Question about Minolta bizhub 200 All-In-One Printer
Error c3451 - Minolta bizhub 200 All-In-One Printer
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 91 Answers
Fuser not getting warm enough, first check if there is paper wrapped around the upper fuser roller, if so remove it and reboot the machine.
If this is not your problem then your thermistor inside the fuser unit needs to be replaced
Posted on Oct 22, 2013
??? ??? ??? c3451
Error c3451 is a warm up error meaning the machine has not yet reached the correct temperature within a specific time. To Reset switch machine off using the switch inside the front door, not the one on the control panel. While holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen. Tap that, OK will be displayed then turn off the machine and then turn it back on. This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing.
Feb 03, 2016 | Office Equipment & Supplies
Konica-Minolta bizhub 215 giving c3451 error message?
Sep 18, 2015 | Konica Minolta bizhub Office Equipment &...
Error c3451 for bizhub c450
Error c3451: "Heating roller warm-up failure"
Oct 12, 2014 | Konica Minolta 120v Fusing Unit For Bizhub...
Malfunction c3451 detected for bizhub 250 konica minolta
Try this It could do the trick for you.
The error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
I bet it happened when you first switched on one morning.
Easy to reset and fault usually goes away.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
Read More...
Error Message C3451 and Printer Support and Konica Printer Support
Jul 23, 2014 | Office Equipment & Supplies
Konika minolta bizhub 350 Error c3451
error c3451 is abnormal heating temperature. al you have to do is reset the machine. open the back cover and on the main board look for a micro switch. press it will the machine is turn on. i hope this will help you.
Sep 16, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Problem with my Konica Minolta bizhub 350
The code is for fusing warm up failure. Turn the machine on, wait for the error, then open the front door - you will see a cover on the right hand side which you need to unscrew and remove, behind that is a board (PWB-S1- Tech. Rep. Setting Switches Board) press the trouble button then reinstall the cover and shut the door. Your printer should now reboot - if the error comes back you will need to have the fuser either repaired or replaced.
Sep 01, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Error C3451 ! Anyone? Pretty Please.
This is an indication of a reoccurring error or faulty part. You MUST place a service call.
Oct 03, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
Minolta bizhub 200 All-In-One Printer Logo
59 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
