Question about Extended Systems ExtendNet 100X Print Server
Default password - Extended Systems ExtendNet 100X Print Server
WRT310N
Hello I found the following info about the default settings on your router (you can reset your settings to the default ones by pressing the reset button on your router or the back of your router device):
Link is: http://pcsupport.about.com/od/linksys-default-passwords/a/wrt310n-default-password.htm
WRT310N Default Password & Other Default Login Data Version Default Username Default Password Default IP Privileges All [none] admin 192.168.1.1 Administrator
Jan 28, 2012 | Linksys WRT Computers & Internet
Tip
Forgot my password.
If you ever forget your password to your router you can look up the default password online.
Most default passwords for linksys is: login=blank password=admin
Default passwords for belkin is: blank
Default passwords for netgear: login=admin password=password
Default passwords for d-link: login=admin password=1234 or password.
if none of the passwords work then you can reset the router to factory defaults by holding the reset button in with a paperclip for 30 seconds while powered on. This will erase any customized settings and apply the factory default settings. If the password doesn't work please check with your device manual.
on Feb 23, 2012 | Linksys Computers & Internet
Forgot my password for wrt120n
Looking for the Linksys WRT120N default password? You probably have little reason to access your router on a regular basis so don't feel too bad if you've forgotten the WRT120N default password.
However, when you're troubleshooting a network problem and need to get in to the device, the WRT120N default password suddenly becomes very important.
For most versions of the Linksys WRT120N, the default password is admin. As with most passwords, the WRT120N default password is case sensitive.
In addition to the WRT120N default password, you can also see the WRT120N default username and WRT120N default IP address in the table below.
Note: The Linksys WRT120N default password may be different for certain hardware orfirmware versions.
If I have that information, I'll include the exact WRT120N version number along with the correct default password. You can usually find your Linksys WRT120N version number on the bottom of the router.
Be sure to change the default router password on your WRT120N to something more secure as soon as you're in. Then use a free password manager so you'll never forget your new WRT120N password.
Help! The WRT120N Default Password Doesn't Work!
At some point during the life of your particular Cisco Linksys WRT120N, the default password, username, and/or IP address might have been changed.
In most cases, if the Linksys WRT120N default IP address has been changed, the new IP address for the WRT120N will be the same as the default gateway IP address configured for your network connection.
See How To Find the Default Gateway IP Address for help.
In situations where the WRT120N default password or WRT120N default username has changed, you'll need to reset the Linksys WRT120N to factory defaults. You can usually do that via a special button or sequence of actions.
The WRT120N manual will have specific directions for performing a factory default reset. You can download the manual for the WRT120N from Linksys Support.
Please let me know if any of the WRT120N default login data below needs updated. For other questions about the WRT120N default information on this page, see my Default Password FAQ.
WRT120N Default Password & Other Default Login DataVersionDefault UsernameDefault PasswordDefault IPPrivilegesAll[none]admin192.168.1.1Administrator
Jan 13, 2012 | D-Link 802.11g Wireless Router WBR-1310...
Hmm
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 08, 2011 | Belkin (F5D8231-4) Wireless Router...
Reset password of DGS3627 from console
Sep 07, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
Wanted to set password om my linksys
192.168.2.1
192.168.1.1
Sep 07, 2011 | Computers & Internet
New password wifi
Sep 07, 2011 | Encore 802.11G WIRELESS LAN ROUTER...
How 2 put the password?
Sep 07, 2011 | SMC Barricade N Wireless Broadband Router...
Forgot my password and cannot reset?
Sep 06, 2011 | Computers & Internet
Default factory password
Most of the NETGEAR devices, except ReadyNAS products and Fully Managed switches, have the following default username and password:
  • Username = admin
  • Password = password
    • For older devices, password = 1234
If you have changed the default password and have forgotten it, you will need to reset the NETGEAR device to factory default settings in order to use the default username and password. Click here to learn how to reset the NETGEAR device to factory default settings. Please note: restoring a device to its factory default settings will erase any changes you have saved to the device.
This applies to:
  • Most of the NETGEAR devices such as routers and smart switches.
Aug 13, 2010 | Cell Phones
Extended Systems ExtendNet 100X Print Server Logo
Top Extended Systems Computers & Internet Experts
David Payne
David Payne
Are you an Extended Systems Computer and Internet Expert? Answer questions, earn points and help others
