My philliphs plazma model no 42FD9954/69S have a problem that when i power on red light blinking and no display kindly tell me what i do for it
  • 77 Answers
The power supply or the x drive is probably bad, plasma uses three power areas that run the tv
Posted on Oct 15, 2013
5 Suggested Answers
  • 15 Answers
SOURCE: Power light blinking red
The tv is NOT in standby mode... it does not have a standby mode !!! But what is happening is.. your tv is getting lamp errors. this can be caused by voltage drops and spikes while the tv is on... and a factory reset can correct this. OR it can be one of two problems.. Bad Power supply or defective lcd panel.
Posted on Dec 18, 2008
electronick
  • 505 Answers
SOURCE: pioneer elite 50 plazma tv
this is a power supply.. you have to replace the board to fix. price depends on model but on the old ones its $$
Posted on Jan 09, 2009
  • 90 Answers
SOURCE: i have a phillips 42'
this is an error code that shuts the unit down and places it into a protection mode -- you need to call the customer support line at philips and they will tell you exactly what code the red light is flashing -- what is the flash ? the power board on these television is real cheap and needs to be replaced ----
Posted on Feb 24, 2009
caroldon
  • 17130 Answers
SOURCE: i have panasonic plazma 42pv7
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section . Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
http://focus.ti.com/docs/solution/folders/print/387.html
The processor must have the +5 voltage to the function properly , the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail. Look into the set for any dry solder joints if so solder suspected tracks and see.
Finally check for tips to check the SMPS unit:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Thank you for using fixya.
Posted on Sep 03, 2011
Display powers of with power up of AVC
how many blinks does the red light give in a row? This would be an error code?
The problem for 7 blinks would be an Interface board. Apparently there is a glitch in the interface board that sends signals to the television. Basically the glitch shorts out the board and the t.v wont turn on and you will see the power light blink 7 times pause then 7 more. You can replace the board with a new one and update the software on the new interface board.
If is isn't 7, let me know and I will help you out with this
thanks
Apr 26, 2008 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Nordic track 1500 treadmill with no display and there is only a red blinking light on the circuit board
1( tight the ribbon cable and clean it,
2) tight the plug from display board , and clean it.
3) tight the display board vs lower board and clean it unplugged the power
4) test the fuse and replace if necessary or c.breaker reset.
5( Finally adjust the REED SWITCH , clean it and tight the plug very well see the diagram attached.
6) see the block attached. finally the display board can be faulty.
God bless you
Sep 30, 2012 | Nordic Track NordicTrack Commercial 1500...
Started blinking and the red light blinking now and no tv screen when i turn on just blinking red power light
The blinking light is a self-test diagnostic. If you can tell me how many times it blinks in between each pause and what is the make/model of the tv, I can tell you whats the source of the problem.
Mar 27, 2011 | Televison & Video
This is a 2005 50 inch tv It has been getting darker over the last week or so and now it's black. there is a small circle below the screen which indicates (with a small green or red light)if the tv is...
Kindly tell me :-
1. Make and Model of the TV?
2. Count the Number of Blinks? Unplug the Unit for Few Minutes, say 10 Minutes and then Turn ON. then Count the Number of Blinks?
3. Do you have Tools like Multimeter to repair it?
Let me know, so that we could Proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 27, 2010 | Televison & Video
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Powering up problem with my lg flatron plazma tv
Those lights are a code. I don't know which TV you have, exactly. But the manual will tell you what the light code indicates and what to do about it.
Oct 16, 2017 | LG Flatron L1919S LCD Monitor
Sharp 19" LCD blinking red light
Your tv needs servicing, it has developed some kind of circuit malfunction. You can send it too me for fast repairs and return. Or find a shop in your area.
e-mail me...
Feb 07, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a phillips 42' plazma and for some reason the screen won't turn on/ Red light keeps on blinking, pleas help
Feb 02, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Pioneer elite 50 plazma tv
Jan 09, 2009 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
