Ibm controller monitor initializing - Computers & Internet
IBM x3400 7975 controller initiation failed The
Check the cabling, both the data cable and the power cable.
Aug 03, 2013 | Intel Motherboard
Controller monitor failed,controller not started appeared on my screen when i opened our server systemx3500
This is a raid controller failure. Server is not able to initialize device.
Workaround:
1: Turn off server
2: Take out Raid Controller from server > blow air on raid controller slot to remove dust.
3: Put it back
Now turn on server and see of it gets initialized.
If you still gets error then its time to replace controller
Thanks
Dec 06, 2012 | IBM System x3500 7977 - Quad-Core Xeon...
Sir, In our IBM eServer3400 At First we got Controll Monitor Error,we followed the steps you have given solution.But yet we get error in another two servers we followed the same steps but one server...
There is a great deal of bugs and fixes for your product from here:
http://www-933.ibm.com/support/fixcentral/systemx/selectFixes#Critical updates
Make sure its for the right model, and mainboard number, and operating system:
My suggestion is, to consult your local IBM dealer, and ask them what the problem
could be.They must know.
Its not easy to say, what the problem could be, but my guees is that, it could be software
related.Or entering a wrong parameter.
Specifies the name of the Monitor control server where the Replication Alert Monitor program runs and the monitor control tables reside. This must be the first parameter if entered.
luw.gif If you do not specify a Monitor control server, this parameter defaults to the value from the DB2DBDFT environment variable.
zos.gif The default is DSN
Here is the trouble shooting site:
http://publib.boulder.ibm.com/infocenter/db2luw/v9r7/index.jsp?topic=/com.ibm.swg.im.iis.db.repl.monitor.doc/topics/iiyrcmonrasnmon0.html
Hope this was helpfull.
Mar 14, 2011 | IBM x3400 Server
Question: I have one server for IBM X3400. this con't booting that problem was Fatal error: controller monitor failed conterollre not started . .
I have one server for IBM X3400. this can't booting that problem was controller monitor failed controller not started
Dec 15, 2010 | IBM x3400 Server
Fetal error controller monitor failed x3400 ibm server
Welcome to fixya
Open the server and take out the raid controller . Now clean the slot as well as the raid controller . Now replug the raid controller check if it works
If you get same error now , then its time to replace the raid controller
Thanks
Oct 13, 2010 | IBM x3400 Server
The display on my ibm thinkpad r40 is black after initial dim ibm screen. External monitor works fine though. This happened immediately after I used my ibm with a projector this morning? Fn F7 does not...
The problem youve discribed does seem to point to your back light has failed on the laptops lcd display, i dont know exactly how this would accure just using a projector though, go into bios again and try loading factory settings.
This problem could also be the inverter if you cant make out even a slight image on the screen.
let me know what happens. thanks
Jan 19, 2010 | IBM ThinkPad R40 2681
IBM ThinkPad A20M Turns on but there is no video?
My initial diagnoses for your PC is due to a defective
video card. But there could be other causes such as
Processor contact defect. So, to get a precise and
guaranteed works, have your PC serviced by a qualified
PC technician in your area.
Dec 08, 2009 | IBM (08K3261) for ThinkPad A20P, A20M,...
Ibmserver x3400 fatal error
Have you checked the IBM website for BIOS and any firmware to download and update for the controller? It can get to be a maze with server cards.
Jul 07, 2009 | IBM x3400 Server
IBM starting problem.
Hi , if your dont have any data, try to get the IBM Netfinity CD for 4000r which supporting the OS 2003. Usually IBM provide a cd on each NEtfinity server. Check on the IBM website for more details about your Server Compatibility on 2003 server. then proceed to re-intalled the OS.
Aug 10, 2007 | IBM Netfinity 4000R 8652 Server
Computers & Internet Logo
127 people viewed this question
David Payne
David Payne
