You didnt provide the type of safe but on mine the bottom of the keypad lock mechanism has a compartment for the battery. Mine doesnt need to be opened to change the battery. If your has a compartment if you push on it it will pop open then you just change the battery.
DSLReports
Aug 5, 2007 - 19 posts - 8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
connect the pad to your computer and open iTunes, turn off the ipad, then hold both the lock and the home button for 10 seconds, then release the lock button while continuing to hold the home button until iTunes recognizes the iPad.
You can reset it using iTunes. Open iTunes, plug the iPod in using USB, then turn of the iPod, once it's off hold down the home and lock buttons for 10 seconds, then release the lock button while continuing to hold the home button. After a few seconds iTunes should detect the iPod and let you restore it without the code.
then turn of the iPhone, once it's off hold down the home and lock buttons
the home button. After a few seconds iTunes should detect the iPhone. Then
you should be able to restore the iPhone back to factory defaults. Even if you forgot the password.
You need to try to do a hard reset, then a restore. Follow instructions below:
1. Hold down home and power button together until screen turns completely black.
2. Open up iTunes on your computer
3. While holding down the home button, plug your iPhone into your computer and continue holding down home button until iTunes recognizes the iPhone
4. Should see dialog box from iTunes saying, "iTunes has detected an iPhone in Recovery Mode, you must restore this device"
Hope this helps, Please Rate Me!
