Question about Car Audio & Video
IDM 888 wiring harness diagram - Car Audio & Video
2 Suggested Answers
reinadkorazo
SOURCE: need wiring diagram for idm-888
YUP
Posted on Oct 07, 2012
96 f350 no ground on #3
test again, known wiring harness problems beneath valve cover
Jul 11, 2013 | Cars & Trucks
Ford code p1316
ford code p1316 is IDM problem ( injector driver module)
the IDM operates as 2 banks of injector drivers ( right and left and can cause one bank to shut down as if driving a 4 cyl
there are forum statements which say that there is a problem with wiring and clips inside of the rocker covers or broken wires
check that the harness and wires to the unit are tight
suspect that the module may be in an area that is near the transmission and the wires may have been disturbed
I went google and typed in--- ford fault code p1316 and there are videos and forum sites that will help you
code p 0562 refers to system voltage --low===causes ---wiring---poor connection--battery---alternator
also refers to ECM power relay control--circuit open wiring ---ECM relay
check that all harness connections were put back properly after the transmission job
code p 0231 refers to fuel pump relay---circuit low ===causes --wiring short to ground --fuel pump relay---ECM
Apr 13, 2017 | Cars & Trucks
Wiring the circuit board i need a diagram
wiring diagram for what brand? is the circuit board located in the pump housing or in a separate box?
Rod
US Parts Center
We locate the "seemingly" impossible...
888-521-6183
Jan 20, 2013 | Home
PO380 and p1316 what do thies coads mean.
P0380 - Glow Plug/Heater Circuit "A" Malfunction
Bad glow plug. The glow plug system is used to assist in providing the heat required to begin combustion during cold engine temperatures. The glow plugs are heated before and during cranking, as well as initial engine operation. The engine control module (ECM) controls the glow plug ON times by monitoring coolant temperature and glow plug voltage. The California Glow Plug system has eight individual glow plug supply circuits between the controller and the glow plugs. If the feedback voltage from the controller to the ECM is not within range, DTC P0380 will set.
- The glow plugs are commanded OFF and the glow plug feedback is more than 2 volts. or
- The glow plugs are commanded on and the glow plug feedback is not between 5 volts and 6.2 volts.
Keep in mind that the "wait to start" light only comes on while the voltage is dropping in that circuit. This should only take 3-5 sec's. If it takes longer, refer to your "Likely problem" you listed above. That would be the Heater Module. If your glo plugs stay on, your batteries would be dead in no time. If any of your plugs go bad, they would each be listed on the reader per cyl 1-8. If you need to change the Module,
P1316 - Injector Circuit / IDM Codes Detected.
This code indicates that codes are stored in the IDM
Possible causes are as follows:
- Injector(s) or circuit(s)
- Open or shorted IDM enable circuit
- Open/short in EF circuit
- Open/short in FDCS circuit
- IDM relay
- IDM powering circuits
- Failed IDM
- Failed PCM
Check your Injector Driver Module wires, circuits 821 (Brown/Orange) and 818 (Grey/White) between the PCM and IDM. On the IDM side, the connector pin numbers are 17 for circuit 821, and pin 4 for circuit 818. You should check for high resistance in that circuit, short to ground, or open circuits. If wiring checks out good, you may need to replace your IDM. It's not uncommon for water intrusion into the module, due to its mounting location. Also check the engine wiring harness where it routes up over the driver side shock and/or driver side valve cover. That code is either a key-on/engine-off or a continuous memory code.
Hope this helps (remember to rate this answer).
Feb 04, 2011 | 1999 Ford F350 Regular Cab
Ford f250 2002 idm relay clicking will not start
PCM maybe loosing voltage may have caused Engine control Fuse #22
to blow open. IDM injector Driver module could have loose or open harness connetors. IDM relays gets its ground thru the PCM ground circuit. When this happens it cycles the ground side of the relay trigger coil switch.
Feb 22, 2010 | 2000 Ford F350 Super Duty Super Cab
97 F350 diesel check engine light stays on and is running rough?
Ok, lets take this from the top. I have a 97 f250 diesel. In mid may mine did the same thing. It's either one of two things. You have under valve cover harnesses (uvc). They slide in under your valve covers, you will see two wiring harnesses on the outside of the valve cover gaskets on either side of the block. Ok, it IS possible one of these slipped out of place and killed two of your injectors, causing the horrible running/ low idle/no power/ sounds like the truck is going to stall symptoms. The easiest way to check that is to unplug the wires while the truck is running and see if it kills the engine, if it doesen't unplug the other one on the same side of the valve cover. If both of these don't cause any change then you have a bigger problem, the IDM (Injector drive module).
FAIR WARNING: When you unplug the wires with the truck on it is extremely dangerous, it is 110 volt feed. It can kill you.
OK, the IDM is a silver box, 8"x10" approx dimensions, located on the driver side under the hood, over top the front tire. If you take the wires you unplugged and take a multi meter to them and they are dead, you have a bad IDM. This was the case with my truck. Ford designed the IDM to have a hole in the side to allow condensation to escape from it, unfortunately, this allows water inside and will short out resistors and practically kill half of your engine. Buy a new IDM on ebay for about $380. It takes 5 minuts to put it in.
I hope this helps you out man.
Aug 28, 2009 | 1990 Ford F350
Wiring diagram for the ignition wiring harness for a 99 Malibu?
you can go to a chevy dealer and get a diagram of the wiring, or go to any auto parts store and buy a haynes manual for your car. the wiring diagrams are in this manual. for about $20.00,
Aug 27, 2009 | Corvette Chevy Malibu 90-04 Car Radio...
Replacement wiring harness for pyle pld5mu
1-888-318-PYLE Ask for tech support they will sell you one.
Mar 10, 2009 | Pyle PLD5MU Car DVD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
