Question about Sylvania 6319CE 19 in. TV/VCR Combo
Sylvania combo tv/vcr turns self off
Turns on for about 5 seconds, makes noise like the vcr is trying to eject, then turns itself off??
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
The rubber band that controls the eject mechanism is broke. you need to take it apart (5 screws) and attach an appropriate sized rubber band and let it complete it's initial cycle. then try not to use the vcr unless you buy the aprropriate rubber band. hope this helps.
JAY
Posted on Jun 05, 2008
Same exact problem with my Sylvania combo.
Posted on Dec 19, 2007
SOURCE:
The TV turns off when i put a VHS tape in the VCR. The tape will play for a few seconds, then the Power goes off. When i turn the Tv back on the tape immediately ejects.
Possibly have a tape drive motor issue it powers down to save itself .Thats the dickens with those combo sets they are hard to look at ,you have to take it half apart just to see whats going on
Feb 16, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Sylvania 9''--turns on, turns off by itself after 3-4
check the motor charge belt on the vcr and change it
Jan 06, 2010 | Sylvania SRC22134 13 in. TV/VCR Combo
Sylvania MTS/SAP tv/vcr/dvd combo turning itself off
could be that either the dvd or the vcr are malfunctioning, usually it is the vcr that creates the problem. If you turn tv on and set vol to low see if you can hear the noise of the motor loading or trying to load,with out a tape inside. It may be a good idea to have a qualified tech repair it, these units are difficult to work on and further problems may come up if you are not familiar with the tv.
Dec 31, 2009 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
Vcr cuts my tv off after i put the tape in
The VCR is not turning the TV power off. The tape is not playing. I'd guess maybe it needs a cleaning or a replacment.
Dec 24, 2009 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
Symphonic tv vcr combo will not eject tape
You need a new VCR belt it located on right side of the vcr tray take your finger and start rotate the belt clockwise, it should release the tape. or the motor is going bad.
Apr 25, 2009 | Symphonic SC319C 19 in. TV/VCR Combo
The tv turns on, but the tape is stuck, will not eject
the rubber band inside for the ejecting mechanism broke. you need to take it apart and reattch with a rubber band.
Apr 13, 2008 | Sylvania 6319CE 19 in. TV/VCR Combo
VCR repeatedly tries to play and eject when tape deck is empty
the tape carriage is probably stuck, or something stuck inside blocking the tape sensor.
feed a tape in and see if it does it "with" the tape too
hope this helps
Jan 08, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
Tape stuck and tv turns off
With the set unplugged remove the back and extract the main board. You'll find a metal cover over the tape housing area that is easily removed by removing some screws holding it to the board area and manipulating some wired over it... You should then be able to see the tape and what's hanging it up. If you need to unwrap tape from the pinch roller or around the guides do so carefully. When it all looks free you can either manually crank the load motor assembly to eject the tape or put it back together enough to plug it in and press eject. If you do the later be VERY careful... Good Luck! Bill
Jun 01, 2007 | Sylvania 6313CB 13 in. TV/VCR Combo
Sylvania 6319CE 19 in. TV/VCR Combo Logo
615 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
