SOURCE: whirlpool 6th sense washing machine,
Find your machines tech sheet. The error codes and suggested remedy's will be there.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: I have a whirlpool 6th
f13 is a problem with the door lock, I have the same machine and it takes 4 minutes for the door latch to open and if it dont in the 4 minutes F13 comes up and the machine will go off and not start again.
SOURCE: clean pump!
remove bottom panel torx or 7 mm nut driver needed.pump has "knob" turn counter clock wise ..have plenty of towels handy to unlock door first reach up to bottom of door lock tear shaped plastic tab pull down door will open
SOURCE: what does F7 mean on a whirlpool 6th sense washing
F7 in whirlpools means "Clean the filter”.
The following troubleshooting steps would help fix it. Remove the filter on the floor of the machine, including the metal grill. Press & hold the start button (like you do when you want to cancel a program this will drain the water out of your clogged up drain outlet. Clean your filter and grill and replace it. My guess is that the sensor in the drain (a little glass tube) measures whether the water going out is clean enough to decide that your dishes are now rinsed correctly. If your filters clogged, the water going down the drain is still dirty. After a while it gets sick of trying and stops the machine.
Thank you for contacting www.Fixya.com
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06
Drive
Motor Tachometer Error
The
control is unable to properly detect motor speed and the
machine will shut down. If a failure occurs during high-speed
spin, the door will be unlocked after 3 minutes.
Thank you for writing to fix ya.
Best regards Richard
