Question about Weedeater Garden
Brand new FB 25 cc gas blower can't pull cord to
Brand new FB 25 cc gas blower can't pull cord to start
  • 8 Answers
SOURCE: ryobi leaf blower #8544,25.4 cc
I have a McCulloch, that the hose rotted off the fuel strainer in the tank, I replace the hoses, it ran for awhile then stopped, removed the carb. an have cleaned, { 7 Times} it runs for awhile then stops, Usually I dump lighter fluid in the carb. if it starts Ign is OK if not its a fuel problem. You could check on the filter, I still have a problem with mine, its a pain when your on the roof an it stops. so check the fuel filter is the only thing I could suggest to you GOOD LUCK
Posted on Nov 11, 2008
  • 68 Answers
SOURCE: cord won't pull out
Hi Shaun77b,
Regretfully if you didn't use a gas/oil mix the motor is probably seized. The internal parts on a 2 cycle motor are lubricated by the oil in the gas. It may keep running without oil but once it shuts off- its done.
Sorry, Phil
Posted on Dec 28, 2008
  • 49 Answers
SOURCE: Hello, My 31 cc troy
If the either burned, then you have a fuel problem. Make sure the fuel filter (in the tank) and the lines are all clear. If so, then you my need to rebiud the carburator.
Posted on Jan 30, 2009
steve_lima
  • 181 Answers
SOURCE: 32 cc blower not starting
your problem is inside the carburator.there is a small screen inside that needs to be cleaned out.take the single screw from one side of carb.there is a small screen in side.carefully take an air hose and blow it out.do not blow to hard or the screen will blow out.once it's clean the unit will start right up.hope this helped,let me know.................................
Posted on Jun 29, 2009
  • 103 Answers
SOURCE: repalce cord on gas blower
MAKE SURE YOU HAVE THE RIGHT SIZE CHORD FOR THAT STYLE,MUCH SMALLER THAN MOWER STYLE. ALSO PROBABLY HAVE IMPROPER TRACKING OF ROPE. TRY PULLING COVER BACK OFF AND MAYBE KNOT GETTING CAUGHT UP IN FLYWHEEL FROM ROPE
Posted on Jul 12, 2009
I have a ryobi2cycle blower /vac I pull the cord and it just spins how can I fix?
Leaf Blower : Pull-Start Cord - YouTube
? 7:26
https://www.youtube.com/watch?v=0bbHtbcNZ-o
Mar 25, 2011 - Uploaded by Repairs101
I'm loading the spring into the housing just by winding it in. ... Push the pull cord out first and then the pipe ...
What Stops a Pull Cord for a Gas Weeder? ' Home Guides ...
Nov 29, 2015 | Garden
Hey how are you My weed eater blower 25 cc pull cord is stuck half way and dk how to get to it
should of told us the model number... most likely have to take that whole thing apart
Aug 10, 2014 | Garden
I just bought a Sears snow thrower, I put in oil and gas went to start it but the pull cord will not pull up. I then tried the electric starter but it just made a grinding sound. Why won t it start?
Check the crankcase and make sure it has oil. It sounds like the engine is frozen. If its brand new, take it back to Sears and have them start it for you.
Dec 16, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Troy bilt sequall 2100 will not start. has new plug
Is the gas making it TO the new plug? Pull it over a dozen or so times on full choke and then pull the uh to see if its wet meaning the engine is getting fuel. Also make sure the safeties and off switches aren't preventing it from starting
Nov 18, 2013 | Troy-Bilt Squall 2100 208 cc 21-in...
Yes, I have a Craftsman 25 cc Gas Trimmer and we just snapped the starter cord. Do you have to open up the head to fix this? Does it need a special type of cord?
Yes you have to remove the plastic recoil assembly and install a certain size cord. We use a #3 or 3.5 cord on all our string trimmers, blowers with that size engine.
Aug 09, 2011 | Craftsman 25cc Gas Line Trimmer
The PB-250 will not start. It was purchased last year and used little. I have fresh gas and a new properly gaped OEM plug. I do have spark. The spark plug is wet with fuel. Can one flood the engine by...
It is very easy to flood this item mind you its easy to flood all petrol trimmers. If plug is wet simply turn the switch to off and pull cord at least 15 times you should get the engine to start coughing keep pull cord but do not turn the petrol on do not prime it either. It should catch. If it does not push the primer once and pull cord
May 31, 2017 | Echo Gas Blower 135 MPH390 CFM Blower...
Pocket bike prblems
Get some engine starting fluid and spray a small amount in the air intake. If that doesn't work take out the spark plug and see if it sparks when you pull the cord and make sure it is not fouled. If it is wet with fuel dry out the plug and pull the cord a few times to clear the cylinder. Fresh premium fuel always works best on temperamental engines.
Sep 06, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
Will not start - brand new
i bought a new dirtbike as a kid n same thing.it turned out ,it needed to be a synthedic oil in the mix.try seeing for spark to begin with by putting sparkplug in the wire n touching diode to the engine block while pulling the cord.thats a good starting point to diagnosing your problem.maybe try warming it up in the house then try starting it with no choke needed.the saws i ve used needed you to give it throttle after you pull,n no throttle with choke.
Mar 12, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Garden Logo
Top Weedeater Garden Experts
Matt Olenzek
Matt Olenzek
 steve
steve
Jerry Kramer
Jerry Kramer
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
