Black spot lcd tv screen
A spot developed on screen with its screen sticker.when a part of screen card is removed a bad smell is just got but problem is not solved .it just buyed before six or seven month.how to solve this
    Sergeant:
  • 245 Answers
Please call the engineer from the tv co . Its due to display ic fault !
Posted on Oct 15, 2013
  • 103 Answers
SOURCE: Sharp 42" flat screen LCD T.V.
You have a bad buffer ic,which is part of the lcd panel.Definiately call sharp to get it repaired.If it doesn't have a warranty,persistence through sharp will get you results.
Posted on Mar 07, 2008
SOURCE: Philips 300wn5 green stripe on screen
I have a similar problem, what is the fix?
Posted on Jun 30, 2008
  • 8 Answers
SOURCE: LN37A550 LCD TV has washed out image
It is possible the problem is caused by a wrong option byte setting in the service menu. The correct setting depends on the type LCD panel used in that version. Version number can be found on a sticker on the right side of the television. A bad main board or TCON board can also cause that type of problem.
Posted on Jan 30, 2009
  • 92 Answers
SOURCE: same problem, vizio 47" LCD TV, six month old
change out the LVDS cable (the cable that go from the control board to the main board) and it should resolve your problem. If your TV is still in warranty, call 1-877-MY-VIZIO and they will set up an in home repair for free.
Posted on Jul 01, 2009
Raditronic
  • 196 Answers
SOURCE: Light blue tiny spots on the flat panel
Bad Optical Unit Block The part # is A-1084-658-A
Posted on Apr 20, 2010
Sanyo dp42848 black spots and scrambled screen
Black spot means the LCD panel is faulty. Its better to go for new tv than rearing this one.
www.electro-medical.blogspot.com
Oct 07, 2015 | Sanyo DP42848 LCD TV
Black spots
it happens when a laptop falls from a height .. screen gets damaged ..
led/lcd screen needs to be replaced !
Jun 28, 2013 | Dell Inspiron Computers & Internet
CRACKED 46inch LCD SCREEN
you can find replacement panels but expect to pay $250 plus for one. You will need to take the back cover off the set and get the panel model # off the back of the panel. There should be a white sticker on the back of the panel stating the model #. You will need to get a replacement panel that matches your model # EXACTLY
Oct 13, 2012 | Sharp Televison & Video
My camera has developed small cluster of dark spots on the LCD screen interface, the pictures however are fine with no such marks when developed or viewed on any other media device. At first, It was one...
Mine has been doing this too! The spots are getting so large that it covers 1/4 of the screen. I'm sending mine in to get repaired because it came with a 1 year warrenty.
May 10, 2011 | Olympus SP600UZ Digital Camera
A spot developed in center of screen next day black lines across screen from the original spot
it sounds like you have a small crack on your screen that has gotten worse over time, these black areas are where the lcd crystals aren't active anymore, unfortunately there isn't allot you can do apart from buy a new screen or put up with the black lines.
May 02, 2011 | Gateway FPD 1730 17" Flat Panel LCD...
I have a Philpis 42" LCD TV Model # 42TA648BX/F7. Basically, I know the Power supply board is bad (it was not functional when I aquired)). Obviously someone previously had it diagnosed and got sticker...
Appears that the only other major component is the Servkit assembly
http://www.partstore.com/Model/Royal+Philips+Electronics/Philips/42TA648BXF7.aspx?SearchTerm=True
Sep 28, 2010 | Philips 42TA648BX 42 in. LCD TV
Black Spot on Soyo LCD Screen
to get rid of it you will need to replace the screen.
Aug 19, 2009 | Televison & Video
Sharp front panel replacement for 42" LCD t.v. (Black)
I just removed my sticker today, and the sticky adhesive would not come my tv either. I tried alcohol first and to that only worked a little. Then I even tried warm soapy water(thats what sharps customer service told me to do) but that didnt work. So I put a razor scraper inside a rag with soap and water on it and that put little scratches on my new shiny black bezzel which made me very mad. The scratches arent really bad but who wants that on a new tv. FINALLY THE ONLY THING THAT WORKED WAS THE WD-40 NO MESS PEN. YOU RUB THAT ON THE STICKY ADHESIVE THEN WIPE OFF WITH WARM SOAPY WATER, WORKS REALLY WELL ONLY DID IT 2 TIMES. TO BAD I DIDNT DO THAT BEFORE ALL THE SCRATCHES. IF YOU DONT HAVE THE PEN I THINK YOU CAN JUST SPRAY REGULAR WD-40 ONTO A RAG AND WIPE.
Dec 20, 2008 | Sharp LC-42D43U 42 in. LCD HDTV
Spot on LCD screen
I would call the company anyway and complain! A lot of times they will fix the product Free of charge if you have ran over your warranty (screen will need replaced!)
Dec 19, 2008 | Cameras
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
