Question about Zebra Symbol MC3190G Handheld Mobile Computer
Where can i find regsave tool for MC3190G WinCE 6.0
How do i get the internet explorer message that appears from time to time off the screen of motorola mc3190 without having to shut it down
The key combination you looking for to close any window or message in a Windows environment is ALT+F4, depending on the type of keypad the Motorola MC3190G are using.
Please Note: Keypad functions can be changed by an application so the mobile computer keypad may not function as described.
48-Key Keypad
The ALT functions are indicated in blue on the keypad, so in order to use these, you have to activate the ALT Functions first by pressing the BLUE BUTTON (FUNC) (Right side below ENTER button) and then press the CTRL BUTTON (left side below BKSP button).
After the key combination is pressed, the ALT icon appears on the taskbar on WinCE devices or the ALT icon appears at the bottom of the screen on Windows Mobile 6.5 devices.
Now you can press the "D" button to use F4, this will close any window or message that is currently in view.
38-key Keypad
Press the blue FUNC BUTTON (Right side below RIGHT ARROW button), and then press CTRL button (Middle below UP ARROW button), now you can press the F4 button.
28-Key Keypad
Press the blue FUNC button (Bottom right next to Power button), and then press the CTRL button (Top right side below RIGHT ARROW button), now you can press number 4 to use F4.
Hope this helps, good luck.
Jul 02, 2014 | Zebra Symbol MC3190G Handheld Mobile...
Clean boot for mc3190g
It is best to contact Motorola Solutions for assistance with your MC3190g.
portal motorolasolutions com
Mark
Motorola Mobility Support
'tab' button doesn't work on Motorola MC3190
You get 3 different keypad models of the Motorola MC3190:
- 28 Key Numeric
- 38 Key Shifted Alpha
- 48 Key Alpha Numeric
So depending on the type of keyboard your model has, using TAB are different across these 3 keypads.
When the FUNC button is pressed the icon "F" appears on the taskbar on WinCE devices or the icon "Blue Circle" appears at the bottom of the screen on Windows Mobile 6.1 devices.
In order to use the TAB function, do the following:
28 Key Numeric - Press the blue FUNC button (Bottom right next to Power button), and press the RIGHT ARROW button.
38 Key Shifted Alpha - Press the blue FUNC button (Right side below RIGHT ARROW button), and press the RIGHT ARROW button.
48 Key Alpha Numeric - Press the blue FUNC button (Right side below ENTER button) and press the number 9 button.
Apr 18, 2014 | Zebra Symbol MC3190G Handheld Mobile...
Why can't my MC3190G connect to my Windows 7 machine via Windows Mobile 6.1?
Hi, for Win 7, you cannot use activesync, you need to use the Mobile Device Centre, also from Microsoft, free download.
This will load the drivers into Windows7 such that it will recognise the Symbol/Motorola MC3190 when it is docked to an attached cradle
Note: for some applications you could previously set the "Guest Only" flag in Regedit for an ActiveSync and the handheld would not ask about the connection each time (assuming you do not want sync email) but in win7 it will ask each time.
May 09, 2012 | Zebra Symbol MC3190G Handheld Mobile...
Need recovery for windows embedded ce 6.0 core x13-12056
hi
how update wince 6 embedeb ce from sdcart...bicause my device im possible connecting to pc model: QXV-712 PR?MO plase help me
Mar 14, 2012 | CTX EzBook V92C266 Notebook
How to install toshiba tgo1 mobile in android 2.2
Ok its just been hacked recently so your phone is lucky !
Ok DOWNLOAD the ANDROID here
AND FOLLOW MY INSTRUCTIONS
For those who want to try himself.
1st. Download from Markinus posts his repository it's on the right side on the page http://gitorious.org/linux-on-wince-.../linux-on-tg01
2nd. Unzip it in a folder that you have created before. How to unzip it?
Go to Applications -> Accessories->Terminal
In Terminal tap: cd name of your new folder, ( example: cd myAndroid )
then you have myAndroid$
Now you tap : tar xvzf directory where you have download Markinus repository. (example: tar xvzf /home/downloads/linux-on-wince-htc-linux_on_wince-htc-linux-on-tg01.tar.gz.gz)
You will see how the file is unziped.
3rd. You will see in your folder that there is a new folder named (linux-on-wince-htc-linux_on_wince-htc-on-tg01 or something like that). If you see like a small lock in the front of this folder then do this. Create a new folder put the name you want. Then cut everything from the folder linux--on-wince-htc...........etc. and past it in your new folder.
(example what I did it was easy just in my folder myAndroid I create a folder kernel_1 and I paste everything inside.
4th Now wen we have not everything but may be a part of. Is time to download toolchan (compiler) and some libraries.
in your Terminal tap : apt-get install git-core gnupg flex bison gperf build-essential zip curl zlib1g-dev gcc-multilib g++-multilib libc6-dev-i386 lib32ncurses5-dev ia32-libs x11proto-core-dev libx11-dev lib32readline5-dev lib32z-dev.
thats for the libraries.
and this one for tollchains or cross tools or ... what you want call it.
http://www.codesourcery.com/sgpp/lit...tal/release858
download it and install it. in the same folder as repository (example myAndroid/cross_tools)
Thanks to Endrix with his tutorial help me a lot.
5th.Now enter in your kernel_1 folder or whatever you called it and tap: make ARCH=arm tsunagi_defconfig
6th When finish writing to configuration. tap: make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabi-
enter
If you have done everything without errors then you will see how linux is building your kernel.
7th When finish building go to (exaple myAndroid/kernel_1/ARCH/arm/boot/ ) ther is your kernel Image and zImage you can use both if you want. :O)
Feb 17, 2011 | Toshiba TG01 - Pay Monthly Cell Phone
How to setup wifi connection in motorola symbol MC3190-G
I'm writing to ask you a question about MC3190G Motorola I bought. I dont know how to transfer Data to the computer via Wifi/
can you tell me. what to do? I'm looking forward to your reply ASAP.
Oct 17, 2010 | Zebra Symbol MC3190G Handheld Mobile...
MC 9060 not retaining programming
We have the same problem, and according to our supplier we had to use the Regsave for saving the settings, due to internal proceudres, we haven't use the devices for a year, but now we have to use them again....
We have found this solution in the net, perhaps will help you...., now we are trying to find out the RegSave utility, if you find it, PLEASE e-mail me at alrapmttas@maersk.com THKS
quote
Some brief notes about the use of RegSave on Symbol 90X0 terminals, specifically the 9060 with the 802.11b RF option.
You will need RegSave_2_53_04.zip
Unzip this and locate the file RegSaveCED.exe in the 9050 folder.
Connect your terminal as a guest in ActiveSync and explore it using Win Explorer. Locate the c:\applications folder and copy the RegSaveCED.exe file to this folder on the HHT.
Now you can uncouple the HHT and click start menu and Windows Explorer to look at HHT's local files. locate applications folder and locate the RegSaveCED.exe file... double tap
Now screen RegSave EMEA TS appears.
In Registry section press "Create Template File"
Accept \Application\RegSave.tpl option offered
Click Create template and wait forever !
............. time passes ..................
The app rattles through all the registry entries and builds a file with them all in. Just when you assume it'll last forever it stops...
Now back to the main screen ...
Click OK (top right) to exit the app
--- oOo ---
Now set your IP parameters and RF bits... in fact anything you need.
--- oOo ---
Now re-load the RegSave app.
Press the button in the Registry section entitled "Save Current Configuration"
I got some missing file error here which I rode over roughshod... basically it's looking for a registry exception file. You can create this but and it can be a list of ignored keys but for our purposes it doesn't matter so I just said "Yes"
It'll do some stuff regarding comparing and checking for differences, then it saves the changed bits.
Now you can exit RegSave and try rebooting... it should have saved the changes to the Registry and everything should be the same as before
unquote
Feb 27, 2009 | Symbol MC9060-G
I NEED HELP!!!
you have to manually reload firmware, if you get the dvd I sell on ebay you should be able to run the update file to reload, this is if wince has not been damaged... search ebay for finedrive dvd.
Aug 04, 2008 | Fine Digital FineDrive 400 GPS Receiver
Zebra Symbol MC3190G Handheld Mobile Computer Logo
63 people viewed this question
Top Zebra Computers & Internet Experts
pkwc
Mike
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
