Mitsubishi rear projection TV , Model VS-45603.In the last year it started to turn off by itself. It has no real pattern. It can turn off 2-3 times one day and none the next day. It is hooked up with Direct TV. The TV will turn itself off and the Tivo box will stay on. WE have to wait about 10 min. before we can turn the TV back on. I have a 65" Mitsubishi Rear Projection TV bought in 2004. It to is connected to Direct TV who I believe is responsible for the TV shutting down. The TV does not exactly turn off. It looses all signal. The only way to get the signal back is to power the TV off & on. Sometimes it will not pick up the signal for hours. The only thing you can do is keep powering the TV off & on until you regain signal. I didnt really have this issue until I connected it to a High definition receiver. Direct TV says its my TV. They replaced the receiver once without fixing the issue
  • PHXLION Apr 24, 2009
    I can play a DVD just fine, which also tells me its Direct TV
  • beyondsat May 11, 2010
    Does it do this when you are watching a DVD, VCR, or any thing else?
  • 23 Answers
What kind of cable are you using to connect it with (coax, HDMI, RCA (composite), component, s-video)?
This may be a grounding problem. Either the cable from the satellite dish is grounded to something with a little electricity running through it or you may have a hot ground in your electrical outlet. Or the cable may be on a different ground than your electrical outlet and by connecting the two it has created a slight electrical current. You can try using a plug adaptor to remove your receiver from the electrical outlet ground. These adaptors are meant for older homes and electrical outlets that do not have a third hole or ground plug. The outer metal part of all video connectors is the ground and this may be causing the tv to act strangely.
I hope this works.
Posted on Apr 24, 2009
Hello I have a mitsubishi vs-45603 with what appears to be a convergence problem.
You may have bought bad chips or your soldering...
This is a common problem on many brands of Projection Tv sets. Its usually a convergence issue. You can get more details and a solution here on fixya using this link http://www.fixya.com/support/r11932741-convergence_repair_dull_video_repair
Mar 22, 2012 | Mitsubishi VS-45603 45" Rear Projection...
Mitsubishi VS-45603
You will need to go into the menu, setup, a/v connection, then make sure the locked to input is selected to no..
Good luck..
Sep 17, 2008 | Mitsubishi VS-45603 45" Rear Projection...
Mitsubishi VS-45603 had power outage and when it came back on it says TV is locked. How do I unlock it?
Go into the 'Menu' -> then 'Setup' -> then 'A/V Connections'.
You should see an option called 'Locked to Input' switch it to 'No' and your problem should be solved!
May 05, 2011 | Mitsubishi VS-45603 45" Rear Projection...
TV will not turn on
you either have leaky capacitors near the voltage regulators, cooling fluid leaking on the boards, and/or bad solder connections on the yoke plugs. this model is known for all 3 problems, but you probably need a qualified tv repairman to fix this right.
Sep 17, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Sound is distorted on this Mitsubishi Model No. vs-45603
how old is your unit?sometimes distortion is caused by interference,like motor or automobiles but that is minimal.connection of the antenna , cable and other connectors can also be the caused.if all these are not the cause, call a tech.the audio circuit is faulty.
May 14, 2009 | Mitsubishi VS-45603 45" Rear Projection...
Cleanng the projection mirror
remove the speaker grill, you will see the screws holding the front screen, remove the screws and the connectors going to it and slide the screen up and off.
Sep 18, 2008 | Mitsubishi VS-45603 45" Rear Projection...
Only Picture in Picture Works...????
Its possible some of the surface mount capactors has failed on the pip board is so the unit will need to be replace or repaired.
Mar 18, 2007 | Mitsubishi VS-45603 45" Rear Projection...
Televison & Video Logo
140 people viewed this question
Top Televison & Video Experts
Electro Med Services...
