Question about Dell Computers & Internet
Hello there, When I try to turn my Dell laptop on, the ''on'' light is flashing 5 or 6 times then turn off . Please help me, as all my work in it!!! Thank you in advance for your help!
    Scholar:
  • 132 Answers
Take out the battery and try it with just the power cord.
If that doesn't start it up then take a pen or paper clip and push in the reset button (should be on the side or front area) for 5 seconds and see if it comes to life.
Posted on Apr 24, 2009
When I start my laptop after some time it shows dell and I make it off now the laptop is not being on and other function like boot is also not working
Download and burn ths CD Resident WinPE.
http://www.uploadable.ch/file/mKD6atNTMRGF
Boot WinPE from CD and use a small boot recover utility it has,
If works, feel free to tell us if it was helpful
Aug 13, 2015 | Dell Computers & Internet
Orange light flashing, no chargine
A replacement battery must be the EXACT same power spec as the original in DC volts and Milliamps, or you could damage the Mobo components. Some aftermarket batteries do not work well. The connections may be different.
Jan 31, 2013 | Dell Latitude E5500 Laptop
Everytime I turn on my D410 Dell Laptop, the screen doesn't turn on. The caps blink about 10 times then shuts down. Please help?):
The flashing caps lock light indicates an SDRAM memory fault. If you are comfortable accessing the RAM yourself you can try re-seating it and see if that fixes the problem. If that does not work or you do not want to open the laptop up yourself, you will need to have the RAM replaced.
Mar 01, 2011 | Dell laptop Latitude D410 Series with...
Dell computer won't start up.
Please connect an external monitor, and turn on the power. If it is working, then it is video and LCD problem.
If not working on external monitro, try to remove the battery, then unplug AC adapter. Then press and hold power button for 30 seconds.After that, put battery back and re plug AC. Turn on the power. If still not working, and no display on screen, Then the motherboard need to replace.
May 09, 2010 | Dell Inspiron 9300 PC Notebook
Dell vostro 1510 error lights
But the Diagnostic indications says exactly that you needs a Motherboard replacement
Jan 05, 2010 | Dell Vostro 1510 Laptop
The light for the battery charging on my inspiron 1300 Dell laptop is now flashing amber??
Means:
1. Your battery is low and needs charging which possably means you need a new battery.
2. A battery replacement is needed.
Dec 30, 2009 | Dell Inspiron 1300 Notebook
It wont start up, push the power button and screen doesnt come on
Please plug also the power cord to the power source then wait for 10 - 20 minutes to charge the battery of your laptop then after the said time given above please turn on the laptop and see if your laptop is working now. Else if it is not then try to contact computer technician and let that person check the problem of your laptop Most of the problem causes of software and hardware.
Thanks
Aug 04, 2009 | Dell Latitude D505 Notebook
Won't post/boot
Try removing one of the two memory SODIMMS under the cover on the bottom of the unit. It sounds like you could have a bad memory problem that is keeping the machine from completing the POST (power on self test). I'd try one stick at a time and see if that helps.
Good luck, please rate this solution if you feel it has helped!!
May 13, 2009 | Dell Inspiron 1501 Notebook
Laptop Won't startup Vostro 1500
See if you can run the Pre-boot System Assessment (PSA) diagnostics. To run the PSA+ Diagnostics on this system, perform one of the following actions:
1) Hold down the <Fn> key while pressing the power button.
2) Turn on the system, press <F12> at the initial Dell™ logo screen, and select “Diagnostics” from the boot menu.
3) Disconnect the AC power and remove the battery. While holding down the power button, insert the AC connector into the back of the system. The system then starts and the message “Diagnostic boot selected” displays. The system then launches the PSA+ Diagnostics.
According to Dell specs, there is no error code listed that you described, (Flashing Caps LED). Also try reseating the memory modules, (you might want to try this first).
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 07, 2008 | Dell Vostro 1500 Notebook
Sony Wega 55" Replaced Bulb TV still does not work
Hello, please check how many times the red light flashes. If it is 3 times this means that the lamp cover is not fastened securely. If the red light flashes 5 times this means that the lamp driver is defect. If you need more help please advice
Apr 20, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Computers & Internet Logo
32 people viewed this question
Alun Cox
