How do I set up Canon 8500 printer defaults in computer? I print manuals as needed that require 2 sided,colored covers then stapled. There used to be a manual default to select but was erased accidently.
    Brigadier General:
  • 3,614 Answers
You can change the default printer to any other printer that you have connected to your computer. This will simplify your printing tasks, since you can select the most frequently used printer to be the default.
  1. Click on the Start menu and click on Settings, then Printers.
  2. A window will appear showing the icons of all the printers that are installed on your system. Right-click on the icon for the printer you want to use as the default. A menu will appear.
  3. Click on Set as Default.
  4. To make sure the correct printer is now set as the default, right-click on the printer icon again. When the menu opens, a check mark should appear before Set as Default.
Hope this initial info/idea helps.
Posted on Apr 24, 2009
How do i print copys of MX310 printer manual
Do you mean the Canon Pixma MX310 all-in-one inkjet printer? If you wish to print a copy without using a computer, first make sure that you have ink and paper loaded and that the all-in-one is on and the paper output tray is extended. Place your document face down on the glass or face up in the automatic document feeder. (Note: the scanner doesn't see the document if it is within 2 mm of some of the edges of the platen glass. If you use the ADF, remove any document currently on the glass.) Press Copy (if the unit isn't already set to copy). Check the default settings on the LCD screen and enter the number of copies desired. Press Settings to change any items and use the left/right arrows to change the number of copies, if needed. Press the Color or Black button to make the copy(ies). Color for color documents and Black for black & white documents. Press Cancel to stop copying.
The FAQ on making a copy without storing the image on a computer is here: https://support.usa.canon.com/kb/index?page=content&id=ART120681&actp=search&viewlocale=en_US&searchid=1485643876501 .
The manual is available on the product support page: https://www.usa.canon.com/internet/portal/us/home/support/details/printers/support-inkjet-printer/mx-series/pixma-mx310 . Click on the Manuals tab. The manual is in a self-extracting executable file. You'll need to run the program and then find the icon or folder where the manual is stored. (The default location is C:\Program Files (x86)\Canon/IJ Manual .)
I hope this helps. If this doesn't work, please add a comment with any error messages that you see.
Jan 28, 2017 | PRINTER Office Equipment & Supplies
How do I reload staples into my Xerox WorkCentre 7530?
You did not indicate finisher? Xerox MFPs' come with the most finishing options of any manufacturer.... I included instructions for all of them below. Enjoy!
Solution : Load Staples in the Professional Finisher With Booklet Maker The stapler in the booklet maker uses two Staple Cartridges labeled R2 and R3. Booklet stapling requires that both Staple Cartridges be free of jammed staples.
WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the printer has stopped copying or printing.
  2. Open the Finisher Front Door.
  3. Squeeze the orange R2 and R3 levers together and pull the Staple Cartridge unit out of the Finisher until it stops.
    NOTE: The Staple Cartridge unit does not detach from the Finisher.
  4. Grasp the orange tabs on both sides of the Staple Cartridge and lift the cartridge out of the Staple Cartridge Unit.
  5. Push the new cartridge into the Staple Cartridge Unit.
  6. If no jammed staples are found, repeat step 4 - 6 for the other Staple Cartridge.
  7. When finished, return the Staple Cartridge Unit to its original position.
  8. Close the Finisher Front Door.
Solution : Load Staples in the Main Stapler of the Professional Finisher NOTE: Using Staple Cartridges other than the recommended staples may impair quality and performance. Only use only Staple Cartridges recommended for this Finisher.
  1. Make sure the machine has stopped copying / printing.
  3. Grasp the orange R1 lever on the Staple Cartridge and push it to the right.
  4. Grasp the orange tabs and pull the cartridge out of the Finisher.
  5. Check inside the Finisher and remove any loose staples.
  6. Pinch both sides of the staple case and remove the staple case from the cartridge.
  7. Insert the front side of the new staple case into the Staple Cartridge, then push the rear side into the cartridge.
  8. Grasp the orange tabs on the cartridge, and then insert the cartridge into the Finisher until it click into position.
  9. Close the Finisher Front Door.
Solution : Load Staples in the Booklet Maker of the Optional Office Finisher LX NOTE: The Booklet Maker uses two staple cartridges. Booklet stapling requires that both staple cartridges contain staples.
  2. Open the Finisher Side Cover.
  3. If the Staple Cartridges are not visible, grasp the vertical panels to the left and right of the opening and slide them to the center.
  4. Hold the tabs on both sides of the cartridge and pull the cartridge out of the finisher.
  5. Hold the tabs on both sides of the new cartridge and insert it into the original position in the Finisher.
    NOTE: If you have trouble inserting the cartridge, make sure the staples are positioned correctly in the cartridge.
  6. Starting at step 3, repeat the procedure for the other cartridge.
  7. Close the Finisher Side Cover.
Solution : Load Staples in the Integrated Office Finisher WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the machine has stopped printing or copying, then open the Front Cover on the Integrated Office Finisher located under the Scanner Assembly.
  2. Remove the Staple Cartridge by grasping the cartridge by the orange handle and pulling it straight out of the Finisher.
  3. Remove any loose staples inside the Finisher.
  4. Pinch both sides of the staple case and remove the staple case from the cartridge.
  5. Remove the new staple case from its packaging and insert the front side of the case into the staple cartridge. Push the rear side into the cartridge. The cartridge will click into place when it is installed correctly.
  6. Grasp the cartridge by the orange handle and insert the cartridge back into the stapler until it clicks into position.
  7. Close the Front Cover.
    NOTE: If the Front Cover is not completely closed a message will be displayed. The machine will not operate if the cover is even slightly open
Nov 18, 2013 | Xerox WorkCentre M-24 Color Copier
Can I print on both sides of the page
Here are the instructions for duplex printing.
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
1. Open the printer driver setup window, and check the Duplex Printing check box on the Page Setup tab.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note
sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper or Photo Paper Plus Double Sided is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
You can download a users manual for your MX310 at
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#BrochuresAndManuals
Please rate this solution. Thanks.
Sep 27, 2011 | Canon PIXMA MX310 All-In-One Printer
How to get a Canon MG5220 printer to print 2-sided copies
If you have a Canon MG5220 you certainly can print two-sided. I have one and I print two=sided pages. When you bring up your print menu underneath "Orientation" is a small window that likely says "layout". Click that window and you will have various options to choose from; color matching, paper handling, cover page, quality media color options. borderless printing and duplex printing & margin. Choose Duplex & Margin. Once you've clicked that you'll see a check box for duplex printing, click that box. You have other options for for reduced or normal printing (your choice) and then if you're stapling there's options for the side you'd prefer but the point is once you've checked off that box for duplex printing you're set to go.
Feb 05, 2011 | Canon imageCLASS MF7480 Laser Printer
My computer was printing lines within color images. I tried to manually adjust the colored ink. That made things worse. How do I reset the printer back to default auto settings?
start>control panel>printers
select the IP3200 printer
select display printer queue
select IP3200 printer
select printer>properties>printer preferences>defaults>apply
This should set your printer back to the default settings.
Aug 15, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Ref.: BJC 620 I cannot get true black print, instead I get sort of greenish color where the black shoud be.
Hello, look at what cartridges are being used and what is status indication? There are several things to think about, as follows:
1) Is there a good black cartridge? Many color ink-jet printers will print black using color cartridges if black is out, low, or bad.
2) Can you use a standalone copy mode - if possible for your printer -and get good/correct copy colors (not using the computer)?
2) Have any cartridges been refilled manually? I have done this where I thought I refilled a cartridge with the right color and filled it with the wrong one by accident -oops. Please try different cartridges.
3) Is your printer color problem the same when using any or all programs? If it is and you are sure all the cartridges are OK then use your printer software to reset all the settings to a default factory settings and try again.
Oct 30, 2009 | Canon Office Equipment & Supplies
Canon imagerunner 2270 staples on the right side
Under user screen you have in lower left corner finisher or similar. press it, and chose staple and left or right
Nov 20, 2008 | Canon MF8180C Color Laser MFC Printer
Canon MP470 printer problem
I think your printer requires a little servicing. Those spots are usually caused by a dirty gamma wire, and probably the fuser is requiring a replacement. Both tasks can be done on-site, but require a little knowledge of the printer internal parts.
Mar 17, 2008 | Canon PIXMA MP470 All-in-One Printer
Can I set default printing to black and white for color laser printer?
Yes. Any printer's default options can be set as desired. Open the printer's properties (Start/Control Panel/Printers/right click the printer and left click Properties), and change the setting as you wish, then click OK. Those settings should be used each time you use the print command, unless you change the settings for that particular print job.
Hope this helps, and please rate my advice, good OR bad.
Feb 05, 2008 | Office Equipment & Supplies
Color printing problem~only green, yellow, blue
The TekColor correction options provide simulations of different color devices. Automatic is the default correction for general image processing. Use the following table to determine what option you want to use.
TekColor
Description
Automatic Applies the best color correction to each graphic element: text, artwork, and photographs Office Color sRGB Display: Approximates the colors on a computer display.
sRGB Vivid: Produces brighter, more saturated colors than sRGB Display. Press Match SWOP Press: Matches specifications for Web Offset Publications.
Euroscale: Matches Fogra glossy paper specification.
Commercial: Approximates U.S. commercial press target.
SNAP Press: Matches specifications for Newsprint Advertising Production. None Applies no color correction. Use with other color management tools, such as International Color Consortium (ICC) profiles, ColorSync, or the PANTONE Color Chart for the printer. Black & White Converts all colors to shades of gray
From the workstation, select the color correction in a supported driver.
Microsoft Windows 98 SE / ME / 2000 / XP/ Server 2003 / NT 4.x Operating Systems (OS):
NOTE: Some of the color corrections are grouped under Office Color or Press Match.
  1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed.
  2. Click on the [Properties] button located on the top, right of the window. The Properties window will be displayed.
  3. Click on the [TekColor] tab.
  4. Select the required color correction.
Apple Macintosh OS 9.x:
  2. Click on [General], and then select [TekColor] from the pull-down menu.
  3. Select the required color correction.
Apple Macintosh OS X, (version 10.2 and higher):
  2. Click on [Copies and Pages], and then select [Image Quality] from the pull-down menu.
Dec 05, 2007 | Xerox Phaser 8500/DN Printer
59 people viewed this question
k24674
jasbo
jasbo
