Question about Kubik Digital Electronics Kubik Roca 8Gb Touchscreen Mp3 And Video Player
After charge will only switch on if connected to charger
Coby Kryos Android Tablet is not charging. It is connected to a charger but its not charging.
Leave the tablet connected to the charger for 5-10 minutes even if doesn\'t work. Then take out the battery and try with master charger and (switch on the tablet) after that, check whether the previous charger is working again or not again. If it doesn\'t show charging sign, then you have to take it to service center to change the charger connector.
May 21, 2013 | Tablets & eReaders
Tip
How to Wire On-Board Marine Battery Chargers
Battery chargers are wired into a boat's electrical system. Wiring the charger to a battery switch permits the charging of the individual batteries or battery banks. The switch can be configured to charge both batteries or battery banks at once. Mounting the charger in the vessel keeps the charger where it will do the most good--connected to the batteries. This is useful if you are stuck with low batteries and need a recharge. Power from a generator, shore power or even AC power from another vessel can be used to get you going again
Instructions Things You'll Need:
Battery charger
Battery switch
Battery cable (sized)
Cable cutters
Razor knife
Battery terminal lugs
Lug crimper
Terminal kit
Terminal crimper
Hammer
Step 1
Mount the battery switch with the mounting kit provided by the manufacturer. The switch should be accessible but close to the battery or battery banks.
Step 2
Mount the battery charger in a location that will be accessible but protected from the elements. Mount the charger close to the battery switch to reduce the size of the charger leads.
Step 3
Connect the battery cables to the battery switch. Mount the battery cables onto their corresponding terminal studs on the battery switch.
Step 4
Lay out the battery positive cable from the charger to the switch and cut it to length with the cable cutters. Strip 3/4 inch of insulation from the cable ends with a razor knife. Splice the cable to the hot wire from the charger with a **** connector and the terminal crimper. Crimp a terminal lug onto the battery end of the cable with the lug crimper and a hammer. Connect the terminal lug at the battery switch positive output terminal.
Step 5
Lay out a battery cable from the charger to the battery negative terminal block. Cut the cable to length and strip 3/4 inch of insulation from the ends with a razor knife. Connect the battery negative cable to the charger negative power lead with a ****-splice and the terminal crimpers. Crimp a terminal lug onto the terminal block end of the cable with the lug crimper and a hammer. Connect the terminal lug at the battery negative terminal block post.
Tips & Warnings
Set the switch to "1," "2" or "both" to charge battery bank 1, bank 2 or both batteries at once.
on Jan 07, 2010 | Mercedes-Benz C230 Cars & Trucks
How do I connect charger to battery I know one terminal has to be connected to a painted/ non painted surface. please advise
Red attaches to the POS or the + termnal. The Black clamp can attach to the NEG or the - terminal on the battery ... or any part of the engine. Assure the charger is in the off position when you connect. Assure it is on the Charge position if you are charging the battery. If you are trying to start the car, put the charger on the START position and let it sit on the battery for 30 seconds before you try to start it. The best way to get your car going is allow the charger to charge the battery on CHARGE setting for an hour or more first.
Incidently, I have a charger exactly like yours ...
Thanks for your qeustion @ FixYa.com
Sep 19, 2011 | Schumacher & Fast Charge Starter Charger
I turn rocker switch on with one battery I show full, plug in a different battery, turn on rocker switch get nothing, both batteries show a full charge on charger. I think one battery is 3 years old other...
Hello
Check the following:
* Circuit breaker on main control box is tripped
* Fuse blown (check fuse in main control box assembly).
* Incorrect polarity at battery terminals
* Dead batteries.
* Charging cable is still connected to charging receptacle
* One of the cable connections at the main control box is loose.
* Control connection cable disconnected
* Broken key switch
* Throttle stuck fully open
* Throttle control potentiometer broken.
* Speed potentiometer broken
* Battery voltage too low.
* Faulty charging cable.
* Charger not working.
* Charging circuitry in main control box assembly not working
If these check OK, the problem is likely to in the control connection cable or upper control box Verify that the upper control box is getting 24V. (Blue wire on red connector.)
* If the upper control box is not getting 24V, replace control connection cable
* If the upper control box is getting 24V, check key switch operation and verify wiring in the upper control box. Trace voltage from keyswitch on to find where the problem occurs. (Replace upper control box if necessary.)
* Charge batteries with a 12V charger or replace if necessary.
* Ohm test the charging cable - replace if necessary.
* Test scooter with a different charger, if new charger works, replace charger.
* Check wiring in main control box assembly - replace in line relay if necessary
* If batteries, charger, and all wiring is good, replace controller PCB. (Note the model number for the PCB, for example 1208-2330.)
Aug 22, 2011 | Shoprider SL73 Echo 3 Wheel Scooter ()
Dear sir i have a china mobile Nktel A800, my mobile not charger support. i charge my mobile and my mobile show message bad charger connected, plz slove my problem, my no. +917737119777
repair your mobile...
i knw your problem... any time it will saw u charger connected without charger..
problem is in the socket of mobile where u connect charger to phone
May 17, 2011 | HP StorageWorks (A8000A) 16-Port Fibre...
My phones power stitch is not working
Dear customer
At first u just connect the charger of ur mobile and see its charging or not if it is showing charge then there is a problem in ur on/off switch or connection between CPU to switch. Change ur on/off switch or make the proper connection if u are a professionally trained for mobile repairing. If ur mobile phone doesn't charge after connecting the charger then its a hardwere or softwere problem in PCB (Printed circuite board). It is better to go at NOKIA care if u are not a Technician. Thank you for visit.
May 22, 2010 | Nokia 3110 Cellular Phone
I inherited the charger w/no manual - as I've
I can find no manual on line for the charger but the basic & most important things I can share with you.
On the charger should be your On & Off switch, possibly 6 volts / 12 volts switch, (you want 12 Volt) some have a meter to show how much amp draw is taking place as it is charging and you'll have to determine that from observation.
MOST important parts: It is best to disconnect the battery you are charging, at least the Negative post. This will speed up the charge process & prevent any mishaps with the electrical system on the vehicle. I prefer the battery completely removed & placed on an insulated material, plastic, wood, rubber, to prevent battery drain by sitting on concrete or the ground.
If you can check the battery first for swelling/cracked case=don't charge! Frozen inside=don't charge! Thaw first. The fumes from batteries charging are explosive & no sparks, or flames should be anywhere near. Upon reinstalling, Negative wire is always last to connect & be sure that everything inside as far as lights & ignition switch are off to prevent excessive sparking when you connect the final cable.
Charging & connecting. I prefer to test unknowns such as the connecting cables to make sure they are what they say they are. You need a multimeter for this but for now, I am expecting they are marked properly for this instruction. You need a Positive clamp , this one usually has Red handles, to connect to the Positive terminal of the battery (marked POS or +) The other cable, generally Black, connects to the Negative terminal (marked NEG or - ) and provides the ground to complete the circuit.
Make sure connections from the charger to the battery are all clean & well attached, then turn ON the charger. This will prevent sparks near the battery. Be sure to turn off the charger once charging is completed, then disconnect the cables from the battery. The unit you are charging with should give you some indication about when you're charged 100%, but these are the basics of charging a low battery. If by chance your charger shuts down on you & stops charging immediately, you either have the terminals reversed, or a shorted battery. good luck
Feb 06, 2010 | 2006 Ford Expedition
Samsung omnia problem trying to charge battery
It looks like battery is damaged... When plugged in to charger phone shouldn't power on. Try put it on charger when on and see if charging icon appear. (top right corner-battery status icon should change -insted of battery to charging.) Battery is fully charged after cca 4 hours, 80% after 2 hours.
Jul 16, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Mio 168 not charging when using Car Charger
You have to have an ignition switch on, only then to connect a device. It is to protect device against an electric shock.
firo
Dec 15, 2008 | Mitac Mio 168 Pocket PC
Kubik Digital Electronics Kubik Roca 8Gb Touchscreen Mp3 And Video Player Logo
18 people viewed this question
Top Kubik Digital Electronics Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Kubik Digital Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
