Question about HP Officejet 5610 All-In-One InkJet Printer
Print heads stick to the far left at the end of printing a page.
My HP Officejet 5600, with very little use, in fact we 2 at the office and they both are doing this. When attempting to print the print cartridges appear to be stuck over on the far left and chunk and bump and finally get a jam message. It usually occurs at the end of a page and I can stick my hand in and move them along and clear the message and continure
  • 433 Answers
This may help: the silver colored rod that the cartridges ride on made just be a tad dirty. Unplug the printer, open the cover and with a slightly damp cloth wipe the rod off. Do this several until no dirt is showing on the cloth. Sometime the fine mist of ink spay settles and makes it sticky. Try it now and see if it travels along any better.
I have even taken a cotton ball with some fine oil (sewing machine, gun oil etc) and wipe rod lightly.
hope this helps...
please leave a rating- thank you kindly
Posted on May 02, 2009
Printer gets print command and goes through print action but no print on page. Ink cartridges indicate full.
Although "full", some ink in the path-way has dried out, and is blocking the flow of ink from the ink-tank through the ink-jets.
Try the "head-cleaning" procedure, or replace the ink-cartridges.
Oct 31, 2013 | HP Officejet 5600 series
HP Officejet Pro L7680 prints half page only
to get to the root cause of the problem . you can try printing from the notepad and check it prints fine from the notepad . if it prints fyn then there can be some issues with the software compatibility.. which version you have for microsoft office.
Oct 20, 2009 | HP Officejet Pro L7680 All-In-One Printer
How do i change ink?
If iam not wrong you want to replace the Ink Cartridge. Please follow the below mentioned instruction.
Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access doorc00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridgec00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tapec00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridgec00034769.jpg
  5. Close the print-carriage access door.
Back to top Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Regards,
Shrey
Oct 08, 2009 | HP Officejet 5510 All-In-One Thermal...
Help! My Officejet 5610xi All in One won't print
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab66
Jun 26, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp 5600 printer will not effectively cancel print
Please try to following these steps :-
1- Try to run print spool services from the services.msc
just type :- services.msc in the run command.
then restart the print spooler service.
2- Try to delete unprinted page from the print command.
3- Please download HP printing diagnostic utility for check printer problem :-
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-56143-2&cc=uk&lc=en&dlc=en&product=3221646
4- Try to uninstall and reinstall the printer.
please install the driver from the following link ;-
http://download.cnet.com/HP-Officejet-5600-series/3000-2116_4-80627.html
May 05, 2009 | Computers & Internet
Printing
hi,
here are the things that i want you to follow to somehow resolve your issue.
1. On your computer, click on start then go to control panel
2. inside control panel open the PRINTERS and FAXES (XP) or PRINTER (VISTA).
3. make sure change the default printer icon to the HP Officejet 5600 series.
- right click HP Officejet 5600 series and choose "set as default printer"
4. then try printing,
note: the reason why you encounter that problem is because the default printer icon is the "HP officejet 5600 series fax".
best regards
adonscott
Apr 04, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
HP K550 blak print failure
Hold the far button on the right down for a minute and it will move the head over for access
Jan 06, 2008 | HP OfficeJet Pro k550 Printer
Hp office jet 6210
Got to be Cartridge, print head within this cartridge that is full, is block/busted,
Nov 11, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
116 people viewed this question
Seeker5211
Seeker5211
