2 yr old Samsung WA80V3 drains out water immediately
5 Suggested Answers
beltronic205
  • 1466 Answers
SOURCE: I have purchased SAMSUNG -
sounds like the drain pipe is too low resulting in Syphoning of water lift pipe above 24 inch floor level, this should cure...
Posted on Feb 01, 2011
  • 6277 Answers
SOURCE: Samsung WA80V3 leaking water at
It could be that the cap is not screwing on completely because of limescale in the thread and/or the filter is not seated properly. I suggest undoing the cap and removing the filter (if that is practical/possible) and spraying all with anticalc fluid to clean. This 'cure' helped another FixYa customer with a similar problem!
With ours I had to spend a couple of hours gently turning the cap back and forth until it finally released its hold- but the filter did not remain attached to the cap by its rubber ring. More patience, anticalc fluid and all was revealed.
I now run an anticalc clean regularly.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 15, 2011
barkencoa
  • 3463 Answers
SOURCE: Samsung WA80v3 connected to cold
It will heat the water as normal, even though it is a cold fill only washer.
Just select prog as normal, washer will do rest.
Posted on May 18, 2011
richroth
  • 9472 Answers
SOURCE: Samsung Washing Machine WA80v3 not working properly
Did the water start without you setting the cycle?
Posted on Nov 28, 2012
Got a Samsung Diamond Drum WA80V3 after I put in on quick was and start it goes 22 minutes and when at 15 it goes toe rinse but then the machine just stop doing anything. Water still inside drum. Maks n...
The drain pump is either blocked or failed. Check the filter if it's clear then you are most likely up for a new drain pump. Here is a link to the part you need and a video on how to do it. Samsung DC31 00030E DRAIN PUMP B20 3 120V 60 NEW ORIGINAL
Mar 15, 2015 | Samsung Washing Machines
Why does my Samsung washing machine wa80v3 not wash, spin or drain. ?
There are a few things that could cause this, first of all check the lid switch. That is a safety thing that makes sure the lid is closed before it allows it to start washing or spinning. Some other culprits could be a clogged filter, or a broken belt ( if your model has a belt) does the machine sound like its trying to wash? or does it just turn off and do nothing like its dead? if it seems dead its more than likely the lid switch, they are about $40 and simple to replace.
Jul 15, 2014 | Washing Machines
Samsung wa80v3 does not drain water
check the drain pump isnt blocked. there is a panel at the bottom front of the machine. remove this and unscrew the round cap and look for a jam. turn off machine first! move the propellers with you fingers. if its ok it should turn a quart of a turn then race forward some
May 17, 2014 | Washing Machines
Samsung automatic WA80V3 does not drain water
the pump maybe jammed or the filter could be blocked.
if you need advise on how to check, let me know
Got a samsung wa80v3 washing machine it just stopped draining after checking it out I found the drain pump was burned out I replaced it with a new one my proplem is as the water comes in its drained out...
Did you replace the pipe correctly? The thing you should be asking though is why was the first one burnt out? Is there a connection problem? Maybe the replacement pipe has burnt out as well.
Elisa Jed ' http://www.lanzaplumbing.com
Apr 17, 2014 | Washing Machines
Nov 28, 2012 | Washing Machines
Water is continuously draining from my samsung washing machine . due to this unable to keep washing the clothes .why the problem come & what is the remedial measure to rectify?
Possible that the drain value is half blocked and so is not able to block the water in the tub. Remove the connection to the valve and check if this drains , if so it is confirmed. Remove, clean the dirt and reset. If the leak stays then the valve is faulty.
Also it can be due to partial voltage to the drain valve to keep it open which means that the program controller is faulty. This is confirmed when the drain stops as the connection to valve is taken off.
Jan 13, 2011 | Washing Machines
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
