Hello! I have a Canon IR1024i printer. During printing, it pauses for a couple of seconds after 1-2 pages printed, then it continues. What can be the problem?
map9966
  • 2351 Answers
SOURCE: prints extra blank page for every one page of printed material
Reduce the amount of paper in the print try.
Posted on Feb 11, 2008
  • 12 Answers
SOURCE: Printer prints top 1" of page, then just spits out blank pages
try and click on file at the top left hand corner of your screen.hit print and see what happens
Posted on Mar 03, 2008
Ajkill
  • 2035 Answers
SOURCE: printing a banner via canon mx310
  1. Access the printing preferences by opening the printer Properties / Preferences:
    For Windows Vista
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    • Click your right mouse button on the listing for your printer, and then select 'Preferences' from the menu that appears.
    For Windows XP Home Edition
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
  2. Click the Page Setup tab.
and select printing banner and then apply ok then start printing
Posted on Oct 12, 2008
mickspaceNET
  • 115 Answers
SOURCE: Printer constantly paused during printing
Is Post Script Key in the Mahcine? (PS must be intalled on the machine)
Do you have the Correct Driver
www.sharpusa.com
Posted on Oct 23, 2008
  • 72 Answers
SOURCE: printer pauses between each print job
Step one: Download and install the print diagnostic utility. click on this link from HP and download the printer diagnostic link. http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?swlinkmsg=100&lc=en&dlc=en&cc=us&product=1153494
Posted on Jun 17, 2009
LQ 300 +2 auto pause during printing
This is a feature provided by the manufacture to protect the print head overheat for small dot matrix printers. Here giving printer head connection diagram, the last two row have temperature sensing (thermister) connection pin 1 to 1. If the thermister is faulty in the print head the printer will auto pause abnormally. Check the printer with compatible / EPSON recommended print head. These kind of small printer only for POS printing not for continues printing. 2_17_2012_8_31_04_am.jpg
Feb 16, 2012 | Epson Dot Matrix LQ-300+II Printer
Our HP Laserjet P4015N printer prints slow. It prints, stop, prints, stop and so on. It is working from a print server (Windows 2003) and we have update the driver. It might work for a day, but then it...
If it is a local issue to your printer it is likely that the fuser temperature is set to low. If the fuser temp is set low then it will pause printing in order to maintain a whatever temp it is set at. If you web out to your printer(type in the ip address of your printer) you will find the menu for the printer. Somewhere in there will be the option to increase or decrease the fuser temp. Sometimes it is as obvious as FuserTemp;Higher, HIgh, Normal, Low, Lower. Other times like on the cp2025 color laser i have it is under the extended print modes option, and it is under fusing with the options of; less fusing (-2), less fusing (-1), normal, more fusing(+1), more fusing (+2). however the option is presented on your printer you will want to increase the fuser temp. do it incrementally and see what works best from you. If this does not solve the problem there may be a problem with the spooler dropping packets from your print server. Hope this helps.
Jun 09, 2011 | HP LaserJet P4015N Printer
My HP Laserjet 2015 is printing very slow. Paper pick up is about 15sec interval. Its very frustrating as I have more than 5000 pages to print.
try to perform Cold reset...maybe this will fix your problem.
Follow this simple steps:
1. Turn off the printer
2. Press and hold the GO button.
3. Turn the printer on, and continue to hold the GO button for at least 5 seconds, but no longer than 15 seconds. During this process, the Attention LED turns on.
4. Release the GO ****
Mar 19, 2011 | HP LaserJet P2015dn Printer
I just replaced my developer for all four colors. During the gradation adjustment, on the second and third test pages, I noticed pink streaks at top (about 1/5 of a 11x17 page). What could be the problem?
If you just replaced the toners then the problem is with the new toners. They will require that you print another 25 to 30 pages before the streaks will go away. Then you may continue to print without any issues. Let me know how I may continue to assist you.
Jan 28, 2011 | Canon CLC 5100 Copier
Power went off when I tried to print
Would be helpful to know which operating system you are using and whether there where any warning light flashing. For starters review the following solutions.
Printer Does Not Start or Stops During Print Jobs
Inner Cover was open when you started printing.
Close the Inner Cover and press the RESUME/CANCEL button on the printer. The printer resumes printing.
Inner Cover was opened while printing is in progress.
A page of print data being sent at the time of the error will be erased, so print that page again.
The printer has been printing continuously over a long period.
If the printer has been printing continuously for a long time, the Print Head may overheat. To protect the Print Head, the printer may stop printing at a line break for a period of time and then resume printing.
In this case, interrupt your print session at a convenient time and turn the printer off for at least 15 minutes.
Additionally, if the printer has been printing graphics or photos with intense colors continuously over a period of time, the printer may stop printing to protect the Print Head. In this case, printing will not resume automatically. Turn the printer off for at least 15 minutes.
i_expl.gif Caution
The Print Head and the surrounding area can become extremely hot inside the printer. Never touch the Print Head or nearby components.
Out of paper.
Make sure that paper is loaded in the selected paper source.
Reload paper if no paper is found in the selected paper source (Auto Sheet Feeder or the Cassette).
If the same paper is loaded in the other paper source, you can switch the paper source with the Paper Feed Switch or the printer driver to continue printing.
If both paper sources have run out of paper, confirm the selected paper source and load paper there.
Printing documents with plenty of photographs or illustrations.
When the POWER lamp is flashing green, the printer or the computer is processing data. Printing large data such as photos or graphics takes time for the printer and the computer to process, during which the printer may appear to have stopped operating.
In addition, when printing data that uses a large amount of ink continuously on plain paper, the printer may pause temporarily. In either case, wait until the process is complete.
i_note.gif Note
If you are printing a document with a large printing area or printing multiple copies of a document, printing may pause to allow the ink to dry.
Dec 08, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Error 5200 shows when trying to print. Not listed in the user manual.
I found a few answers http://www.uktsupport.co.uk/canon/bj/s400.htm
error 5200 indicates print head overheating. You might try printing 1/3 of document, pausing for cooling then print second 1/3, pausing for cooling then print final 1/3 as a work around.
Looks like thr repair cost is more than a brand new Multifunction printer/scanner
Aug 09, 2010 | Canon Office Equipment & Supplies
My HP L7580 all in one printer pauses while it is printing any page including the test page from the properties folder for approx. 45 seconds and then continues to print. I've made a photo copy using the...
hmmmm if its just a doc. it not normal...try to make a copy if its doing the same thing-if not them the software driver needs to be reinstall...for further support you can call 1-800-474-6836
Apr 02, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Waste ink full
This step is a "reset" step for the Canon CLI8 cartridges. The original Canon CLI8 cartridges have a memory chip on the back of the cartridge, which sends a signal to the printer when the cartridge is empty. Your printer won't be able to determine how much ink is in the compatible cartridges, but you can easily monitor the ink level by noticing the ink level drop in the cartridge as you print (the cartridges are see-through), or by noticing low ink output on the printed pages when you run out of ink. The "reset" procedure below is the best procedure we know of to date to allow your printer to use Uni-Kit cartridges which offer a tremendous savings over the Original Canon products.
With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
  1. The "Ink Low" dialog box will pop up (similar to photo 1 below)
  2. Continue to print until the "ink has run out" dialog box pops up (similar to photo 2 Below) Click "OK" to continue to print.
  3. The "Ink Low" dialog box may reappear, if so repeat the first 2 steps
  4. Then the "once empty" dialog box will pop up (similar to photo 3 Below) Click "Yes" to continue to print
  5. The "Not Liable" dialog box will pop up (similar to photo 4 below). Click "Yes" to continue to print
  6. Continue to print until the "remaining level of ink" dialog box pops up (similar to photo 5 Below) Click "OK" to continue to print
  7. Another dialog box will pop up with the "press and hold the Resume" or "press and hold the Paper Feed" button (similar to photo 6). Press and hold the "STOP/RESET" button (for Canon MP Series) or "PAPER FEED" button (for Canon IP Series) for 5 seconds. DO NOT Click "Back" or "Cancel Printing"
  8. The "Ink Monitor" dialog box will appear and the printer will continue to print. (similar to photo 7) In the event that that the "press and hold the Resume " dialog box pops up again, Press and hold the Paper Feed Button or Stop/Reset Button for 5 seconds
Oct 31, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
Canon BJC 4300 InkJet Printer
i assume the cleaning method that you perform is offline (taking the cartridge our and clean them). I suggest you clean the head during the printer on.. try to perform below steps per the manual Cleaning the printer Printing the test pages Cleaning the print head I assume you do not have the manual anymore (no DVD) i list down the step below Its a bit long manual I suggest you download them from the canon website.. if you still have problem I can send to you the BJC 4300 manual Cleanning printer Make sure the printer is turned off before cleaning it. It is a good idea to unplug the AC adapter also. Do not clean the exterior of the printer with volatile liquids such as thinners, benzine, or any spray-type or chemical cleaners; doing so will damage the surface of the printer. When cleaning the printer, avoid the area near the print head on the BJ cartridge. Do not touch the print head. Ink may leak out and cause stains. Clean the printer regularly to avoid printing problems. Remove any ink mist or paper debris from the interior of the printer using a soft cloth moistened with water. Clean especially well around the platen area. If the rollers become dirty, you can clean them using a small soft brush. Clean the exterior of the printer with a soft cloth moistened with water. Clean away smudges and dust. Do not use paper products (such as paper towels or tissues) to clean the inside of the printer. Printing the Test Pages You can print these test pages to check the operation of your printer and your print quality. Test A This test prints a repeating pattern of characters. Demonstration This test prints a sample page describing the printer's features. Printing the Test Page From Windows You use the Test option on the Control tab in your BJC-4300 Printer Driver for Windows to print a self test, demonstration page, or a nozzle test pattern. Before selecting a Test option, make sure paper is properly loaded in the sheet feeder (see Automatically Feeding Paper starting on page 3-7). Click on the Test option and then click on the Print button. Printing the Test Pages Using the Operators Panel To print a test page, make sure the printer is turned off and paper is loaded. Press and hold the POWER button until you hear the number of beeps that correspond to the test page you want to print. Test Page Number of Beeps Pages Printed Demonstration 1 Continuous Printing Status Information 2 1 Page Test A 3 Continuous Printing Nozzle Test 4 1 Page When you release the POWER button, the test page starts to print. *All self-test prints require Letter or A4 size paper. Using a smallersize paper for a self-test print will result in parts of the printoutbeing printed directly on the platen. All self-test prints are printed in accordance with the current printing settings (font, printing mode, etc.) *Red- Information for technician not included in the user manual Cleaning the Print Head Your printer is equipped with a print head cleaning function to ensure constant high quality printing. Cleaning the Print Head From Windows If you are using Windows, you can execute print head cleaning from the Control sheet in the printer driver. Simply click on Clean Ink Head. 4300 Chapter 4 Page 6 Cleaning the Print Head Using the Operators Panel If you want to clean the print head from the operator panel, follow these steps: 1 Make sure the printer is turned on. Make sure the green POWER light is on. 2 Press and hold the RESUME button for at least two seconds until the printer beeps twice. The POWER light will blink for several seconds while the print head is being cleaned. Perform the print head cleaning only when you encounter a print quality problem. Unnecessary and repetitious cleaning will waste ink. If you execute the print head cleaning while paper is manually loaded, the printer will eject the paper and then perform the cleaning. 4300 Chapter 4 Page 7
Aug 24, 2007 | Canon BJC 4300 InkJet Printer
21 people viewed this question
jasbo
jasbo
