Question about Hotpoint Dryers
My hotpoint dryer aqc9bf5e dial is not selecting drying options...it's turning loosely around
  • 92 Answers
SOURCE: LG DLE2532W Electric Dryer doesn't allow adjustment of drying options
it may be possible the contol is bad can you change the settings at all
Posted on Feb 10, 2008
  • 92 Answers
SOURCE: DLG2532W - LG Gas Dryer - Not spinning/working
COULD BE A DOOR SWITCH A THERMAL FUSE A CONTROL BOARD OR A MOTOR
YOU'LL PROBOBLY NEED TO CALL FOR SERVICE
Posted on Feb 22, 2008
kachbibi1
  • 979 Answers
SOURCE: Dryer only shuts off and restarts during cycle
Get a new timer. It is not that expensive and the wiring is fairly simple.
Posted on Jan 14, 2009
jumptrout51
  • 3361 Answers
SOURCE: GE dry is making a noise like loose change is rolling around
There may be change rolling around in it.
Remove the top. Take the screws out of the drum baffles and remove the coins from inside the dryer drum baffles.
When replacing them, tighten them well to help prevent coins from getting in there.
Posted on Mar 23, 2009
ned_san_jose
  • 234 Answers
SOURCE: dryer never turns off
It's the timer indefinitely. The no heat problem probably occured due to insufficient air-flow.
Go outside and check the flow. Rule of thumb:
you should be able to have your hand a foot and a half away and still feel air. good luck :)
Posted on Jul 13, 2009
The dial on the cycles never advances to the "off" position
The timer is shot. Replace it. Check around there are places that rebuild them, sometimes at half the cost.
Aug 10, 2014 | GE GTDL200EMWW 27" Front-Load Electric...
Hotpoint tdc 30 not getting hot enough to dry
Remove and clean all filters, and make sure you have the correct heat setting selected
P[lease rate my solution.
Thnks.
Nov 15, 2009 | Hotpoint TDC32 Electric Dryer
Timer button won't rotate and dry time is very long
The timer has a little motor in it that causes it to turn and it sounds like it has failed. I'm assuming you can manually turn the timer all the way around. If you can, then it is not mechanically stuck. It's the motor within the timer.
Replace the timer/controller.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Hotpoint NWSR483EBWW Electric Dryer
Hotpoint Aquarius WDD440 washer and dryer
Possibly Pump blocked. or impeller broken. without taking a proper look but sounds the obvious.
Jul 26, 2009 | Hotpoint Aquarius WD63 Front Load...
Dryer runs and doesn't stop based on the selected dry time
Check the connections to the timer dial. If all connected, replace the timer. Should solve the issue
May 08, 2009 | Dryers
Hotpoint Aquarius Tumble Dryer TDL 31
Replaced with a new unit as not cost effective to repair.
Feb 16, 2009 | Hotpoint TDC32 Electric Dryer
Door wont open on my hotpoint aquarius washer/dryer
Turn the dryer dial to off, making sure you can hear it click off, wait 1 min, and then try door. If it will still not open then you may have faulty door lock, or a prob with the door handle.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Programing a wash without drying
I had the dial on the wrong setting sorry to be a pain
Julie
Dec 01, 2008 | Hotpoint Aquarius WD63 Front Load...
Sensor dry level
quite possible that only a few selections will allow you to override "dryness" level feature. certain options are preset and dont alllow change.
Oct 21, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryer keeps cutting out
Dryer outlet hose could be plugged or restricted not letting adequate air cirulate. Check this and the filter to be sure both are clear of obstructions. Make sure the flapper at the end of the dryer vent is working correctly.... A blocked vent will cause the temp to get too high and the unit shuts down rather than burn down the house.
Jan 11, 2008 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
19 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
