Question about Apple ~:~ BROTHER INTERNATIONAL CORP ~:~ MFC9440CN MF Color Laser w/Copy, Scan, Fax and Network All-In-One Printer
Unable to print pictures from my coolpix camera
I am unable to print pictures from my camera plugged directly into my MFC Brother 9440 camera--always comes back printer error--check printer status
  • 5,660 Answers
Do you have your camera software installed on your computer?
You need the drivers for your camera.
Drivers are small pieces of software that allow the device, (In this case your camera) to 'communicate' with the Operating System.
(MAC OS X 10.5.5 {Leopard} is an example of an Operating System)
Plug your camera into your computer. Print from your computer.
Posted on Apr 24, 2009
Print unable 71
Print Unable 71 means Polygon Mirror Failure on the Brother HL-4040, MFC-9840 and MFC-9440.
Pretty safe to say it means the same thing on the MFC-8880.
The Polygon Mirror is part of the Laser Unit, and its rpm isn't within specs.
The Laser Unit must be replaced.
Jan 08, 2015 | Brother MFC-8880DN Mono Multifunction...
PRINT UNABLE 32
This usually works.
MFC- 9440, 9840cdw Print Unable 32
Usually caused by a sticking density sensor solenoid and can easily be repaired.
  • Remove the rear cover
  • Remove the fuser
  • Remove the Hi Voltage PCB
  • Check the angled density sensor window for sticking. When you move it, it should spring right back. If it hesitates at all, repair the solenoid.
  • Remove the old foam and replace it with adhesive labels.
  • Reassemble machine and test.
Apr 09, 2014 | Brother MFC-9840CDW Laser Printer
What does the error code "Print unable 2A" mean specifically? This is on a Brother MFC 9440 CN, about 1 year old.
The problem is with the Fuser thermistor. The thermistor detects & heats the fuser temperatures. When this error comes up it means that the fuser thermister is not function corretly.
Unfortunatly it cant be reset so it will have to be replaced.
Good luck!!
Aug 02, 2010 | Office Equipment & Supplies
How do I set Brother 9440 MFC to print using black cartridge only?
You can set the MFC-9440CN to print with the black toner cartridge only through the printer drivers.
If you are using Mac, this needs to be changed before you print or set a preset.
If you are using windows, follow the below steps.
1. Go to Start menu \ Control Panel \ Printers (devices and printers for windows 7)
2. Right click on the MFC-9440CN and select "printing preferences"
3. Under the "basic" tab, you will see "color mode"; simply select "mono"
Thank you,
Mar 28, 2010 | Brother MFC-9440CN Laser Printer
MFC-9440 CN Laser Printer is producing vertical color line streak
Colored vertical streaks - looks like a transfer belt problem, and it's not user fixable. You may need a new belt unit - you can find it for around US$ 80-120, but you may want to have a technician inspect the unit first, since it could arguably be the drum instead, and you don't want to fork around US$ 100 and replace the wrong part.
You can try showing a printer sample at a print shop; by looking at the streaks it is possible to diagnose drum, fuser or belt problems.
Here you find a much more detailed page, for another printer model, but the issues are mainly the same for most color printers:
http://www.laserquipt.com/support/idx/26/452/article/Toner-Smearing-Issues.html
Mar 25, 2010 | Brother MFC-9440CN Laser Printer
I have a Brother MFC 9440 CN All in one printer and it says unable to print routine maitenance help!
this message normally indicates a physical problem somewhere on the machine, try turning it off for a couple of minutes then back on. if it keeps giving you this message it should at least give you the error number as well
Mar 24, 2010 | Brother MFC-9420CN All-In-One Laser...
Black dots on printed page from Brother 9440 color laser printer
The problem lies with the black toner cartridge. This is a common problem in these machines due to poor design by Brother. Best solution is to replace the offending color toner cartridge.
Jan 18, 2010 | Brother MFC-9440CN Laser Printer
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
Error messages
I can't help directly but if you go here to the (Australian) support site
http://www.brother.com.au/customersupport/customersupport.asp
you may find your answer.
Note You may need to contact them direct to get your answer.
Good luck.
May 11, 2008 | Brother Multi-Function Center MFC-240C...
Apple ~:~ BROTHER INTERNATIONAL CORP ~:~ MFC9440CN MF Color Laser w/Copy, Scan, Fax and Network All-In-One Printer Logo
65 people viewed this question
Top Apple Office Equipment & Supplies Experts
jasbo
jasbo
Abdul Mannan
Abdul Mannan
k24674
Are you an Apple Office Equipment and Supply Expert? Answer questions, earn points and help others
