Question about Toshiba Tecra 750CDT (PA1253U-T2C) PC Notebook
Notebook computer T2C - Toshiba Tecra 750CDT (PA1253U-T2C) PC Notebook
DELL E6420 beeping intermittently
Hello there, I am the computer technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Ronnie Bradl.
Intermittent beeping donotes that the Notebook computer is overheating. The beep is a warning that the Processor has reached the set tempreature alarm. Usually set to 65degrees Cen.
Clean the vents of the notebook with a vaccum cleaner and paintbrush. Be sure to Remove the power and battery from the notebook. Get out as much dust as possible. In addition you could purchase a Notebook cooler.
Notebook coolers ensure that the notebook receives sufficient airflow, some coolers even have fans installed for greater performance.
When using your notebook on a table surface, raise the rear of the notebook off the table to allow for additional airflow. Be sure not to obstruct the vents. A pen or pencil may do the trick.
If the problem persists, you may need to get your notebook serviced/cleaned by a laptop computer technician.
Take care!
Feb 02, 2012 | Dell Latitude E6420 Laptop Computer...
Can man put more memory in this computer ?
Yes you can upgrade the memory, just make sure the maximum supported capacity of your notebook and the compatible brands.
Sep 08, 2011 | Sony Notebook Computers: VAIO VGN-S260...
X205-SLI1 17" Notebook PC PC Notebook 3 beep
Memory problem:
Sometimes when the computer is moved or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 23, 2011 | Toshiba Satellite X205-SLI1 Notebook
HP G60-120US 15.6" Widescreen Laptop PC Notebook: when trying to turn the computer on, the 3 lights ...
Due to regular use of the notebook, some static charges tend to stay in the computer, and sometimes results in not allowing the computer to function properly.
Please follow the power drain procedure to confirm the same:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30seconds to 1 minute.
4. Put the Battery in.
5. Reconnect the AC adapter.
6. Turn on the Notebook power.
7. Restart the Notebook.
If the Notebook boots up you may fix the battery back. Try restarting the computer only with the AC power, without the battery & vice-versa. If the issue still persists then I request you to reset the memory modules, as sometimes the memory module connection get loose.
May 17, 2010 | HP G60-120US Laptop
I have a Fujitsu Lifebook LBS6120 notebook
Turn on as you did before and leave on for 10 minutes. Then, try turning OFF the computer by keeoing the POWER button pressed for 7 secons. If the computer goes off, then your screen is fried and the computer is actually booting up normally... you just can't see it ;)
Mar 17, 2010 | Fujitsu LifeBook E8010 Notebook
I cannot enter to bios.also can not pass to windows set.as i read it supports 95,workshop 3.11 and Win NT.Firs,how i can enter to bios.Thanks.
When you power up the computer press the following key board command.
F1 or
F2 or
del key or
ESC or
ESC+F1 or
ESC +F2 or
TAB
Try above command you can see bios with 1 of them.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 25, 2010 | Toshiba Tecra 750CDT (PA1253U-T2C) PC...
Fn key
Try installing the "Sony Shared Library" and the "Sony Notebook Control Device Drive".
First install the Sony Shared Library, restart the Computer and then install the "Sony Notebook Control Device Driver" (restart the Computer again).
NOTE: Sony Shared Library is the system component which makes the download and installation of Drivers and Applications compatible with the Computer. While "Sony Notebook Control Device Drive" is utility which will enable the Function keys in the Computer.
Check this Link to download these Utilities.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCGFRV27
The Sony Shared Library will be listed under "System Components - 1 file(s)" and Sony Notebook Control Device Driver will be under "Notebook Control and Utilities - 1 file(s)".
Good Luck!!!!!!!!!!!!!!
Nov 17, 2009 | Sony VAIO FRV27 Notebook
Automatic not switch the headphone and notebook speaker
sound like u have to update your sound driver. try this link driver updater download it and install to your computer. scan your driver using after installing this software and then restart your computer. its work in acer laptop. might be it will work to your computer also.. cheers..
Mar 09, 2009 | Compaq Presario C700T Notebook
Forgot my admin password for my notebook
No worries about taking the Backup of data before reinstalling the Operating System in your Notebook.
I recommend you to remove the Hard Drive of the Notebook and connect it to the USB Port of any other computer using some cables that will be available in most of the computer part stores and copy the required files in the computer to which the hard drive is connected.
You can find the required instructions to remove the Hard Drive of your Notebook from the Manual which is available in the link below :
http://h10032.www1.hp.com/ctg/Manual/c00737799.pdf
You can find the required instructions to remove the Hard Drive of your Notebook starting from page number 100 of 233 in the Manual.
Find some cables which can be used to connect the Hard Drive of the Notebook to another computer by clicking HERE
Once the required data is saved, reinsert the Hard Drive back in the Notebook and perform a full recovery by following the instructions listed below using the Recovery Partition  with Vista :
Restart or Start the Notebook and start tapping the F11 key immideatly after the Notebook restarts.
This will take you to the Recovery Manager window.
In this, click on the Advanced button.
In this, you will get the following options :
a) Computer Checkup
b) Microsoft system restore
c) File backup wizard
d) System recovery
Click on System Recovery.
In the window that opens, you will get the options...
Do you want to back up your files first (reccomended)
or
Recover without Backing up.
You can take a backup of the data in the Hard Drive if you have any External storage devices like External Hard Drives connected to the Notebook.
Select the required option to proceed with the Recovery.
The Operating system in the Notebook will be reinstalled along with all the Preinstaled Applications and Drivers to factory default settings.
Hope this helps....
Nov 01, 2008 | HP Pavilion dv6000z Notebook
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Toshiba Tecra 750CDT (PA1253U-T2C) PC Notebook Logo
71 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
