Question about JVC Kd-r210 Car CD/ MP3 Player
Wire harness i need a wire diagrahm for a jvc r-210
3 Suggested Answers
etirbynnor
  • 655 Answers
SOURCE: color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Posted on Apr 24, 2009
iadame
  • 676 Answers
SOURCE: Need wiring diagrahm for jvc ks-r135
Hello here is a diagram to help you out.
Posted on Mar 24, 2011
My jvc stereo will not power up but have found the black wire is live ?
hi peter, before you start using the rest of the harness cables find out if the harness you have is a jvc original for your model. the black wire is the ground/chassis cable only for a jvc kd-r411. you mite be using a compatible fitting harness whose " wire colour configuration" is incorrect for your model. cheers.
Mar 02, 2013 | JVC AM FM CD DET FACE CAR STEREO
JVC headunit oranges with white stripe (illumination wire).
As far as I know, If the illumination wire is connected, the radio dims the display when headlight is turned on.
Feb 20, 2012 | JVC Car Audio & Video
I am replacinng the factory stereo with a JVC unit. The harness for the original has two orange wires, one plain the other with a black stripe, and the JVC one doesn't. What are these for and are they...
the orange wire in the #8 cavity is your key on power wire, so yes you need it the yellow wire in the #1 cavity is the 12 volt alwise wire so you need it as well the orange wire in the #10 cavity is the right rear speaker wire + you also need it hear is the wire list.
wire #1. yellow 12 power with key on
wire #2. gray interior lights
wire #3. green right rear speaker -
wire #4. red right front speaker +
wire #5 black left front speaker -
wire #6 brown left rear speaker -
wire #7 gray power antenna
wire #8 orange 12 volt power hot all times
wire #9 pink interior lights
wire #10 orange right front speaker +
wire#11 blue right front speaker + ( door )
wire #12 empty
wire #13 empty
wire #14 yellow left front speaker + (door)
wire #15 white left rear speaker +
wire #16 black/orange ground
Apr 17, 2011 | 2004 Kia Optima
Mar 24, 2011 | JVC Car Audio & Video
Looking for a wiring diagrahm for my ford lgt 125
You should price out a wiring harness,they are usually not that expensive and can be replaced fairly easily,may be the cheapest way out of your problem.
May 16, 2010 | Ford Garden
Installing a cd player in a 1992 honda accord
The harness looks like what is depicted on this link: http://cgi.ebay.com/JVC--16-PIN-WIRE-HARNESS-FOR-CD-PLAYER-BLACK-BRAND-NEW_W0QQitemZ370214069143QQcmdZViewItemQQimsxZ20090612?IMSfp=TL090612198008r8862
This connector fits the following JVC Car Radio/CD/MP3 Players with 16 pin connection.
All wires are labeled.
Hope this helps....................sodeep
Jul 26, 2009 | JVC KD-G220 CD Player
I NEED A WIRING GIAGRAM BECAUSE THEIRE IS NO COLOR TO COLOR PATTERN ON BACK OF MY JVC-KD-G320
This may help your cause
http://www.nodevice.com/manual/JVC/page24.html
Jun 11, 2009 | JVC KD-G320 CD Player
Connect jvc kd-lh1150 in elantra 2001... different connector
Hello claude_bouth,You need a vehicle specific aftermarket connector generally called a "wiring harness". Your JVC came with a plug that fits the back of the receiver with "pigtail" wires which you splice to the harness wires. http://www.SonicElectronix.com sells the Metra 70-7301 which appears to be the correct harness for your Elantra.You can tap into the wiring of the car harness and splice the wires by function into the appropriate car wires, but using the aftermarket vehicle specific wiring harness is a lot easier and you don't need to disturb the vehicle wiring in any way, just plug into it. It also makes it possible to re-install the factory radio if you ever need to do so. If you choose to tap and splice, you can find your Elantra's wiring color code at http://www.modifiedlife.com.Hope this helps.
Jun 05, 2009 | JVC Arsenal KD-LH1150 CD Player
Wiring my jvc kd-g331 to a 1996 vauxhall corsa
You can go to a place that installs car stereos and purchase a universal wiring harness for your car that will cost about $15 and allow you to do the wiring very easy without the need to know what every wire is for. This harness would be wired to the harness you got from JVC for your new radio and all you need to do is to match the colors of the JVC harness to the same colors of the universal harness that would then just plug right into the factory wiring harness for your car and then the other end plugs into the connector for your JVC radio. It is very easy and insures that you have all the proper wires connected to operate your radio and have full functions available for use.
If you require to know what each wire from the JVC harness is for, just ask.
I would be happy to offer you more help if you need it, just reply to this post and I will get back to you as soon as I am able.
If you found this free information to be useful a FixYa! rating would be appropiate and very much appreciated. After all, it is the only reward we get for helping people like yourself for free.
Thanks and good luck with your radio installation,
Dave
Sep 04, 2008 | JVC Car Audio & Video
JVC Kd-r210 Car CD/ MP3 Player Logo
54 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
