Question about HP ProLiant ML150 G2 Server
Controller monitor failed
Controller monitor initializing... fatal error controller monitor failed. controller not started
I have IBM Server x3400 Tower . I got Error message Fatal error : Controller Monitor failed. Controller not started Press any key to continue
Welcome to Fixya
The problem is with the raid controller . Either the controller is faulty or it is due to dust or happen some shake. To rectify this issue do the following
1: Switch off the server 2: Remove the Raid controller from the server and clean the dust . ( Please Don't touch with hand just blow air ) 3: Clean the Controller slot 4: Refix the Controller and power on the server . 5: Check whether the controller is booting or not . 6: If you gets same problem then replace the controller
Thanks
Feb 14, 2011 | IBM x3400 Server
Question: I have one server for IBM X3400. this con't booting that problem was Fatal error: controller monitor failed conterollre not started . .
I have one server for IBM X3400. this can't booting that problem was controller monitor failed controller not started
Dec 15, 2010 | IBM x3400 Server
Getting error message on ibm x3400 Fatal Error Controller Monitor Failed Controller Not Started
dear sir in my server IBM X3400 has a problem due to RAM it might be corrupted or out of order bcause system gives continues beep when i change the RAM with HCL 1 GB DDR2 (Previous RAM was also 1 GB) it gives error:
waiting for controller to start
FATAL ERROR: controller kernel self test failed
<< press any key to continue>>
please solve the problem
Oct 28, 2010 | IBM x3400 Server
Replace the flat cable on the motherboard of SAS1 to SAS2. Resolved.
Dec 09, 2009 | IBM x3400 Server
Ibmserver x3400 fatal error
Have you checked the IBM website for BIOS and any firmware to download and update for the controller? It can get to be a maze with server cards.
Jul 07, 2009 | IBM x3400 Server
Enteri am having a big problem with my acer 5315 laptop it keeps coming up with a blank black screen and at the start screen after logo it says windows failed to start. a recent hardware or software change...
I might advise you reformat the operating system of the computer, or check the peripheral devices for this computer if properly connected? You got a fatal error it means that there is something that is not reading by the memory of the computer.
Mar 16, 2009 | Computers & Internet
Emachine will not start up it says fatal error regeristery not updated, then turns off
Linux and UNIX ld command help -z defs, Force a fatal error if any undefined symbols remain at the end of the ... which are marked lazyload will not be loaded at initial process startup
E-mail CHID: 5369 Unfortunately we were unable to find anything about the Fatal Exception error message you are encountering we suggest you go through the basic fatal.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | E-Machines eMachines Desktop PC
Computer is showing fatal error
That fatal error warning message is not coming from your operating system - it is coming from a virus. Do not follow whatever instructions boxes like that may tell you until after the following process.
Turn on your machine's firewall and tick NO EXCEPTIONS. Download an anti-virus product like AVG from download.com. Install it, update it until it says it has all updates, and then do a complete scan of your machine removing viruses.
Reboot.
Navigate to WINDOWS UPDATE on your start bar and allow it to install all updates it can, even optional ones.
Reboot.
Go to ADD REMOVE PROGRAMS from CONTROL PANEL and remove all security software besides the anti-virus you just installed, since this software has failed and is now unreliable.
Good luck...
Nov 18, 2007 | Compaq fs740 17" CRT Monitor
HP ProLiant ML150 G2 Server Logo
63 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
