Question about Mitsubishi MSZ-FE12NA MUZFE12NA Mr Slim 12,000 BTU 23 SEER Heat Pump
Mitsubishi Heavy Industries Cassette Out Door Model: FDC506HES. What is the BTU size?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 26 Answers
1 ton of ac is 12000 btu. you should probably call mitsubishi they have a tech support that will help you with this. the number is usually in the paperwork that came with the unit. you may find it on the tag where you got the model number
Posted on Oct 15, 2013
4 Suggested Answers
  • 15 Answers
SOURCE: mitsubishi heavy industries a\c srk20zcx-s
Most of the time once every season so once a year same time you clean the filters. But being thats its the cheaper chinese made heavy industries and not the better quality japanese made mitsubishi electric i would say once every 3-6 months
Posted on Mar 16, 2008
  • 7 Answers
SOURCE: Mitsubishi electric or Mitsubishi Heavy Industries
as an refrigeration engineer dealing whit them every day my advise is: mitsi heavy industry away much more reliable and better performing.
Posted on Jun 27, 2009
  • 534 Answers
SOURCE: No Mitsubishi Air Con Manual
ok heres the problem. The a/c filter is clogged or the evaporator coil is clogged. These systems have a metering device that measures the amount of air flow over the coil. If this air flow is obstructed the filter light will flash. If the filter in the unit is clean then the coil has some type of obstruction. This will mean having to clean the coil before the light will go off. An a/c tech should be able to clean this for you and it not be a huge cost. They have the chemicals to get the job done fast and clean.
Change your filter first.
Good Luck hope this helped you some
Dave
Posted on Jan 12, 2010
Hi I need manual for mitsabishi heavy industries model no src7zea-s
Mitsubishi Link HERE:....https://www.mhi-mth.co.jp/en/products/detail/air-conditioner_users_manual.html
May 11, 2017 | Sewing Machines
FDC506HES
what issues are you having with your mini split system?
Oct 21, 2013 | Mitsubishi Heating & Cooling
Need a manual for a raypak 346 optimum pool heater
Not familiar with "Optimum" by Raypak.
346 is probably your output BTU/Size in 100,000's, so 346,000 btu
What is model number of your heater? Metallic label on inside of the heater behind the front cover/door.
Some Common heater models current & obsolete are as follows:Gemini, Versa, RP2100, Delta, xfyre
Dec 29, 2012 | Raypak Free Hydraulic Lift Gate Delivery -...
Canon image class mf5750 legal size paper
Hi ...
If you wish to print using a paper size which is different from the normal one A4, you need to specify the same to the printer else it will not recognize or will not accept the paper ...
Below are the steps that you can follow to:
1) Specify paper size
2) Specify paper type ..
Specifying the Paper Size At the factory, the paper size has already been set to [LTR]. Normally, you can make copies in this setting. When making copies on other sizes of paper, you need to specify the paper size according to the following.
  1. Press <Menu>.
  2. Press <la.gif> or <ra.gif> to select [COMMON SETTINGS], then press <Set>.
  3. Press <la.gif> or <ra.gif> to select [PAPER SETTINGS], then press <Set>.
  4. Press <la.gif> or <ra.gif> to select [PAPER SIZE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper size (LTR, LGL, EXECUTIV, A4, B5, ENVELOPE, or FREE SIZE), then press <Set>.
    black_dot.gif When [ENVELOPE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select the type of envelopes (COM10, MONARCH, DL, or ISO-C5), then press <Set>.
    black_dot.gif When [FREE SIZE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select [VERTICAL SIZE] or [HORIZONTAL SIZE], then press <Set>. white_square.gif Use the numeric keys, or press <la.gif> or <ra.gif> to specify vertical and horizontal sizes of the paper in millimeters (mm).
    Available range in [VERTICAL SIZE]: 127 mm to 356 mm (5" to 14")
    Available range in [HORIZONTAL SIZE]: 76 mm to 216 mm (3" to 8 1/2") white_square.gif Press <Set>. Repeat the steps above to specify both vertical and horizontal sizes of the paper.
  6. Press <Stop/Reset> to return to the standby display.
Specifying the Paper Type [PLAIN PAPER] is selected as the default paper type. When making copies on paper other than plain paper, you can specify the paper type according to the following. Specifying the paper type can prevent poor copy quality, or the printout not being printed correctly.
  1. Press <Menu>.
  4. Press <la.gif> or <ra.gif> to select [PAPER TYPE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper type, then press <Set>.
    You can select from the following paper types: - Plain paper (17 lb to 24 lb (64 g/m2 to 90 g/m2 )): [PLAIN PAPER] - Heavy paper (25 lb to 34 lb (91 g/m2 to 128 g/m2 )): [HEAVY PAPER], [HEAVY PAPER H]*1 - Transparency: [TRANSPARENCY] - Label*2 : [HEAVY PAPER], [HEAVY PAPER H]*1 - Envelope: [HEAVY PAPER], [HEAVY PAPER H]*1*1 If print fixing is not sufficient when printed with [HEAVY PAPER] selected, select [HEAVY PAPER H].
    *2 A label that can be loaded in the cassette is a standard type (label standard card) only.
Please vote if this helps ... Cheers :)
Jul 27, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
P8 eroor code
P8 error is abnormal pipe temperature indoor. If you are running it on heating P8 error will appear because the disc pressure is too high. It could be overcharged.
May 31, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
How to scan legal documents on Canon MF5770?
This information is available on CANON WEBSITE
Unfortunately, they imbed the text in javascript, and there is no way to link or c/p the information here. Try THIS HYPERLINK to take you to the exact page.
Enter your model # in "search knowledgebase" at the above link.
Type PAPER SIZE
You will have a clickable link that says How do I specify paper Size and Type.
Instructions will appear.... starting like this... (i used C/P, and it may not come out slearly after I submit this answer)
Issue: How do I specify the paper size and type?
Solution: Specifying the Paper Size and Type
  • When making copies on LTR-size paper after having continuously copied on paper smaller than LTR-size paper, the copies may be dirty. To prevent copies from being dirty, wait about 1 minute before making copies.
  • The paper in the multi-purpose feeder is fed prior to the paper in the cassette.
  • The settings changed in the Menu do not return automatically to the settings you set previously. Change to the previous settings again if necessary.
  • When making copies of a small size or heavy paper*, etc., the copy speed may be slightly slower than usual.
    *The paper type should be selected in the Menu.
  • If you intend to make a copy and print with a thermal transfer printer using the same sheet of paper, make the copy first. Failure to do so may make copies dirty or cause a paper jam.
  • When copying onto transparencies, remove each transparency from the output tray as it is output.
  1. Press <Menu>.
  1. Press <Menu>.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | Canon imageCLASS MF5770 All-In-One Laser...
Jan 29, 2009 | Mitsubishi MS15TN Air Conditioner
Mitsubishi heavy industries a\c srk20zcx-s
Mar 06, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi MSZ-FE12NA MUZFE12NA Mr Slim 12,000 BTU 23 SEER Heat Pump Logo
114 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
