Question about LG Washing Machines
Lg wd 10165
My washing machine keeps on tripping the electricity. I have changed the plug, plugged it into another socket, but the problem stays the same. What can I do to rectify the problem
  • michfourie
    michfourie Oct 15, 2013
    where do I find the element on my washing machine?
    Sergeant:
  • 245 Answers
Check the load of clothes in your machine ! Unload it! And turn it on empty! Check if its working ! If yes then reduce the quantity of cloths you are putting in
Posted on Oct 15, 2013
  • 3 Answers
SOURCE: washing machine
it is possible the heater is at fault try this first / then check motor / after these there could be an exposed wire shorting on the chassis . always remove plug from mains when carring out checks . good luck
Posted on Apr 20, 2008
barkencoa
  • 3463 Answers
SOURCE: electric trips when switch on switch on socket
There is obviously an electrical problem that is causing the trip to operate try it in another socket, then check the plug , if o/k, then it is a case of open ing the washer up to try and locate the prob,
At this stage, it literally could be anything, from a faulty motor, faulty heater, faulty suppressor, the list is endless.
Plz rate my comments.
Thanks.
Posted on Jan 09, 2009
SOURCE: Hotpoint WM51 Washing Machine keeps tripping the electric
I had this problem; it was the motor arthing out on the body. It took a repair man half an hour to sort and it cost me £35. Hope this helps. Domo.
Posted on Feb 08, 2009
barkencoa
  • 3463 Answers
SOURCE: Washing machine trips electric when fills with water
From the symptons described, I would suspect that the heating element is faulty, disconnect the heater, and try it again, if it does not trip, then replace heater.
Please rate my solution.
Thanks.
Posted on Aug 15, 2009
SOURCE: my indesit WDC6125 washer dryer trips the
10 month old Indesit WIXL143 washing machine lights up for 2 seconds then trips mains off in flat.Have changed fuse in plug. I squeezed machine into small space and drainage tube gives off foul smelling problem cos it wasn`t long enough at back. But why now is it tripping? Where do I turn? Am on benefits
Posted on Mar 11, 2010
Hoover primera washing machine keeps tripping electrics when tured on.
Possible that there is higher current drain which trips off the circuit. This can be due to moisture or dampness in the circuit , coils or the motor. You need to remove the top panel and dry using a dryer. check the connectors, check the main line , the motor circuit. Isolation of the motor or the heater can confirm the short if the circuit stays. Check the main power to the panel and allied circuit for possible capacitor leak or short.
Mar 16, 2013 | Washing Machines
Electrical short
We will be able to help you further if you supply the following information.
What is the make and model number of your unit?
Oct 15, 2012 | Washing Machines
My zanussi washer dryer keeps tripping the electrics
check ground wire for tightness on plug in and on breaker box.
Mar 31, 2012 | Zanussi ZWD12270 Front Load Washer / Dryer
My washing machine it tripping the mains board out, changes plugs and sockets and its still doing it - any ideas? perhaps the bushes?
sounds like water is getting into the electrics....or your trip circuit has became week...try switching the trip switch from another circuit.
Jul 21, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Thanks.
Aug 15, 2009 | Washing Machines
Hoover VHD Washing machine
Surely it is the wall socket.
Mar 19, 2008 | Washing Machines
Washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Jan 16, 2008 | Washing Machines
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
