A creative speaker sbs a235 connection pin is totally damage so we need to connect cable directly into board.so we need the pin details a235(mf0400)
4 Suggested Answers
  • 356 Answers
SOURCE: Creative SBS 2.1 370 Speaker - Volume Remote Controller not worki
Hi Arun!
Try to plug your speakers to an iPod or any MP3 Player to check if there's sound. If there is sound, then try plugging it to the green port at the back of your speakers.
If it doesn't have sounds then you need to buy a new speaker system.
^_^
Posted on Jun 05, 2010
  • 3940 Answers
SOURCE: Hi there, Due to space constraints, i had to
It should have little if any effect on the monitor, LCDs are not nearly as sensitive about EMP as CRT monitors were
Posted on Oct 15, 2010
SOURCE: Creative Speaker Of Model SBS-370 The Volume Control is not working, How to directly Connect those two Wires connected to Volume control,bypassing the Volume Control Switch
1. connect:Both Ground (copper wires) with Green wire
2. Connect Red with Blue and
3. Connect White with Yellow
This will give Stereo Output.
Posted on Feb 06, 2012
How to fix creative A235 speaker main controller or right speaker not producing any sound
You must check the 9 pin connector and wire connectivity in the right speaker PCB board.
If you can post the pin and cable colour of attachment I may help. If you can draw circuit diagram of the small pcb in right speaker than it will be advantage.
May 22, 2014 | Audio Players & Recorders
Win 7 drivers for creative sbs a235 speaker
creative a 235 doesnot require any computer driver. Just plug into headphone jack and enjoy. If your headphone is working in the same jack and your speakers must also work. Use a working headphone to check the problem is with laptop or speakers.
Apr 20, 2014 | Creative Labs Audio Players & Recorders
I want the image of cable pin of creative speaker sbs a235
Thesee days, every speaker uses a 3.5mm jack. Its become a standard now.
Oct 15, 2013 | Audio Players & Recorders
Creative SBS 2.1 370 Speaker. hello how are you today, i have a question regarding the wiring in the volume on and off switch in the Creative SBS 2.1 370 Speaker setup, ive lost the little contoller some...
posted by Sandeep Sharma
hai, Here is the solution. when u cut the PCB from both sides u will find 4 cables i.e. green blue yellow and a copper wire coming from woofer and 3 cables white, red, yellow coming from audio lead. connect the green cable to copper cable and yellow to blue coming from woofer. Now take white cable coming from audio jack.connect this with yellow blue cables of woofer. Now attach Red and Yellow, connect these to green and copper cables of woofer and enjoy. if problem persist then make experiment to make interchanges with red white yellow coming from audio lead to the 2 sections of woofer side. woofer connections green/copper and yellow/blue remain same.
an.astrologer@gmail.com
Aug 30, 2011 | Creative Labs SBS 370 Computer Speakers
A creative speaker SBS A200 connector pin was damaged. we need to connect that cable directly into the board.so we need that pin details.
Hi, I hope this helps,
Pins look like this: (Top view, not copper side)
1 2 3 4 5
6 7 8 9
1 = Thin white wire from thick white cable (Left input)
2 = Gray (Speaker out)
3 = Orange (+V return from volume unit to bass unit)
4 = Not connected
5 = Thin Red wire from thick red wire (Right input)
6 = Blue (+V power from bass unit to volume unit)
7 = Black (GND - if socket removed, solder 3 socket shield holes to each other or solder black wire directly leftmost hole)
8 = Not connected
9 = Shield copper from thick red wire
Shield copper from thick wire : Solder to GND or Left unconnected
Jun 23, 2011 | Creative Technology SBS A200 2 Speakers
I can not find the drivers for Creative SBS 380
Hi lorenzogoode
You don't need drivers for these speakers : it's a plug and play system .
Check your connections , power supply and volume settings .
Best regards ,
fanaudi .
May 25, 2011 | Creative Labs Creative SBS 380 2.1...
Hi Arun!
^_^
Jun 05, 2010 | Creative Labs SBS 370 Computer Speakers
61 people viewed this question
 Grubhead
Grubhead
