Question about Zyxel Computers & Internet
Zyxel zywall 35 slow internet speed after firewall rule active
2 Suggested Answers
luis356
  • 53 Answers
SOURCE: My Zyxell (Zywall 2WG) router drops out every 30
logon to your router and chage the default channel(usually 6) to something else. This should correct the problem most times.
Posted on Jun 03, 2009
Zywall usg 50 won't VPN to 3Com officeconnect
Check the system log of the devices. The log usually can tell you why the VPN is not working.
Apr 02, 2014 | Zyxel ZYWALL USG 50 SEC-GTW 5 VPN TUNNEL -...
Zywall l2tp ipsec
There are many root causes can make the VPN connection not stable. You should try to rule out the possibility that the outdated firmware cause the issue first. Contact zyxel tech support after you update the firmware.
Feb 19, 2014 | Zyxel ZYWALL USG 50 SEC-GTW 5 VPN TUNNEL -...
I want to block ultrasurf using zywall 2
Open App patrol, search for UltraSurf and block it.
Mar 17, 2011 | Zyxel Zywall 2 PLUS (ZYWALL2PLUS) Firewall
My dad is death and I don't now the password ov ZyWALL 2 plus..please help me... im ITALIAN
Hello there,
Im sorry for your father, by the way if you forget / lost your password(cannot access the web configurator you will need to reload the factory-default configuration file or use the RESET button on the back of the ZyWALL. Uploading this configuration file replaces the current configuration file with the factory-dafault configuration file. This means that you will lose all configurations that you had previously and the speed of the console port will be reset to the default of 9600bps with 8 data bit, no parity, one stop bit and flow control set to none. The password will be reset to 1234, also.
The procedure to use the reset button
Make sure the SYS LED is on ( not blinking) before you begin this procedure.
  1. Press the RESET button for 10 seconds, and then release it. The ZyWALL restarts with the defaults restored. Otherwise, go to step2.
  2. Turn the ZyWALL off.
  3. While pressing the RESET button, turn the ZyWALL on.
  4. Continue to hold the RESET button. The ZyWALL restarts with defaults restored.
  5. Release the RESET button and wait for the ZyWALL to finish restarting.
Hope it help and have a nice day,
regards
Apr 15, 2010 | Zyxel Zywall 2 PLUS (ZYWALL2PLUS) Firewall
I have zyxel zywal 35 have two wan port, wan1 connected to t1 line, wan2 connected broadband line , now the firewall configured on active/ passive mode,it was working fine but some times. fire wall lan ip...
This is due to some bad packets on your network. Check the network for any worms/spywares. Also check if the ethernet connections/card donot malfunction.
Jun 19, 2009 | Zyxel ZYWALL 35 Firewall
Port 80 forwarding
use hidemyass.com as a home page surth from hear
Jan 24, 2009 | Zyxel ZyWALL 2 Firewall
Full Duplex
By default, I think these come with auto-sensing turned on, but I may be mistaken.. do not have one available, but do have the manual link if you need it:
ftp://ftp.zyxel.com/ZyWALL_35/user_guide/ZyWALL%2035_4.03.pdf
or:
http://tinyurl.com/2k9gth
I reviewed the entire document and did not see a section on configuring duplex, although it may be in the Bandwidth section.. since they do not show all the configs, I am not sure....
Dec 21, 2007 | Computers & Internet
Routing problem
I don't know if this will help because I don't see what you and seeing but here is an idea: In every routing scenario I have experienced, you must specify a default gateway with a specific IP address. 0.0.0.0 only points to the device itself, not the other WANS. The gateway IP addresses should be statically assigned. If there is DHCP involved, insure that the gateway address is not part of the DHCP scope but in an excluded range of reserved addresses. For SMTP to work the gateways (and you should have 2 or 3) must be properly configured and TCP port 25 enabled.
Dec 09, 2006 | Zyxel ZYWALL 35 Firewall
Computers & Internet Logo
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
