Question about NEC NP61 DLP Projector
My NEC NP61 DLP Projector power on but not lamp on when after 1 or 2 minits red led blinking 8 times give me a solution
Gigatech
  • 259 Answers
SOURCE: NEC VT47 Lamp type VT70LP will not power up 2 red lights spear Lamp not working
When the lamp exceeds 2100hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Posted on Feb 27, 2008
Gigatech
  • 259 Answers
SOURCE: Status light blinking red
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
SOURCE: Blinking status light
Replacing the lamp with an old one was helpful for me. Good news: the projector itself not faulty. Bad news: I have two projectors with the same issue at the same time (the lamps were replaced also at the same time) after only 400 hours of running.
Posted on Jun 23, 2008
SOURCE: NEC VT 595 wont turn on. Just red blinking light
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
Posted on Aug 26, 2009
projdoc
  • 2236 Answers
SOURCE: red light blinking in nec lt 260
how many times? that will tell you what's wrong:
1x- lamp cover (close lamp cover)
2x- temperature problem (too hot. clean out and cool down)
3x- power problem (check power)
4x- fan problem (one or more fans not running)
6x- lamp fails to light (lamp or ballast problem)
Posted on Sep 02, 2009
Nec vt540 vt540k
probably needs filters cleaning or a new lamp replacement.
Oct 07, 2013 | NEC VT460 Multimedia Projector
I have a NEC VT470 Projector. The power light is steady orange and the status light blinks red 6 times.
steady orange means projector in standby mode
red light 6 times is a lamp error.
either the lamp is old and wont start up or the ballast power pcb is not working.
can you hear the sparking of the high voltage trying to strike the lamp.
if you can then the lamp may be dodgy.
can you borrow one to test it out
Mar 02, 2011 | NEC VT470 Multimedia Projector
NP310 NEC Projector shuts down after about 15 min.
Check for good air flow: that filters are clean and the fans are running and not blocked. Check the bulb hours - it may be nearing the end of its life expectancy. If heat is the problem, the inside temperature sensor will shut down the machine or it may be faulty. Inside electronics would be the next suspect.
Feb 07, 2011 | NEC NP61 DLP Projector
Steady red status light on NEC VT45 projector. Would not POWER ON. LAMP was replaced with a new one
the power supply on that model seem to go bad after a while. the caps aren't properly reted it's power needs. they dry up. if you are good at soldering, replace c1 on the board (big cap) with a cap that has a slightly higher voltage rating. or replace the whole power supply. you might not be able to get one from nec, but you can try www.projectordoctor.com
Dec 16, 2009 | NEC MultiSync VT45 Multimedia Projector
My lamp light stays on my status blinks
if it's blinking red, how many times? 1 time- lamp cover. 2 times- overheating. 4- fans. 6- lamp. if the lamp led is lit red, replace the lamp.
Dec 09, 2009 | NEC VT460 Multimedia Projector
Red light blinking in nec lt 260
Sep 02, 2009 | NEC LT 260 Multimedia Projector
InFocus LP120 Powercycles/Shuts Off/Does Not Stay On
what is the led doing? what coloris it? and if it is blinking, how many times? this will tell you the problem.
green (flashing and solid)- all is well
red flashing:
1 time- lamp won't strike after 5x
2 times- lamp has over 2000 hrs. replace lamp
3 times- lamp failure. replace lamp
4 times- fan not working.
5 times- projector running too hot. needs cooldown
red led lit solid- undiagnosed issue. send in for repair.
if your projector is under 2 years old, it's under warranty, but it seems unlikely.
Aug 10, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Projector not working
The solution is replacing teh Mainboard !
Mar 21, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
NEC VT 470 projector won't work at all
Try pressing the HELP button. Don't release and press the power button. The LED lights should blink. Release then try to power on again.
Jan 11, 2008 | NEC Replacment Lamp Projector Lamp for...
NEC NP61 DLP Projector Logo
Top NEC Office Equipment & Supplies Experts
Electro Med Services...
Piyal Perera
Piyal Perera
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
