Question about Samsung SGH-E740 Smartphone
Didfactory reset now its stuck - Samsung SGH-E740 Smartphone
Black and decker lawn vaccum needs to be reset, will not power on?
check the vacuum if there is stuck inside you cannot reset if there's something stuck?
Apr 29, 2018 | Power Computers & Internet
I need to know how to reset my E: DVD drive because it won't open all of a sudden, it acts like it wonts to but its stuck or something.
you can't reset... the only thing to try is to open casing and replug all the cables... But it may be also a problem drawer being just stuck , so the solution is : hit the drawer a few times while pressing eject button and maybe will jump out ...
Jan 24, 2014 | Computers & Internet
Tmax 9 tablet stuck on boot screen
  1. Shut off tablet
  2. press the volume minus button and the power button @ start up
  3. tmax logo shows up and then a android menu
  4. factory reset
  5. Once complete, reboot
  6. wait 4-5minute... tablet works again
Dec 26, 2013 | Tablets & eReaders
My brother ce8080prw machine will not stitch in reverse and is stuck in abasting stitch. how do I reset?
My machine was also not sewing in reverse and stuck in a basting stitch. It was a simple fix. Unscrew the plate and remove any pins stuck in there. All fixed
Nov 04, 2012 | Brother SE-270D Computerized Sewing...
Rca L40FHD41is stuck on menu,cant change input or volume . how to reset the tv???
Unplug the TV for a few minutes it should reset itself.
Make sure the menu button is not stuck, if it is try cleaning the button.
www.aaatvservice.com
Jan 28, 2012 | RCA Televison & Video
The Officejet is stuck on SelfTest and stopped working
Self test is there to test the unit- do a self diagnosis and test the functions of the machine before it is operational, if it gets stuck at one of the test or one of the tests fail then the unit is inoperative until the fault is fixed.
What you can try is taking the power cord out from the unit while its stuck wait 2 minutes and plug it back in.
if the issue remains then there are 3 resets that you can try
partial reset
semi full reset
full reset
here are the partial reset instructions
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=za&docname=c00060793
the two other resets are, same as the partial reset but the 3 is replaced with a 6 for semi full reset and 9 for a full reset.
if the problem remains after this then you have a hardware problem, take it to a repairer.
Nov 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
770SW Olympus needs a factory reset, lens stuck open
Contact Olympus for the factory reset code.
Sep 01, 2017 | Cameras
Upon startup after hard password reset, server status stuck on "Working..."
Your image is corrupt from an improper shut down. I had the same problem. Reinstall default .TIB and it will boot fine.
Jun 22, 2008 | Toshiba Magnia SG20 Server
Samsung SGH-E740 Smartphone Logo
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
