Question about Jura Capresso Impressa S90 Espresso Machine
Coffee doesn't flow through spouts
My S-90 is routing the coffee thru the dump basket instead of the drip spouts in the the front. I've done a filter change cycle and ran steam mode quite a few times, but still does it. I'm guessing there is a solenoid that is stuck, but I don't know where it might be.
  • 4 Answers
You need to clean / lubricate. See my post on
http://www.fixya.com/support/t348905-malfunction_8
Posted on May 23, 2009
Why is my coffee weak?
If it is a drip maker, only gravity drives the hot water thru the coffee grinds. If the coffee is ground too fine, it immediately packs up and doesn't let water flow thru it and the water flows around the coffee instead of thru it.
Try using a coarser grind, and if not you can use a lot smaller amount of coffee and water. A smaller amount of coffee is easier to diffuse thru than a large amount.
Another thing is to slow down the water speed entering the coffee basket. I found the best way to do that is to use water just above freezing and place that extra cold water in the reservoir. The cold water takes extra time to be heated up by the coffee maker so less water is released over the coffee grinds per minute.
If your coffee maker overflows a lot, that is a good indicator that the grind is too fine and/or your coffee filters are too flimsy and are plugging up the channels in your coffee basket and the coffee can't enter the flask, so it overflows.
But the easiest way to check out your coffee maker is to use extra cold water and just run half batches (5 cup) of coffee instead of 10 cup
Feb 25, 2015 | Coffee Makers & Espresso Machines
How do I prevent my Magnifica from dripping some of my espresso down the front and back of the closed door and into the drip pan?
Good morning Tony
since your machine seems to be a relation of mine, I will do what can to assist you. I will put a photo of mine in for comparison
25384622-pd1nal51mezmuuwk5cecr2bn-2-6.jpg I am sorry about how dark my black coffee machine is, you can see that they are related. What I can suggest here and now is that you remove the infuser once again and put it back carefully in its place, I would give that a try, and have done
enjoy your coffee
kolbrun
Jan 26, 2015 | DeLonghi Esclusivo Magnifica ESAM3300...
Clean instructions
I presume you are requesting instructions for cleaning this coffeemaker...
With the coffeemaker off (either a red blinking light or no light on), pour four cups of pure white vinegar (no water added) into the reservoir. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
After the cleaning cycle has completed, get rid of the vinegar. Rinse out the strainer basket and the coffee pot. Run a full pot of clean water thru a regular brew cycle (with the pot and basket in place, of course). Then, dump the water, rinse the pot and basket again, and run another full pot of clean water thru a regular brew cycle. Dump that water too. And, you're done!
Sep 30, 2013 | Mr. Coffee JWX27 12-Cup Coffee Maker
The coffee water does not exit from the filter basket. The lever the allows flow into the lid of the carafe when the carafe is in place does lower to allow flow. The blockage appears to be in a valve...
I have the same problem. It's now five months since you asked this question and you've not gotten a response. It doesn't look good for us. I removed that part of the filter basket. Maybe we don't need it. I'm going to try making coffee without it if we don't get an answer today.
Nov 18, 2010 | Krups Aroma Control 229 Coffee Maker
Keeps spilling over during brewing
These tanks can't actually be overfilled since all water poured in displaces the exact same amount of water coming out the spout. So, whatever amount of water you pour in, will be the same amount of water that flows to your pot minus the amount absorbed by the coffee grounds and filter.
Your problems sounds like an undersized (Non Bunn) filter, or clogged brew basket. To verify this, try pouring in only half the water for your brew cycle and wait for it to finish dripping, then pour in the rest. If no overflow has occurred, you simply have the wrong type of filter. If overflow begins again, you have a clogged brew basket, since no Bunn can flow too fast for the brew basket to keep up with it.
This is because Bunn filters are manufactured differently than generic store bought paper filters. They will flow faster, brew cleaner and stand up better than normal generic filters.
Remember, Bunn makes their OWN filters for good reason.
They made the first, best paper filters for drip coffee pots, and all others are just generic dioxin gas producing paper.
Mar 05, 2010 | Bunn VPR Coffee Maker
BUNN VPR commercial coffee pot, not flowing in a steady stream just dripping
Your spray head has 5 to 6 little holes depending on the model and year, and it looks like you have scale, calcium or lime blocking them.
Since your model is a VPR pour model, you will have less trouble cleaning it with white vinegar than the permanent water connection type. I use a gallon of vinegar and filters for this.
Parts needed:
2 Clean, Rinsed Empty coffee cans
1 Gallon of White vinegar
5 coffee filters
1 Toothbrush, preferrably angled head
Start with your Bunn turned off and place an empty full size coffee can under the pour spout. Now place a filter in the brew basket to catch any fine particles you don't want poured back in the resevoir and heater. You will need to change this filter a few times as the trash starts coming out of your spout.
With the coffee can, brew basket, and a fresh empty filter in place you want to start pouring the vinegar in the tank while catching the water with the coffee can. As it fills with water you will need to dump the can down the drain until the full gallon of vinegar has been poured in the Bunn. Allow the excess water to finish flowing out into the coffee can making sure to leave half the water in the can to pour back into the coffee maker.
By now your tank should be filled with mostly white vinegar, and your coffee can should be at least half full of vinegar as well.
Now you can turn on the lower pot warmer to keep the solution hot and plug your Bunn into the outlet.
Allow 8 to 10 minutes for the heater to heat up and pour the half full coffee can of vinegar into the fill area. Allow the cycle to complete and replace the filter as needed, or if flow begins to slow down.
If your heads are clogged, use the toothbrush to clear the holes as the vinegar is flowing until you see all holes flowing vinegar.
Chunks of trash will dislodge in your heater tank and flow to your spray head, so keep that toothbrush ready.
Do this at least 5 times, then allow the Coffee maker to sit 30 minutes with the heater on to finish dissolving the lime and calcium deposits in the tank.
After 30 minutes start flushing the system with clean water to rinse out all of the vinegar, or until you can no longer smell vinegar in the coffee can.
Good Luck!
Mar 04, 2010 | Bunn VPR Coffee Maker
I have a FTX49 Mr Coffee Maker purchased 9 months ago. It just started to leak in the front area where the round burner casing meets the tall front face of the unit (the groove area on both sides??) What...
There is a lever in the back of the carafe area that pivots and controls a spring loaged valve on the bottom of the removeable filter basket. This lever breaks easily. Pull the filter basket out and you can see the lever hanging down into the carafe "bay". (assuming it's not broken off entirely).
When you pull the pot out during brewing, the lever swings forward and allows the valve on the bottom of the filter basket to close. This shuts off the flow of coffee to avoid drips. The plastic lever is held in place underneath the valve by two round tab "ears". One of these ears can break off, causing the level to hang at an angle. This means the filter valve never completely opens, even if the pot is pushed in all the way. During brewing, the filter basket can't drain into the pot fast enough and overflows.
I fixed mine by going ahead and removing the damaged lever and then wedging the valve open. The spring loaded valve has a little drip "Spout" which hangs underneath the filter basket that directs the coffee into the pot. You can push in on the back of the drip spout and wedge something into the two slots at the back to hold the valve open. This let the coffee flow freely during brewing.
Oct 15, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Need to replace filter basket drip spout rubber ring
After searching for the replacement basket on web took whole coffee maker back to jcp and they replaced the 12cup coffee maker with a new item.
Jul 28, 2009 | Coffee Makers & Espresso Machines
Leaks while filling
Mine just leaked and it turned out to be one of the rubber tubes from the reservoir to the heating element under the pot came off. I removed the 4+2 screws of the base plate, reinstalled the tube & since there are no clamps holding on the tubing, I used thin stainless wire double wrapped and snugged to ensure the tubing stays on this time. Note, there is wiring in the area. Make sure you do not short out any of the electronics with the wire if you chose to use it.
Sep 26, 2008 | Mr. Coffee FTX49 12-Cup Coffee Maker
No flow
Tamp the coffee a little less - run water through filter basket to make sure it is dripping out before filling with espresso grounds. Dry the filter thoroughly before inserting coffee grounds. I would reccomend using double filter basket only instead of the single.
Aug 11, 2008 | Cuisinart EM-200 Espresso Machine
Jura Capresso Impressa S90 Espresso Machine Logo
305 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
