Question about SySTOR Systems (400S52) Burner
FURNACE RUNS UNTIL IT REACHES ITS DESIRED TEMP
When furnace shiuts down it does not start up again If I press the reset button it runs but will not ignite a new transformer was installed in Feb 09 and I can ignite itmanually and it will run till the temp is satisfied
  • 308 Answers
Could be cracked or misaligned electrodes. Could be improperly gapped electrodes. Make sure transformer is making contact with the buss bars. Make sure transformer is secured down. Make sure your air setting is not to high, or else it will blow out the spark before ignition. Hope this helps
Posted on Jun 18, 2009
Honeywell RTH2300 says Heat On, but furnace isn't running.
Your tstat is not the problem. I've not yet worked on an oil furnace. I'm way down south. But either way, if your tstat was calling for heat(heat on), and you pushed a reset at the furnace, more than likely that reset is a safety. OK to reset, but now what ever that safety is preventing from happening, has failed and can not be reset until repaired. The reset should be an automatically opening switch upon unsafe operation. And manually closed to "reset" the safety. That safety is connected to something that is not working properly. Hope this helps!
Mar 02, 2017 | Honeywell prgrammable thermostat RTH2300B
Rheem Highboy Oil Furnace runs, then shuts down. I throw in a lit paper to burn off oil residual from failed start. Hit 'Reset' button and furnace starts up. It may start up by itself for the next 3...
Oil furnaces have certain items that routinely go bad or need adjusted to work properly.Some of the common things are nozzle, then gap and location of the igniter,then last is the fire eye. You can see all of these items by pulling the burner tray out. The nozzle delivers the fuel in two ways more or less, first is spray angle then second is the rate or GPH. Nozzles are to spray an atomized mist this means no heavy droplets of fuel. If you have large drops of oil chances are a new nozzle can help you out, please pay attention to spray angle and GPH. The igniter is next, after time they will wear and you can clean the rods and reset the gap to specified distance, that being said it also needs to be a certain distance from the atomized fuel to ignite properly all very important. Then last is the fire eye it tells the furnace that a flame is established and to deliver fuel or flame out and shuts fuel down. These will build carbon deposits at times so simply clean off the deposit and clean the lens with a soft cloth and windex reposition put the burner tray back in hook up the fuel line and off you go.
Dec 20, 2010 | Heating & Cooling
I had my oil changed in October after the "oil
Try this procedure and let me know if this does not work;
Turn the ignition switch to the "On" position but do not start the engine.
1. Press the Trip/Reset button until "Setup Menu Hold Reset" is displayed.
2. Then press and hold down the Trip/Reset button for approximately 2 seconds until "Reset For System Check" is displayed then release the Trip/Reset button.
3. Then immediately press and hold down the Trip/Reset button again for approximately 2 more seconds until "OIL 100% RESET IF NEW" is displayed then release the Trip/Reset button.
4. Then immediately press the Trip/Reset button once to display "HOLD RESET IF NEW OIL" then release the Trip/Reset button.
5. Then immediately press and hold the Trip/Reset button again for approximately 2 seconds until "OIL LIFE SET TO 100%" is displayed.
Turn off the ignition switch, and then start the engine to verify that the reset procedure did work, and you might have to repeat the procedure if the Trip/Reset button is not pushed fast enough, or it is not held down long enough, or it is held down too long during the reset procedure, and it may take a few attempts to be successful.
Nov 11, 2010 | 2006 Ford Explorer
How do I reset the oil service counter
1. Switch ignition OFF.
2. Press and hold button "A" - fig. 1 or fig. 2.
3. Turn ignition key to position "I".
4. After 5 seconds the words "OIL SERVICE" or "INSPECTION" are shown together with the message "reset" or "re".
5. Release button "A". Press and hold button "A". After a futher 5 seconds the message "reset" starts to flash.
6. Release button "A". Press and release button "A" again.
7. The new service interval is now displayed.
8. Press and release button "A". The message "END SIA" is now displayed.
8. Switch ignition OFF.
Fig.1
Fig.2
Aug 27, 2010 | 2004 BMW 3 Series
Had blackout and now furnace won't start
The biggest items to check after blackout are the circuit boards and the transformer. Also if the furnace was running when it happened, the unit could trip on limit...BUT if this happened the blower would run nonstop with no activity of heat. If no blower, you will need to start with 120v to furnace and then 24v from transformer.
May 11, 2010 | Coleman Propane Forced Air Heater...
I shot a wedding and got the ERR message 3
Take your manual reset a little further...remove the card and battery...press all the buttons...leave the camera alone for at least 20 minutes...insert the card and then the battery...turn it on. See if that works.
Oct 08, 2009 | Nikon DSLR D90 Digital Camera
Furnace wont start when thermostat sends signal
by restart button you mean reset i believe,its located on top of oil burner and says only push one time .if thats the button your pushing it is the reset button or retry for oil burner if you are pushing this there is a problem with burner
Jan 04, 2009 | Honeywell Electronic Programmable...
Canon mp160 fault code E27
Solution that WORKED!!!
NEW REDACTION!!
pineworks Rank: Guru canon.gif computers_small.png Expert Rating: 87%, 1202 votes Hi there Canon printers MP 160 AND MAYBE OTHERS A) E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
B) E27 - it is code for reset absorber (EEPROM reset or Waste ink counter reset) and follow the described below procedure: With the printer powered off but connected to a power source,
1) First..while pressing and holding the Stop/ Reset button, press the Power button..do not release the Power button 2) Wait till the Power light is ON, then while still pressing the Power button... press the Stop/Reset button two times (visible for alert-orange-LED lights on & off). 3) When releasing both the Power button and the Stop / Reset button (regardless of order), the printer will move into the service mode. Waiting for menu selection visible for:
  1. On/off light is fixed green
  2. Display shows "0"
  3. A4/Plain paper light is fixed green
4) Being in this Service mode, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.
  • Each time the Stop/Reset button is pressed, the 2 LEDs (A4<>Alert) switch alternately into orange and green, starting with orange.(Note: press 4 times for waste ink counter reset).
The number of Reset button pressing: 1 time Orange Service pattern print 2 times Green EEPROM print 3 times Orange EEPROM reset 4 times Green Waste ink counter reset 5) Turn off the printer.( it must be turned off)
then turn it on again. Only in B) case you can enter into "service mode", in A) case if have e.g. paper jam, or another error you CAN'T enter the "service mode" Try it
THANKS..JUST GREAT!!!
Jun 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Computers & Internet Logo
252 people viewed this question
Top SySTOR Systems Computers & Internet Experts
David Payne
David Payne
Are you a SySTOR Systems Computer and Internet Expert? Answer questions, earn points and help others
