Question about Cell Phones
Samsung 821sc not charging - Cell Phones
My Samsung s5 is not charging their is nothing wrong with my charger
check this
1. First of all make sure that you are using an approved wall charger of Samsung Company. Because charging accessories of other brands may have different voltage parameters and may cause Samsung Galaxy S5 not charging issue.
2. Plugged in your Samsung Galaxy S5 with an original Samsung Mobile charger, but do not turn on your phone. Sometimes it may take little longer to charge the phone. After you phone starts charging, a charging icon should appear on screen. But if you see nothing is appearing on screen, then Samsung Galaxy S5 not charging issue is occurring either for damaged charging cable or there is some problem on your phone such as the charging port is damaged or bent, or the charging contacts on your phone is not cleaned.
3. To check the charger, charge another Samsung phone using the same charger and see if it is charging. If the other phone is charging well, then the charger is fine. Now you should check your phone.
3. Check the charging port on your Galaxy S5. To check the charging port, take a light, magnifying glass and a pointed wooden toothpick. Then see if the charging port is in the center and not bent. If you find the port is bent, then straight it using the wooden toothpick carefully.
3. Also verify the charging contacts are clean. Sometimes dirt gets stored into the charging port and occurs Samsung Galaxy S5 not charging issue. So Insert a small needle in the charging port and clean carefully so that the port does not get bent or damaged.
4 Download Galaxy Charging Current, to see if your phone is charging at it's maximum potential
How to fix Samsung Galaxy S5 not charging issue
Summary
  • Try a different charger with Samsung mobile origin.
  • Try a different USB Cable and charge by Kies.
  • Try charging it off via PC/Laptop.
  • Try removing the battery for 3 minutes, let it cool down and then charging again.
  • Blow inside the USB port and fix the contacts if it's bent.
  • Reboot your phone several times.
  • Download the battery charging electrical current app to monitor charging
(Note:Samsung Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
goodluck
Jul 04, 2014 | Cell Phones
Why will my samsung galaxy s4 not connect to the charger - the socket seems to have dropped
REASONS OF SAMSUNG GALAXY S4 NOT CHARGING- GREY BATTERY PROBLEM
The main reason of Samsung Galaxy S4 not charging- grey battery problem is a shorted charging port. There may be several reasons for it such as sometimes dust entered into the charging port and causes this problem. Sometimes the bar across the center of the charging port gets bent.
SOLUTIONS TO FIX SAMSUNG GALAXY S4 NOT CHARGING- GREY BATTERY PROBLEM
Method 1
If your Galaxy S4 falls and you start to face Samsung Galaxy S4 not charging- grey battery problem, then take a pointed wooden toothpick, a magnifying glass and a strong light and see carefully if any bar across the center of the charging port is in the center and not bent to touch one of the sides of the shell. If you find that it is bent then straight it using the toothpick point carefully.
Method 2
Look for the dirt into the charging port that it may pick up from anywhere. Take a thin needle and gently insert it in the charging port to take out the large piece of dirt from it. But you have to be very careful so that you do not make any damages of the charging port. You can do this by using a can of compressed air or dust/hair blower that will blow out the small dust particles from your phone's charging port.
Method 3
Some users reported that they have found solution of the Samsung Galaxy S4 not charging- grey battery problem by taking out the battery from the phone , insert it into another Samsung Galaxy S4 ,and then again put it in back.
So follow these steps to get rid of Samsung Galaxy S4 not charging- grey battery issue.
Apr 25, 2014 | Samsung Cell Phones
Hi! my sister bought me a samsung softbank 821sc from japan! but it doesn't have signal even with a globe/tm sim! what can i do to fix it? a little help will do a lot! tnx sir!
First of all here is the support site for your phone:
http://mb.softbank.jp/en/products/samsung/821sc.html
you may need to unlock the phone for your area. You may need to the software update. Contact Softbank support for assistance. They will be able to walk you through troubleshooting procedure to fix the phones issues.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 08, 2011 | Cell Phones
What is the default security code of samsung softbank 821sc
The default Security code for all samsung products is 9999.
May 03, 2011 | Cell Phones
My softbank 821sc problem need to be open line in the philippines how and i need to go
how to unlock cellphone of migs antaran of calapan mental mindoro,the unit is softbank 821sc,how to solve it?
Nov 19, 2010 | Cell Phones
No Signal i Some Areas
i have this samsung 821sc phone from japan, twas unlocked and open line but it doesnt have smart signal in our place...it has signal for globe but dosnt have smart?wats the prblem with this? can the experts help me
May 14, 2010 | Cell Phones
Im rod i bought a samsung 821SC here in japan how do i openline it so i can use it in the philippines too it uses a usim card and its a 3G cellphone
Hi,from your question i think you need the unlock code for your phone.
There are two solutions to your problem,
1.You will call the service provider's customer care that sold the phone(3G) and request for the unlock code,which will be given to you for free,although you will be asked some questions,don't be bothered.
2.you can visit any of these sites;www.unlock-free.com or www.codeunlock.com.where you can be directed to pay a token to get it unlocked.
Take care
Mar 11, 2010 | Samsung Cell Phones
Want to unlock 821sc so that I can use it in India
Want to unlock 821sc so that I can use it in India ?
Jul 20, 2009 | Samsung Cell Phones
Cell Phones Logo
11 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
