Question about Tools & Hardware - Others
How can I use acid neutralizer to treat well water?
    New Friend:
  • 58 Answers
I would recommend reading this helpful article that explains how to use acid neutralizer to treat well water:
http://www.articlesbase.com/home-improvement-articles/how-to-use-an-upflow-neutralizer-for-acid-well-water-treatment-305784.html
Posted on Oct 15, 2013
How to treat acid reflux
There are a number of ways to treat acid reflux. First, you should be examined by a doctor to find the cause of your acid reflux, which is usually done by an Endoscopy and/or a study with a bravo capsule. However, if you want to treat it with over the counter remedies, here are a few things that can help.
Start out with the light acid reducers such as Cimetidine, and liquids such as Gaviscon, Mylanta, or liquid Rolaids. Some people find that chewables work better for them such as Rolaids.
If you still have acid reflux after using the light acid reducers, then you will want to try some of the "big boys" in the acid reducer category. Finding the right one is difficult, as it's different for everyone. Most people have good luck with a course of Prilosec OTC while others find little effect and prefer to try Zantac. In our household my significant other uses Prilosec OTC and I use Zegerid, I have worse acid reflux problems than he does including GERD, Esophagitis, and a Hiatal Hernia while he just has reflux and stomach ulcers.
If you've tried everything mentioned here, and still have heartburn, it's definitely time to see a doctor, if you haven't done so already. Prescription medications such as Sucralafate can help heal your stomach and solve problems such as eroded stomach lining often caused by acid reflux.
Good luck to you!
Mar 29, 2017 | Acid Health & Beauty
I have a 4"x6" pilar candle never worked right.Put in new batteries each week. "Old" ones covered with flakes of battery acid. Cleaned contacts with vinegar -no help. Any ideas? Thanks
to clean acid leaks you use baking soda or sodium bi-carbonate in water solution then clean of with fresh water
vinegar is an acid and acid will not neutralize acid so it will come back when dry
as for the rest it is possible that the soldered joints for the wires are affected and may have to be resoldered or the copper in the wires has also corroded away.
Dec 20, 2016 | Cars & Trucks
Whenever you mix an acid with a base, they neutralize each other. If this is the case, why is Alka-Seltzer used to treat stomach aches?
Alka seltzer is a base and stomach acis is "ACID" therefore it will neutralize and soothe an irritaed stomach.
Sep 30, 2014 | Coffee Makers & Espresso Machines
Burner time reset.
Are you sure you have an NR71? or is it an NRC model? only NRC models should be getting that code. Anyways, your house water treatment system has nothing to do with the neutralizer. The Neutralizer that it is telling you to replace is not there to treat the water going to your house. It is neutralizing the acidic condensate produced by the exhaust in your "condensing" unit. Without a new Neutralizer the condensate that drains out the bottom of the unit will be strong enough to kill plants and eat away very slowly at some items or metals underneath the skinny condensate drain. It's not a big deal unless you have the unit sitting above something you really care about and there's no condensate drain pipe attached. Either way, if you buy a new Neutralizer it comes with instructions on how to reset the timer so that you don't have to have the EC 92 bug you anymore.
Nov 14, 2013 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
My ph level is at 5.5, should i use calcite or corosex to treat the water?
use a blend of about 85% calcite with 15% corosex. this should put your ph level at around 7.5, if you use too much corosex, the ph could go over 8.5 which is the upper limit
Jan 16, 2013 | Tools & Hardware - Others
What are the most common acid neutralizers to change my waters ph level?
calcite, magnesium oxide, or gravel. if it is for drinking water, make sure the neutralizer is food grade quality
Is there maintainence for a nuetralizer tank
For a pH of 6.0 to 6.9 a type of naturally occurring calcium carbonate media called Calcite is used to neutralize the pH. For water with a pH of less than 6.0, magnesium oxide is blended with Calcite to bring the pH to 7.0 or above. The Calcite or the blend of media is put in either an up-flow neutralizer tank or a down-flow neutralizer tank.
Acid neutralizer water systems are typically installed after the well pressure tank.
In down-flow neutralizer tanks the media flows from the top of the media inside a vertical filter tank down to the bottom of the tank, and up a distributor tube and out of the filter to the household piping. Down-flow neutralizer tanks also act as filters since sediment and other fine particles become trapped in the Calcite. This type of neutralizer is automatically or manually backwashed to keep the media clean.
In an upflow neutralizer the water flows down through the center distributor tube and enters the media bed at the bottom and flows up through the media before exiting the neutralizer and flowing out to the plumbing. Up-flow neutralizers do not get backwashed because the media is never compacted and no sediment is removed. Since the water is flowing up through the media the media is not compacted to theoretically it does not require backwashing.
There are advantages and disadvantages to both up-flow and down-flow neutralizers. The main advantage of the down-flow neutralizer is that it not only neutralizes the water, it also acts as a whole house sediment filter. Down-flow neutralizers are usually automatically backwashed, which cleans the Calcite media and prevents rust particles and other sediment from fouling or coating the media. Since additional Calcite or blended media must be added to most neutralizers once or twice a year, down-flow neutralizers are easier to backwash and put back in service than up-flow neutralizers which cannot be backwashed.
Up-flow neutralizers must use an internal top screen in to order to prevent the Calcite from entering the home plumbing system. Calcite has the appearance of white sand and can quickly damage valves and fixtures if the media enters the plumbing system. If the water contains iron, manganese or sulfides, these internal top screens can later become fouled and so are generally are not used for this reason. Instead of the internal top screen, a filter housing and cartridge filter are usually installed after the up-flow neutralizer tank to prevent any mineral from flowing into the plumbing system. AdChoices7577471742534232713
With down-flow neutralizers these upper screens or external filter housings are unnecessary since the Calcite is prevented from leaving the filter tank due to the bottom internal distributor screen. The bottom distributor does not get easily fouled due to the backwashing the down-flow neutralizer tank receives on a regular basis.
In filter tanks the media can flow around the media and create channels which allow the water to flow without properly contacting the media. This type of channeling is more of a problem with up-flow neutralizers and rarely happens with down-flow neutralizers due to the action of the backwash. For most residential applications down-flow neutralizers work better than up-flow neutralizers due to the filtration feature and the backwashing function.
A down-flow neutralizer can be backwashed on a regular basis to clean, re-classify and distribute the calcium media thoroughly. This backwashing allows the down-flow neutralizer to function properly and lower maintenance costs. The Calcite media dissolves better because it is cleaned and then compacted in the down-flow neutralizer tank.
Well water that is acidic can also sometimes be high in iron, manganese or hydrogen sulfide. If a greensand or other type of manganese media iron filter is used to treat the water for iron, the pH should be raised up to at least 6.8 to allow the iron filter media to work properly. A down-flow neutralizer is usually the best choice to put in front of an iron filter because the neutralizer acts as a pre-filter removing some oxidized iron prior to the iron filter. This lessens the load of iron that the greensand filter must treat. Iron, manganese and sulfides can coat the acid neutralizer media and render it unable to dissolve into the water and neutralize the pH.
There are some applications where up-flow Calcite neutralizers are more desirable than down-flow neutralizers. If the flow is more or less constant on a regular basis, such as when the neutralizer is used to fill a holding tank with neutralized water, the up-flow filter works fine. Since up-flow neutralizers have no automatic backwash control valve they are less expensive than down-flow neutralizers. If the water is of excellent quality with no sediment or iron and the flow rate is constant then the up-flow neutralizer costs less to use and uses no backwash water.
Oct 14, 2012 | Plumbing
Culligan-water control valve leaks
If this is a Culligan neutralizer you will need to call Culligan for replacement parts as they are proprietary. You can pick up the seals for the by-pass at Culligan and replace them yourself. Depending on the PH of the water and your water usage the calcite should be replenished on a yearly basis. So you may want to have them out to do that also.
RJ
May 16, 2010 | Culligan Sediment Water Filter
Mix sm amount of caustic soda for deepwell
In most cases caustic soda is used for the treatment of large commercial deep wells. Unless you have a specific problem, (neutralizing a high acid level) that requires it or are treating a large turbine powered deep well system you really should use either a powdered or liquid chlorine. Also if the caustic acid can help promote oxidation which could adversely affect the pump.
I have sunk several shallow wells and replaced as many deep well pumps and never used anything other then about 1/2 gallon of chlorine. I included a link to a great site for information on the treatment deep and shallow water wells.
Hope this helps.
http://www.inspect-ny.com/water/Well_Shock_Procedure.htm
Oct 07, 2009 | Plumbing
Goodman furnace may be producing to much water
Your furnace is more than 90% efficient and extracting so much heat from the gas that it condenses instead of blowing out steam. This is good! Figure that for every dollar you spend on fuel, you are getting back 90+ cents back in heat. Compare that to the typical units that only get 70 - 80 cents back in heat.
Yes you should drain your condensate to a proper drain via gravity or a condensation pump. I would recommend you treat the condensate first with a acid neutralizer prior to draining in municipal drains due to it's high content of sulfuric acid. You can purchase these filter type neutralizers on the net or at a good heating wholesaler.
Feb 11, 2008 | Goodman GMS90703BXA Heater
Tools & Hardware - Others Logo
852 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
