Question about Fossil AM3695 Wrist Watch
My watch is not working and hw to change my battery
Casio CPW-500H-1AV analog watch not working
That certainly wouldn't hurt - be sure you use good new batteries.
Aug 06, 2014 | Casio Watches
2006 bought, stopped working, does it need a battery change? Is it worth changing the battery?
It looks like you paid over $100 for the watch, I suggest to give a try changing the battery. Actually if you take it to some watch repair shop.. some of them will NOT charge you if replacing the battery does not bring your watch back to life!
I hope this helps!
Marcelo
Oct 23, 2013 | Seiko Coutura Chronograph Watch
Fossil AM3696 not blinking
MY WATCH IS NT WORKING HW TO CHANGER MY BATTERY
Feb 22, 2012 | Fossil AM3695 Wrist Watch
Hw do i change the date.. b.coz for a non-31 month like Sept.. the date displayed is 31 .. plz help
mcdevito75 Here, Press MODE until you get to the date, then press set and set new date, then press MODE again for time display.
Oct 01, 2010 | Watches
Battery changed now watch not working
It sounds as if there is a detector in the watch that registers when the watch has been opened.
Perhaps there is a method of resetting your watch (perhaps known to recognized dealers?).
Read your instructions carefully to see if you can find anything about battery changing. Most makers don't recommend that you change batteries yourself, so I don't hold out much hope on that one.
Otherwise you will have to take it to a recognised dealer in your type of watch.
Feb 02, 2010 | Watches
I have a Casio DBC-60. I changed the battery because was not working for long time, but the watch stil is not working
This is an old problem, but maybe this will help someone changing a battery on a Casio. Many Casio watches must be "zeroed out" by putting an pointed tweezers between the back of the battery and the AC terminal off to the side of the battery. On my old Casio Telememo 50, the AC terminal is in a very small hole just above the battery. On the Baby G force, it was in a wider opening, way at the edge of the watch. It has something to do with resetting the watches circuitry so it will operate again. Good luck!
May 14, 2009 | Casio Watches
My bulova watch isn't working
Even you change a new battery with desame size and volts not working.The problem is in the terminal where going to put the battery.The terminal had a dirt or a film residue that comes out from the battery,you better clean terminal by scratching the old film,the lying down terminal is negative,,the side terminal is positive you better observed polarity if happen inter change the battery side it will not works.If not working, even you clean already terminal,short the terminal connection for 3 seconds,If you have a flourescent with a ballast,put your watch lying where there is strong vibration for five minutes, your watch works 100% txt me whatever the result so i know it's ok.
Jun 02, 2008 | Bulova Men's Watch
Which watch battery do I use?
There are lots of different size button batteries for watches. I work in a clock shop where we change batteries in watches and I have had people bring the watches into me without batteries and it is really a guessing game. A lot of watches take a #377 battery. You can try that or take it to a place that changes watch batteries and let them figure it out.
Mar 08, 2008 | Watches
Fossil AM3695 Wrist Watch Logo
51 people viewed this question
Top Fossil Watches Experts
Arturs Kalnins
Arturs Kalnins
Ray Murphy
Are you a Fossil Watch Expert? Answer questions, earn points and help others
