Question about Car Audio & Video
How do you change time on eurovox aw351017 car radio?
My battery went flat and I jump started my car (Holden VT) now my stereo is locked. Dose anybody know how to unlock it. It's a eurovox radio unit.
Samantha, You need the VIN and the radio serial number. Take those into a Holden dealer to get the radio code and programming instructions from the dealer. They may want a small fee for the #. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forums.justcommodores.com.au/vt-vx-holden-commodore-1997-2002/131983-vt-stock-radio-cassette-player-security-code.html
Radio Security code Street Commodores Online Forum
Go Technologies Eurovox FAQs
Aug 26, 2016 | Holden Cars & Trucks
My radio light is on but it doesnt give me an option to put in the code,its a eurovox.
to enter a radio code you use the preset buttons ie code 1324 you press buttons 1324 and then either select or button six and hold until it beeps and the screen shows radio type stuff , i have researched this particular make and the year, whether it has a cd player can make a difference to the actual code and entering it, follow this link for some advise from eurovox owners
How do enter the code into my Eurovox radio Casette jackeroo 1998...
May 13, 2015 | Cars & Trucks
What is the radio code for mercedes benz radio cassette eurovox model 8790
Try asking your Merc Main Agent. Give them proof of ownership and they can look it up for you. If it is the original radio.
Aug 14, 2014 | Cars & Trucks
I have a eurovox radio cd player model rmi 0774 6 or 8 490 and after changing the battery it has stopped working. I have contacted the Mercedes dealer where the vad was purchased in 2003 but they coul
The dealer is the only way to get the code, check your glove box carefully there should be a card the size of a credit card with the radio code, some times i have found that people write code in book, so look carefully.
Oct 30, 2012 | Cars & Trucks
Security code for eurovox car radio
i full out the eurovox car radio of a holden barina 1995,when turn it back it required a security code..anyone can help me have the code..?
thank you...
Nov 06, 2010 | Ford Vehicle Parts & Accessories
Need a sercuity code for my eurovox car radio,model no.4115
Sorry...This Eurovox code will only be available from your Main Dealer or by using a Radio Decoding Service
Will not be available for free from anywhere on the Internet
Jul 04, 2010 | Car Audio & Video
Eurovox radio/cd stacker in 1998 Holden Astra locked
Radio lock out codes are security related to discourage theft, so they are not published on the internet, if they were what would be the point?? any thief could get the code after stealing your radio. Contact the dealer for instructions and what info u need to get your cars unique radio code. How do I know this isn’t a stolen radio? The dealer will require the serial number off the radio and proof of ownership of the car it came from.
Sep 16, 2009 | Car Audio & Video
Car radio pin code
Hi pat... bad news I'm afraid. You need to get the code from Eurovox. There is a way to change/defeat the code, but it involves having the thing apart on the bench and actually fitting a new memory chip to the radio that does not have a code. I used to do this if someone left a unit for repair and we were not left the code. I have cut and pasted the FAQ from Eurovox's site for you, Click the link to their code request form. There are also instructions on how to enter the code
And as always, the bastards charge for the info. Sorry I couldnt actually give you a code. I used to have charge $60 to recode a radio back in the day by rechipping it.
Why is my radio not working after the battery was disconnected/replaced?
The radio requires a security code to be entered. (also known as PIN number). A security code is either 4 or 6 numbers long for most of Eurovox Units.
How can I obtain my security code?
Download the Security Code Request form located in the Downloads section. Fill it out and send it in via fax or email with proof and payment. The serial number & model number of the piece of Eurovox equipment is essential. A new security code card will then be mailed to you and your details will be registered in our database.
Why does Eurovox charge for supplying a security code?
Security and administrative reasons. We enter your details in our database so if you lose it again you only have to identify yourself and give the serial number and we will give you the security code again, we also send you a new code card.
How do I enter my security code to my Eurovox radio/cassette/CD Unit?
Refer to the owner's manual of your equipment. Turn ignition key to 'Accessories' & a number '1' or code '1' or similar will appear. Press corresponding preset buttons as you read you security code. If you have a 6 digit security code, the display will count the preset buttons pressed. i.e. display will show '1' the '2' then '3' & so on up to '6' regardless of which number is pressed. If the security code is correct, the radio will turn on. If the security code is incorrect, the display will show '2' or 'code 2' or similar. After 3 incorrect attempts, the radio will go into 'lockout mode'.
Why has my radio got horizontal lines on the display & is not responding to any buttons?
The radio has had 3 incorrect security codes entered & is now in lockout mode. For recent model radio's leave 1 hour (some radio's require ignition key to be on accessories). For older model radio's, remove power to radio by either unplugging radio or disconnecting the negative lead on the battery for 1 hour.
My radio will not accept my security code?
(1) This radio may have been replaced and now requires a different security code
(2)The security code you have been supplied is wrong.
(3)This radio has an internal fault. To check if radio works there is a temporary test code '1111' or '111111' can be used for most of Eurovox Radio. This only lasts for approx 3 minutes.
How do I enter security code to my overhead DVD/Screen combo unit?
Using the <<or>> buttons on the overhead console, scroll up or down to select the first number. Once the correct number is shown, press the ENT button. Repeat this procedure to enter the 4 digit code. As each digit is entered, it will be shown on the display.
Why does "Code Input Error" appears on my overhead DVD/Screen Combo Unit?
If incorrect codes are entered for more than 3 times, your Eurovox overhead DVD/Screen unit will show "Code Input Error" on the display.
Leave car key in the car and turn it to Accessories for approximated 1 hour, the overhead DVD/Screen unit will reset itself and shows"Security Input 1***" on the display.
Good luck... a FixYa rating would be great for my attention to your problem. Cheers mate
regards
Graeme
Mar 08, 2008 | Car Audio & Video
Car stero
This is what's on Eurovox's website
http://www.eurovox.com.au/html/faq.htm
Most of Eurovox Radios can be removed by removal keys. With removal keys, contact Eurovox to help you find out which keys you will need to remove your radio. There are many different types of removal keys for many radios. Or a visit to your local specialist is another option.
Oct 29, 2007 | Car Audio & Video
Car Audio & Video Logo
12 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
