Question about Merida Cycling
I need a carbon swingarm for a merida 96 hfs 1000
    Scholar:
  • 97 Answers
Can only suggest trying to find a used bike or frame to raid for the spare part you need. Check whether different frame sizes have identical swingarms before buying.
Posted on Oct 15, 2013
Cannondale swingarm replacement
Only Moto1 swingarms fit on them. Swingarms are specific to models.
Nov 08, 2012 | Cannondale Cycling
I have a merida am 5000 frame and would like to know if a FOX RACING SHOX F100RL with remote lockout, 9mm quick release 1 1/8 steerer at 200mm
This fork will fit in your frame but if your frame size is too big or you need to put your stem too high, the steerer tube may be too short. However, for this frame, a fork with longer travel will be preferable as it will give the bike better geometry for descending and technical trail features.
If this fork is new, remember that a crown race has to be pressed on.
Mar 10, 2011 | Merida AM 5000-D
Can you swop a fzr 600 swingarm for a 1000 swingarm
Hi, Stawild02 after careful deliberation 4 out 5 Yamaha Gods give this one a thumbs up, but just to be on the safe side you should give your local dealer's parts/service department a call to confirm. For more information about your question and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
View topic My Research on SWING ARM SWAPS
FZR600 swingarm swap to R6 The FZR Forum
https://www.tradebit.com/filedetail.php/2864660-yamaha-fzr-600-service-repair-manual-pdf
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-fz-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 07, 2010 | 1995 Yamaha FZR 600
How do i adjust the chain on a ducati multistrada 1000ds thanks
You pull it of course. Nach... first put the bike on its centre stand then look at the end of your swing arms (both) there should be an adjuster where you loosen the bolt/nut and slide it back toward you by wheel axle. It normally tells you if you are in the same distance for both side. Tighten the bolt/nut and off you go.
Mar 23, 2010 | 2004 Ducati Multistrada 1000 DS
How to fix obd2 code 1443 on 96 ford ranger emisson test failed
It is usually carbon pieces from the evap carbon canister clogging the purge solenoid and purge flow sensor. There should still be a one piece purge solenoid and purge sensor with hose assembly available. You will also need to replace the carbon storage canister.
After replacement disconnect the negative battery cable, hold your foot on the brake pedal for 30 seconds, then reconnect the battery.
Oct 25, 2009 | 1996 Ford Ranger SuperCab
I would like info on where I can find wide tire frame or swingarm 4 72 ironhead sporty. jim
I bought a 160/80 16 from Grape Valley Coppers in Masterton about $150.00 Ph 0272557932 063702213 put it on a 6" rim had to off set spockets and modified caliper also offset shock mounts
It fitted inside the swingarm with a little stretching not much clearances but seems to go all right
Oct 02, 2009 | 1979 Harley Davidson XLH 1000 Sportster
Installing an exhaust
but I was curious if I need some sort of rubber seal or a sealing compound for it. Thanks a lot!No you dont absolutly need it but it would be smart to have because I had the same thing happen on my yz125 and the carbon went everywhere and staind my swingarm. I just used a piece of old radiator tube because it was cheap and I didn't have to order it.,
Nov 10, 2008 | 2005 KTM EXC 125
Cycling Logo
81 people viewed this question
Top Merida Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Merida Cycling Expert? Answer questions, earn points and help others
