Question about Yamaha Audio Players & Recorders
No sound from my Yamaha amplifier RX-V5000 - Yamaha Audio Players & Recorders
  • Simon Smith
    Simon Smith Oct 16, 2013
    Solved it the volume was turned down too far
  • Simon Smith
    Solved it the Volume was Turned Down Too Far,Thanks Everyone for looking,Because it is New,Just bit Different To Older Amps
  • Yamaha Master
  • 5,056 Answers
If it powers up take a look at whatever is the main amp. If it is a single device such as an IC then it could be faulty.
Posted on Oct 19, 2013
2 Suggested Answers
  • 30 Answers
SOURCE: HOW TO FIT SURROUND SYSTEM TO A YAMAHA RX-V640
you should have a orenge moniter or audio out tha goes from you yamh to the amp
Posted on Jul 29, 2009
HOW DO I CONNECT MY YAMAHA RX-797 TO MY PC-LAPTOP
does laptop have a 3.5 mm stereo output port for sound ?
HDMI is video
YAMAHA rx-797 is a stereo amplifier audio
so you have a RCA phono input port
you need a 3.5 mm stereo lead to rca phone plug
may look like
http://www.4cabling.com.au/stereo-socket-to-2x-rca-plug.html?utm_source=google_shopping&gclid=CO30uN-Muc0CFUEDvAodscUI3w
with red and white plugs ..
Jun 18, 2016 | Yamaha Audio Players & Recorders
Have a Sony 32" Bravia TV & Yamaha RX-V5000 Receiver. Unable to get the sound to come from the Stereo speakers connected to the RX-V5000 if watching TV. However, can get the Radio to play through the TV...
You probably want to connect the av Audio output from your tv and connect to the RX-V5000. The audio that you are getting from Radio through the tv is probably coming from the output of the RX-V5000 coming to your tv, to which the desiredd route is the other way.
The Outputs at the back should be labeled to tell you which channels are inputs or outputs.
Oct 09, 2013 | Yamaha Audio Players & Recorders
Does the yamaha RX-V1900 have analog zone two output
Yes your amplifier has assignable multi zone capability .You have to go into the initial setup of the amplifier and select if you want to assign any one of the amplifiers ( eg: rear back amp ) as zone 2.
May 22, 2011 | Yamaha RX-V1900 Receiver
My yamaha rx-v596 makes a clicking sound but does not turn on
If it clicks twice almost instantly (on then off within 1/2second) then its got a serious power supply imbalance.
If it clicks on then 5secs later clicks off then one of the amplifier channels has probably failed and the protection circuit is tripping it off to protect itself.
either way its a repair shop job I'm afraid
Jul 16, 2010 | Yamaha RX-V596 Receiver
Yamaha RX-V3000's front channels quit working
The front channels could still go out if one of them
is going out as the relay will shut em both down if it senses a problem! Check also for bad solder connections too!
Apr 13, 2010 | Yamaha HTR-6030 Receiver
How to run an un-amplified signal from Yamaha RX-V3000
split the input before you go to the amp from the dvd or cd split the rca cables
Oct 31, 2009 | Yamaha RX-V3000 Receiver
Yamaha AV Amplifier RX V530
You might have your speakers shorted. Check the wiring at the amp and speaker terminals
Sep 09, 2009 | Yamaha RX-V530 Receiver
The unit does not work
check the standby power supply first and then the main power supply.also check the output transistors and fuses your problem is in one of those points, normally the standby transformer goes bad, it is the small one right next to the big one.
good luck
May 21, 2009 | Yamaha RX-V463 Receiver
113 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
