Question about LG GSA-2164D (8801031211579) DVD±RW Dual Layer Burner
Not recognize Hi, My LG Dvd +-RW is not recognized by Windows XP Service Pack 3. It is powered by the adapter provided through the wall socket and connected to my PC via USB which also came with it. It used to work fine before, but it just doesn't seem to even be recognized as a plug-n-play device! PLEASE HELP!
  • Lestat
    Lestat Oct 19, 2013
    Thanks Naveen. I tried your solution, but no luck still. I've contacted LG support and they recommend trying new usb cables as a final option to the problem. I think I'll give that a shot. Thanks again!
    Sergeant:
  • 245 Answers
Update your windows and the restart you pc after plunging out from electricity for 3 minutes
Posted on Oct 15, 2013
5 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: Problem installing the device,keeps restarting the pc
You will probably have to install Service pack 2 to overcome this problem, which you should install for security reasons anyway. If a driver came with the DVD writer, this should generally be installed first, then the writer connected into a USB port.
Posted on Jan 03, 2007
SOURCE: lg dvd rw installation
Did you install the software first? Sometimes If you jump the gun and install the drive before the software it will not recognize it...
Try updating the driver here:
http://www.downloadtube.com/Drivers/Firmware/LG/
Posted on May 22, 2008
  • 713 Answers
SOURCE: DVD plays in DVD player is not seen at all by Windows XP
Hi,it's obvious from your problem that the particular disc that cannot be viewed on your computer is of a formatt not supported by the windows XP.some DVDs are of low quality which can be viewed practically on any DVD player but as a result of their low quality and the sensitivity of the Windows they are not recognized by your computer. In as much as other DVDS play on your computer,it means there's no problem with your computer,but an unsupported disc formatt is been trying to be viewed and there's nothing you can do to view a DVD formatt not supported by your computer.please don't be bothered.
Thanks and take care
Posted on Apr 21, 2010
madhatter639
  • 260 Answers
SOURCE: My LG DVD RW can not play DVD
Are you sure that your ROM can't play the disc or is it that you don't have a program to play the disc? To my knowledge Windows XP didn't come packaged with a DVD Decoder program; except for XP Media Center. There are some FreeWare programs out there that you can download, or you can pay for the program that decodes DVDs so that you can watch them. If your DVD isn't recognizing any type of DVD that you put into the ROM, then try playing a CD\DVD player cleaning disc in it. If that doesn't work, then you will probably have to get another DVD-ROM.
Posted on Jun 06, 2010
LG dvd external drive not recognized by computer
ERROR 43? Check your SATA connection.
HERE'S HOW I FIXED MINE.
(IE. Computer tries to install driver for BD burner, but ultimately fails, and gives the message. "Unsuccessful" and/or "Microsoft Windows stopped device. Error 43") The SATA CONNECTION on my BD burner's EXTERNAL CASE had gone bad.
TO TEST IT. I used a SATA/IDE to USB Adapter Cable I bought for about $10 on amazon.
  • I unscrewed the external case to get at the internal drive, and plugged the SATA adapter cable directly into the internal BD burner drive (bypassing the case assembly), and plugged the other end into my computer USB port.
    • PS My BD burner POWER was working OK, so I left the big white 4pin power adapter connected to the original external case.
VOILA! Both my laptop and my desktop PC recognized the LG BD burner again and assigned it a drive letter (like it used to do).
  • Now I either need to (1) Buy a NEW EXTERNAL case ($10 - $30), (2) install it as an internal drive (could get problematic if "ANYDVD" is installed) or (3) just leave it connected via the cheap adapter cable.
It's super EASY (& inexpensive) to TEST this before spending $$$$ on a new equipment.
Hope this helps someone. It had me miffed for a while there.
Jan 02, 2014 | LG GSA-2166D DVD RW Dual Layer Burner
I have a NEC DVD RW ND-3530a and my windows xp service pack 3 stopped recognizing it. it no longer reads as a drive. The device manager has it listed with a yellow !. I have tried uninstalling and...
Remove the drive from your computer, and temporarily connect it to another desktop computer.
If it still does not work, then it's time to responsibly recycle it, and spend $40 to purchase a new CD/DVD reader/writer.
Dec 10, 2010 | NEC ND-3540A DVD RW Dual Layer Burner
Device not detect dvd portable external lg GP08NU20 in windows xp, problem usb
ok... Xp both home and pro editions may require you do the updates... if you have not done so lately, you might want to do it now.... go to windows update to see if you still have to update... make sure you also have service pack 3 installed... LG also comes with it's own software for you to install on CD Rom... if you have it and it does not install right away, you might have to do it manually or go to you CD Rom and right click explore to see the files to install it.. Good Luck To You
Oct 18, 2010 | LG GP08NU20 DVD±RW Burner
Can I Play gta IV/4 on my pc? Specs Ar As Follow: DELL PRECISION 650 With: 2X Seprate Intel Xenon CPU's @ 2.40Ghz Each (4.80Ghz Tot) 1.50GB RAM (Memory) 80GB IDE Primary, 40Gb IDE Seccondary, 40GB...
Minimum System Requirements
  • OS: Windows Vista - Service Pack 1 / XP - Service Pack 3
  • Processor: Intel Core 2 Duo 1.8Ghz, AMD Athlon X2 64 2.4Ghz
  • Memory: 1.5GB, 16GB Free Hard Drive Space
  • Video Card: 256MB NVIDIA 7900 / 256MB ATI X1900
Recommended System Requirements
  • Processor: Intel Core 2 Quad 2.4Ghz, AMD Phenom X3 2.1Ghz
  • Memory: 2 GB (Windows XP) 2.5 GB (Windows Vista)
  • 18 GB Free Hard Drive Space
  • Video Card: 512MB NVIDIA 8600 / 512MB ATI 3870
Source :- IGN PC
this is what it says on the box...so if you dont have these specs..forgett it!!
Jun 15, 2010 | Rockstar Games Grand Theft Auto™ IV for...
Jun 06, 2010 | LG GSA-H42N 18x DVD RW DL IDE Drive...
Apr 21, 2010 | LG SecurDisc 20x Internal Double-Layer DVD...
Windows xp doesn't recognize set top box
you need to downlaod the appropiate "loader" software for your box!
Feb 27, 2009 | LG GSA-2166D DVD RW Dual Layer Burner
LG GSA-E60L doesn't work...
Disc drive has nothing with drivers it works in almost any operating system...check the power and data cables
Feb 03, 2009 | LG SecurDisc 20x External Double-Layer DVD...
Remote drive not recognized by lap top
sir
the sony DVD -RW/ take out from the cabinet and open safely and dont tuch the lence. in that a small roller will be there the magnet power will increases that why running peoblem will accurs on the moving part put a lite profile and cleane it and fixed it right ly the problem will go.
Mar 26, 2008 | Computers & Internet
SONY DVD RW AW-G170a
This is a problem with the DVD Writer model. SONY DVD RW AW-G170a has problems reading DVD+/- R/RW Discs. But there is no problem with any of the DVD+/- R/RW Dual Layer, DVD Ram or CD+/- R/RW Discs. It is the reason that this DVD Writer lacks the correct bitsetting for DVD+/- R/RW Discs. There is nothing else you could do other than replacing the wirter with some other model.
Aug 01, 2007 | Sony (1-796-293-13) Plug-In Module DVD...
LG GSA-2164D (8801031211579) DVD±RW Dual Layer Burner Logo
76 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
