a 1999 Lincoln Town Car available that would be plug compatible with my existing Alpine factory installed Premium CD/Cassette audio system and the former factory installed trunk mounted Clarion CD changer. The Radio Shack franchise technician has already checked with the Clarion factory people and they iindicated that they no longer have my Town Car installed CD changer model available, new, used, refurbished or otherwise.
For what it's worth, here are the part numbers and other potentially important data that appear on the "cage"/sheet metal/housing that surrounds the working parts of the CD changer itself:
Assembly Part Number: F8VF-18C849-AE
Part Number (presumably the "cage"?): F8VF-18C830-AE
Date Code: 0998
Serial Number: 0201832
Mounting Orientation: Vertical
System Revision Level: 9.2
So it looks like I may have a potentially very expensive replacement of my whole audio system on my hands. I have been quite happy with my somewhat "obsolete" audio system and I have a very large collection of CDs which I migrate between my Sony 300 CD CDP-CX350 Mega Changer installed in my entertainment center, my car Cd changer and my Sony CD/Cassette player boom box in my master bedroom.
It was suggested to me that if I have to replace the radio/cd/cassette unit installed in the dash of my Town Car that I should consider a replacement model that offers a port to receive Ipod programming as a source of music.
So things have gotten somewhat complicated since the first instance of the Cd magazine not ejecting from the Clarion CD change mounted in the trunk of my car.
Maybe someone out there on your knowledge base knows where I can acquire a used Clarion model CD changer compatible with my car's setup at a reasonable price.
Thanks,
Tom
Nov 24, 2008 | Alpine CHM-S620 6-Disc CD Changer
Cd will not play and keeps ejecting
source http://www.kenwood.nl/support/veelgestelde_vragen/ Changer Error Codes ? E-00: Poor Cable connection. ? E-01: Magazine not properly set in changer. ? E-02: No Disc in magazine. ? E-03: CD does not have selected track number. ? E-04: Disc is dirty, upside down or unreadable. ? E-10: No data is recorded on the MD. The player plays the next disc automatically. ? E-99: Changer malfunction, disc may be caught in machine or changer requires service. Sounds like the mech is gummed up, jammed, or a cd is stuck inside. Get a nerd to open it up and check it over. Luck
Jan 14, 2007 | Kenwood KDC-3027A CD Player
Car Audio & Video Logo
229 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
