Lg intellowasher 7kg wd 10260T - Washing Machines
SOURCE: my lg intellowasher 7kg WD-1059 FB will not pump
Pump motor is probally shot, Mine is 4 years old I'm replacing mine again. Yes I've replaced it twice
Posted on Feb 23, 2009
  • 901 Answers
SOURCE: LG Intellowasher 7kg, Model WD-8074FHB - noisy spin cycle
You are right!
Bearings have to be replaced. Replace with the same type and design. All the bearings connected to the washer center shaft has to be replaced at the same time with new set.
Replace the water seals also connected to this. Check the shaft where the bearing sits, for any abrasions or metal damage.
Check the bearing housing also. While carrying out these repairs check the drive belt also. If needed replace it.
If you are happy with the machine outer body and other aspects repair it and re-use it.
Posted on Apr 07, 2010
Testimonial: "Thanks for the quick reply Ambari, that's exactly what I wanted to know. Atleast I'll some idea if the repair bloke is pulling a swifty. Cheers"
  • 4 Answers
SOURCE: LG Intellowasher 7kg 800rpm WD-8074FHB
It could be that the springs have become lazy (stretched) and not supporting the spinning weight as good as they once did or as happened to me one of the shock absorbers at the base of the unit has come adrift from its securing point. Replacement parts are easily available but you will need someone strong to fit them with all that new tension.
Posted on Jun 07, 2010
jumptrout51
  • 3361 Answers
SOURCE: Manual for LG Intellowasher 7kg
While not exact to your model,this manual may answer your questions.
http://136.166.4.200/contents/Laundry/WD-1070FH/WD-1070FD_Service_Manual.pdf
Posted on Sep 08, 2010
beltronic205
  • 1461 Answers
SOURCE: My LG intellowasher 7kg WD-8015C
Most common,Water supply okay, Door closed properly,Child lock not switched on....? Good Luck
Posted on Feb 16, 2011
How do I clear the CL code on the display of the washing machine lg intellowasher 7kg WD-12235FB
The Child Lock function on your washer has been enabled. Press the options buttons simultaneously for 3 seconds to reset.
May 11, 2015 | LG Washing Machines
LG intellowasher 7kg wd-8015c
SURE VINEGER IS VERY GOOD ON CLEANING WASHER
May 02, 2014 | Washing Machines
My washing machine turns on but will not start. It will only make a click sound then another click sound. Please help
Your timer swicth is defective or fuse inside but check first the cord if it not broken before you go to fuse and timer
Jun 15, 2012 | LG Washing Machines
Cant open door
Dear all, I have a problem with washing machine model wd-8013c, then you wash white laundry receives water and immediately released, and it does not happen with colorful Vesa. Best regards.
Apr 25, 2009 | LG Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
