Question about Electrolux ICON 30 in. Double Wall Oven
How to remove foil adhered to bottom of oven - Electrolux ICON 30 in. Double Wall Oven
3 Suggested Answers
Obertelli
  • 3006 Answers
SOURCE: I have baked on aluminun foil on the bottom of my
If the bottom of the oven is enamelled or has a pyrolytic self cleaning surface then you can use caustic soda to remove aluminium foil.
Many oven and hob cleaners contain caustic soda and those which do always advise that it's kept away from aluminium parts precisely because of it's effectiveness in turning aluminium into grey foamy goo!
If you're in doubt as to whether your oven floor is caustic soda resistant then try a small test patch first.
Please note that caustic soda is extremely corrosive so you'll need to keep your hands and arms covered and preferably use eye protection as well.
Posted on Sep 20, 2009
SOURCE: How would I remove aluminum foil stuck to the
How would I remove aluminum foil stuck to the bottom of a convection oven?
Posted on Sep 10, 2010
Does a GE Profile double oven have a removable bottom pan
It says right in the owner's manual not to use aluminum foil on the bottom of the oven. Try to remove it with steel wool...
Aug 29, 2016 | GE Ovens
MELTED ALUMINUM FOIL ON BOTTOM OF OVEN FLOOR: Have a Kenmore ceramic smooth top range. We placed a piece of aluminum foil on the very bottom of the oven as we like to bake our pizza on the rack but...
I would try a copper scouring pad.
Aluminium is very soft - Mohs hardness of 2.75
Copper has a Mohs hardness of 3, just slightly harder.
https://en.wikipedia.org/wiki/Hardnesses_of_the_elements_(data_page)
Ceramic tile has a hardness of 7
Mohs Hardness Scale
This means the copper scouring pad should be able to remove the melted foil without scratching the ceramic - but test first to be sure.
Mar 10, 2017 | Ovens
My new oven has melted the tin foil onto the bottom of the oven that I put to catch cake drips. I don't know how to get it off as it has adhered. The smell right from the start of the oven and during my...
With the older models of self-cleaning ovens one could put aluminum foil on the bottom tray of the oven, but with the newer models there is a warning (hidden in the last line) of your booklet for models of stoves where aluminum foil should 'not' be used! Even though print in small and many consumers are complaining regarding their stoves and melted aluminum stuck to the bottom tray of their oven (nothing will get it off) all manufacturer do 'not' cover this problem under warranty and thus, it will cost you $44 to buy a new tray. You unscrew the two screws to the bottom of the damaged tray of your oven and then install the new one and put back the screws. Letters of complaint should be written to the manufacturers to have them put this warning in clear bold print right on the front cover of the instruction brochure.
Jan 20, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I have a new Frigedaire self cleaning oven. Before I got to read the manual my daughter baked a cake which dripped onto the oven floor and began to smoke. To catch more drips I put a pice of tinfoil on...
Greetings,
remove as much tin foil that is possible...use something like hot water and mild detergent to loosen up the baked on cake residue...this should come up ok with alittle elbow grease...then run your self clean cycle...All will be ok....Bruce Denton
Jan 20, 2011 | Frigidaire Ovens
Aug 04, 2010 | Electrolux Ovens
Tin foil stuck to bottom of oven how to remove it
See this link: http://askruth.blogspot.com/2006/07/cleaning-baked-on-foil-in-oven-help.html
"I called Sears and this is what they said to do:
BE CAREFUL, remove as much of the foil as possible Turn oven on to 200 lay an old wet bath towel on top. Use a plastic spatular to remove the foil.
They said it will take some time to remove the foil, in some cases days, and that you can still use the oven but DO NOT use the self cleaning untill all the foil is removed."
If you can remove the bottom drip tray/pan from your oven which the tinfoil is stuck to, than remove it. Ovens with "hidden element" usually have the removable bottom tray/pan. Don't scrape yet!!
Lay the tinfoil laden tray on a flat service where it wont be disturbed for a couple of days.
Now remove any tinfoil you can with a plastic scraper/spatula/pancake flipper.
Once thats done, pour bleach directly onto the drip tray/pan until it covers all the stuck tinfoil.(assuming your oven pan is like mine and has a lip all the way around and is somewhat countersunk).
Leave the bleach in for about 2 days. Now get your plastic scraper again and scrape away. The stuck tinfoil should all be dissolved by the bleach and the scraper should get rid of any residue. Then rinse!
Now this method will probably leave some darkened stains on the oven tray, but not near as ugly or noticeable as that melted tinfoil!!
Good luck!!
May 14, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I have a Kenmore self cleaning oven with foil liner burned on!
Hi Leia, Unfortunately, the aluminum actually melted and adhered. The only perfect fix is to buy a new bottom piece for the oven, it costs about $30.00 and it is very easy to remove the old and install the new. Just a few screws.
You can get the part directly from sears by going to sears.com
May 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Foil baked onto oven base.
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. You should never place anything on the bottom of a stove that has a hidden element. You will damage the panel. Oven operation is not affected. The only option you have is to replace the panel or the entire oven liner...
Jun 07, 2008 | Ovens
Melted Tin Foil in bottom of oven
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. You should never place anything on the bottom of a stove that has a hidden element. You WILL damage the panel. The only option you have is to replace the panel or the entire oven liner...
May 20, 2008 | Ovens
Electrolux ICON 30 in. Double Wall Oven Logo
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
