Indesit omega 1100
Hi, the emptying light on my machine is flashing constantly. I cant change the cycle also, it just stays constantly with the emptying light flashing. Any help would be much appreciated. Thank-you.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 53 Answers
Just press the drum inside the m/c then check
Posted on Oct 15, 2013
  • 1462 Answers
SOURCE: Machine stuck mid cycle
filter blocked or brawire or similiar in drain pump take off cover at bottom rear. take of hose going to bottom of tub. filter is in that hose you will have water everywhere. one way round that is to lay machine on side - left side down viewed from rear
Posted on Mar 20, 2007
SOURCE: flashing lights indesit wil103
you will need to unplug the machine at the mains, give it two minutes and the auto door lock will release your duvet, however start saving the pennies as your pcb is knackered and you'll be looking at about £200 to fix it
Posted on Oct 25, 2007
  • 24 Answers
SOURCE: Washing Machine Door is jammed (Indesit WD12x): I
UNPLUG IT
Posted on Oct 13, 2009
barkencoa
  • 3463 Answers
SOURCE: indesit washing machine wixe127 has f04 faultcode
Error code F04 indicates pressure switch jammed on empty.
to rectify, do the following
Remove lower rear panel of washer.
Remove large black hose on drum
Remove and clean filter inside hose.
Remove hose onto pump and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Posted on Jan 25, 2010
  • 3 Answers
SOURCE: Hi, we have an Indesit WIXL 143(UK)washing
This probably happens after the main wash has completed and it is just finishing the first rinse. It seems to be a warning that there is a partial blockage on the waste outflow. Empty the wash and use the DRAIN program to get as much water out as possible. From the FRONT of the machine open the lower flap and and then put a large towel on the floor. Unscrew the big black filter cover slowly - some water will come out -about a cupful. Ensuring the machine is turned off, use a cloth to remove any obvious build up of "gunk". Would suggest using an old toothbrush to clean off the surface and the plug.
99% of the time - Job Done!
You may have a blockage in your waste pipe. (If using an extension check any coupling has not "bunged up".
Last, check your waste pipe / grey water connection. Again, this "should" be fine, but it may be bunged up, especially if it feeds into the sink outflow.
Stick back together, plug in and use the 11, fast wash option in cold. Should now be happy, and you should hear water gurgling away noisily down the waste.
Always worth doing a 2 - 90 extra hot wash once in a while even EMPTY of washing just to "flush the system" now and again.
Hope this helps and saves you a £104 service engineer call from indesit :)
Posted on Mar 10, 2010
Indesit washing machine
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Oct 14, 2015 | Kenmore 24032\24036 Top Load Washer
Indesit DIF04UK: Help with problem determination please?
Modifying a wash cycle in progress:
If a mistake was made during the wash cycle selection process it is possible to change the cycle, provided that it has only just begun: open the door, taking care to avoid the escaping steam, and press and hold the ON/OFF button; the machine will switch off with a long beep. Switch the machine back on using the ON/OFF button and select the new wash cycle using the SELECT WASH CYCLE button; start the cycle by closing the door.
Dado
Sep 08, 2014 | Indesit Dishwashers
Indesit omega 1100
the capasitor is basted.
replace the capacitor
Aug 07, 2013 | Washing Machines
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
All lights flash on indesit washing machine soon after switch on
Indesit washing machine lights come on briefly when awitched on at mains and then no power
Feb 17, 2010 | Indesit W 123 Front Load Washer
washing machine working until final drain, rinse and spin then 3 lights flashing, door lock, stain removal and extra spin.
Unable to empty machine or unlock door.
any suggestions
May 15, 2008 | Washing Machines
Indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Feb 26, 2008 | Indesit W 123 Front Load Washer
Indesit w123 washing machine
Suggestion: The pipe behind your machine has to have a certain height (the machine drain pipe); it does not go directly into the drain at floor level. Check this out.
May 22, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
